Previous in Forum: Difference between pipe earthing & RCCD   Next in Forum: Instantaneous Settings of Feeders
11 comments
22.5 kw Motor Not Able to Start From a 60kva DG
08/26/2009 7:14 AM
i have a 30hp submersible borehole pump that works well from mains power but cannot work from 60kva DG i have tried to check on all possible reasons but i cant find the reason please assist on this
Re: 22.5 kw Motor Not Able to Start From a 60kva DG
08/26/2009 8:03 AM
Does the DG trip out on overcurrent, then? If so, then one possible solution is to inroduce a soft-start unit in the motor starter. Another is to install a programmable variable speed drive unit and program it to run-up to speed more slowly than were the pump to go direct-on-line.
08/27/2009 5:00 AM
Check Block loading character curve of you Generator first,You haven't mentioned what would be the base load on your generator when it comes on line ,check once again it looks like your generator is undersized.
crm
08/27/2009 7:24 AM
GA for a good answer in my book....
08/26/2009 11:51 AM
Because starting current of your motor is more than your generator rated output current. In your case star delta starter will not work it out. as per mr.pwslack metioned select softstarter or VFD or autotransformer.
Good Answers: 244
08/26/2009 12:57 PM
Your generator is under capacity to start the motor. In general, when a larger motor (compared to generator capacity) starts on generator, the generator capacity should be at least:
4 times of the motor capacity for DOL starting,
2-3 times of the motor capacity for Soft Starters starting and
1.4 times of the motor capacity for used with VFD
A Good article can be found here:
http://ecmweb.com/training/electrical_basics/electric_sizing_gensets_large/?smte=wr
This type of problem has been discussed recently in this forum. You can search and find more information from there.
-MS
08/26/2009 11:34 PM
Dear Mr. Kirmani,
In addition to the advise by other CR4 MEMBERS, I would like to addthe following:
What about the delivery line valve. Normally a pump should be started with DELIVERY VALVE CLOSED and you have not mentioned about this. I presume valve is there. If not, install a valve in the delivery line and try.
When you want to start your pump on DG SET, close the delivery valve and start the pump. I am sure you will succed.
This suggestion may look cilly, I have come across a case where the pump was started directly without controlling the flow while starting. After installing a valve in the delivery line the pump was started with VALVE CLOSED and succeeded.
DHAYANANDHAN.S,
CR4 FORUM MEMBER
Good Answers: 18
08/27/2009 5:12 PM
I don't believe a submersible pump has a delivery line control valve, does it?
11/15/2009 2:37 AM
Dear Maths,Physics, Maniac,
For submersible pumps valve may not be there, but the question here was related to the MOTOR HP and GENERATOR CAPACITY. The EXAMPLE WHAT I HAVE MENTIONED AND COME ACROSS is 30 H.P. Motor and 60 kVA Diesel Generator Set.
If the submersible pump is of 3 Hp or 5 HP, we do not need a valve in the delivery line when the DIESEL GENERATOR is of 60 kVA. If the motor is of 30 HP and DG Set is of 60 kVA, definitely valve is required in the delivery line, and close before starting, and this will help and solve this particular problem.
I hope the matter is clear to you now.
DHAYANANDHAN.S,
CR4 MEMBER, INDIA.
08/27/2009 7:45 AM
please let me know
if the dG is tripping ?
What typr of Starter you are using Star Delta type of DOL ?
If DG is tripping that means your stsrting load is very high. If DG is not tripping and motor is working but not delivering the water means there is no enough torque.
So check Frequency and Voltage of Generator it shoud be as given in name plate of 30 Hp motor.
08/27/2009 10:47 AM
As usual the person who needs to (seemingly) fix/find the problem, has not a clue about:-
a) Electric motors and their starting currents/starters....
b) DG sets in general
c) How to supply the limited amount of data needed to allow an intelligent and helpful reply......
Good Answers: 18
08/27/2009 5:07 PM
I work for a soft starter company called Aucom Electronics www.aucom.com
As many have indicated, your problem is because the 22.5kW pump can need 6 times or more current than it would normally need when running to start DOL or Direct on Line with a contactor. This is termed a starting current of 6 X FLC ( Full Load Current ). As current is directly related to power ( Power = Voltage X Current ), this means that a DOL start would need a minimum of 22.5 X 6 = 135 kW generator, which you haven't got.
If you can supply me the details of the pump I can determine for you if a soft starter will be able to start your pump with a starting current limit of about 2.5 X FLC. This will demand about 22.5 X 2.5 = 56.25 kW from your 60kVA generator which should be fine.
Good Luck.
Register to Reply 11 comments
Andy Germany (2); Anonymous Poster (1); C.S.PANT (1); dhayanandhan (2); Maths_Physics_Maniac (2); msamad (1); PWSlack (1); uticobala (1)
You might be interested in: Check Valves, Submersible Pumps
