hi me again and it about my car again
as you may know i have a 1988 Chevrolet Celebrity.
this time i was driving home form work and the battery started to die. so i was pumping the gas so it would make it home. so i put in another battery in. then i went to the gas station and fill up. then started driving to the lake but lucky (i guess) it started asking up a block down. so i started pumping the gas again to make it home. if i didn't pump the gas the car would of die.
i think it might be the alternator but...
there is a story behind my alternator. the 3rd.
so this last May i had an alternator problem. so i took off one form my part car (the car i use for parts for this car i have), and changed it. then one week later the alternator bearings where shot. so i got one form Canadian Tire. now this alternator is gone (i think).
i did a test. started my car on a fully charged battier. then unhook the battier to see if the car would still run. i was told that my car i old enough, that it can run with no battier as long as the alternator is good. but it didn't.
so now i think i need a new alternator but i only got that alternator in mid-May. so i want to know if there might be something wrong with my car to kill the alternator or if i could of just got a bad one?
can you Plz help me out with what i should do?
