Hello all,
This project was originally posted in the elect. engr. section, but it has been so long that I thought I would re-post it here. This is an electric bike that I designed and built using a hybrid bicycle frame that I bought for $60.
I wanted to ask some questions about it, and how to go about the process of revising it for electrical efficiency. Right now it draws from 15 to 30 amps while riding and has a top speed of 22 mph despite my ability to shift gears using the drive motor. I am thinking now that if I reduce the RPMs of the motor more, that I will get more torque, better acceleration, and perhaps use less amperage.
Won't the motor be less stressed and draw less amperage if it has better mechanical advantage? I would appreciate comments on this...especially from people who really know something about it. I'm an engineering student but the physics courses didn't sink in all the way so I kinda don't remember how to do the complete analysis.
Below are some photos, and please let me know what you think.
Thanks,
Dylan
Before.
After.
left-mounted 8 speed shifter.
Left: an amp-meter; and right: a bike computer.
Throttle. Basically a variable resistor connected to a PWM motor controller.
900W motor, no. 25 chain, and a reduction of 3.63:1 (40 tooth to 11 tooth)
Right side of bike. Front freewheeling crank with a standard single freewheel that drives it via the jackshaft.
XLR charging port.
I drew up and manufactured the chain tensioners.
