I am currently learning how a jet engine functions and have several questions:
1. Can a turbo-fan engine efficiently cruise above the sound barrier?
2. How do I calculate the torque required to turn the shaft of a turbo-fan, compressor, etc.? (Where do I find the engine specs?...i have tried the manufacturers websites and no specific info is ever available)
3. Is it true that 80% of the thrust of a turbo-fan is generated through the secondary air stream and not the compressor/turbine area (primary air stream)?
4. Theoretically, if you could power a jet engine by means other than combustion (electric motor), could you do away with the injectors/turbines and still produce enough thrust for an aircraft?
