Previous in Forum: Military Willys or Ford Jeep?   Next in Forum: Mercedes Benz C240 2002 - Turbine/Speed Sensor Malfunction
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
1997 Dodge B3500 Van - Spring Hangers
09/14/2009 8:48 AM
we have a 1997 dodge B3500 van with a unibody frame. The foreward rear spring hangers are "peeling"off. The right side hanger is available but the left side has been discontinued. Is there an aftermarket repair kit available or a recommended repair procedure?
Nothing is fool-proof to a talented fool
Pathfinder Tags: repair Spring suspension unibody
Good Answers: 114
Re: spring hanger
09/14/2009 9:38 AM
There are many, but google is your best bet; the big daddy of mail order parts for eons has been:
http://www.jcwhitney.com/Auto-Parts/10101.jcw
Good Answers: 18
Re: spring hanger
09/14/2009 9:58 AM
Lonster I would think any experienced mechanic would be able to rebuild the spring hangers and reinforce the frame if needed without a kit. These parts could be obtained at a salvage yard as a last resort. I would be concerned with the why, as in why this happened. A 3500 is usually a pretty heavy duty vehicle and it would normally take a grossly overloaded condition to cause this damage unless the frame has been weakened by corrosion. Finding this condition necessitates a complete frame inspection and maybe even a report to the NTSB will be in order depending on the cause found. You should also check for any OEM & NTSB Bulletins concerning this vehicle, you may be eligible for repairs covered by a recall. Be sure the repairs are made using good mechanical practices for this could lead to a catastrophic failure. J.Conway
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
Good Answers: 123
Re: 1997 Dodge B3500 Van - Spring Hangers
09/15/2009 11:18 PM
Read #2 again. Then go look for a reason for that spring hanger is failing. That van is uni-body. I have seen some of them rust out early. If your problem is just a small area, you could have it repaired by any competent welder. If it is wide spread, think about replacing your van. Think how that rusted out frame rail will act if another car was to drive into your van. Be safe.
Bob
Register to Reply 3 comments
bob c (1); Jerrell Conway (1); passingtongreen (1)
