Previous in Forum: Critical Spares   Next in Forum: Water out of Tube?
22 comments
Drying a powder
09/19/2009 9:59 AM
A question for you guys-
I want to dry powder (grain size similar to table salt) containing 8% moisture. The powder will be put in aluminium trays in layers of 1cm. The temp inside the oven will be 70 deg C. The flow of air will be such that no powder sholud blow up in the air.
I am not able to understand how to calculate the time required too reduce the moisture to 0.5%. The powder is not hygroscopic.
Help of you guys will be very benefcial.........
Good Answers: 1693
Re: Drying a powder
09/19/2009 10:08 AM
This sounds like homework, again.
Me, I'd just run a couple batches through and do some before and after weighing.
You might ask this guy, he may know, Water out of tube? He's trying to dry a tube. You guys in the same class?
Re: Drying a powder
09/19/2009 10:41 AM
Maybe he's the same guy?
CARPE CRUSTULORUM!
Good Answers: 1693
Re: Drying a powder
09/19/2009 1:04 PM
Put enough monkeys in a room with enough typewriters and sooner or later you might get similar questions, I guess.
No offense to "any cercopithecoid (Old World monkey) or platyrrhine (New World monkey) primate" intended.
Re: Drying a powder
09/20/2009 7:59 AM
I'm glad that you added that disclaimer or I might have been offended.
CARPE CRUSTULORUM!
Good Answers: 68
Re: Drying a powder
09/20/2009 3:03 AM
Hi not so smart,
Perhaps this is a reason for compelling a person to join before asking a question? You would have a name at least?......................
It costs nothing and joining could not be easier? After all, a truly honest person who is NOT a Student usually does join before asking a detailed or complicated question?
Take care.
Re: Drying a powder
09/20/2009 7:56 AM
Hi babybear,
good to hear from you again.
I've been saying that for some time. If you don't sign in you don't get updates...
take care
CARPE CRUSTULORUM!
Good Answers: 143
Re: Drying a powder
09/19/2009 1:26 PM
That's easy. Just time it till it's half way dried, then double the time.
Engineering Fields - Nuclear Engineering - New Member Engineering Fields - Power Engineering - New Member
Location: From going to and fro on the peninsula and walking up and down on it
Re: Drying a powder
09/20/2009 9:18 AM
TVP45, you're a treasure.
oderint dum metuant
Good Answers: 68
Re: Drying a powder
09/20/2009 6:27 PM
Hi TVP45,
Now why didn't I think of that? So obvious really? LOL!
Take care.
Good Answers: 74
Re: Drying a powder
09/19/2009 11:59 PM
Your not in the drug trade are you? Was that a Columbian accent I picked up there.
The Twain Has Met
Re: Drying a powder
09/20/2009 12:24 AM
WAY too many variables not accounted to even attempt to answer.
What moisture level is in the air coming into the oven?
What "surface tension" does the powder have relative to water.
What it the differential migration rate of water through the powder from the bottom of the tray to the drier upper surface. (I suspect this would become a second order differential based on delta humidity.)
Air flow rate would also impact outcome as this is waht would be transferring the moisture away.
(Some might just guess that if they add enough energy to "evaporate" the required 7.5% moisture then that's enough, but you would have to include the calculation for thermal mass of the original material, oven trays and leakage through the walls.)
Tooooooo many variable, not enough information.
Good Answers: 68
Re: Drying a powder In reply...............
09/20/2009 3:20 AM
Hi JaE,
Seems to be a pretty good answer. At least as much as this question 'can' be answered?
You could also bring in the grain 'shape'. Is it mixed or all more or less square, round??? What is the spacing and thickness of the trays?
Would not there have to be some kind of recirculation to dry the top shelves as well and at the same rate as the lower ones?
I am pretty sure this is homework. In which case any mention of the methods described will have already been discussed and the answer already found; just a case of perhaps 'listening more carefully' on a Tutorial next time?
Can someone tell me, if this is to be dried, why leave the drying process at .5%? If it is a powder would it not benefit from total drying? Perhaps to an even 'cake' then be ground again if necessary? The method proposed seems very 'hit and miss'.
Re: Drying a powder
09/21/2009 11:06 PM
I love your answer
Complexity is only compounded simplicty :Johnny Flash 1960
Good Answers: 97
Re: Drying a powder
09/20/2009 4:30 AM
Define: Drying
Good Answers: 42
Re: Drying a powder
09/20/2009 4:38 AM
Make it a closed batch process, and optimize your circulation and exhaust suction level bare minimum to avoid particulate carry over with dry air.
The other best options could be the use of radio frequency or microwaves, where drying rates can be faster and control can be better.
Nature is so graceful and naked. Human possession is ridiculous.
Good Answers: 42
Re: Drying a powder
09/20/2009 12:20 PM
IR heatingcan also be tried.
Re: Drying a powder
09/20/2009 9:33 AM
Hey Guest,
Don't know if this would help, but a recent Dept. of Energy newsletter gave a brief description of experimental process to dry coal particles (fines) so as to be able to recover them from processing waste and burn them as fuel. If I remember correctly it involved subjecting the wet slurry to heat and pressure. I thought it was interesting because the use of pressure was , to me, counter-intuitive, ( you know, vacuum freezing , the process that renders mine waste , into Taster's Choice instant coffee). The newsletter can be accessed on the Dept. of Energy website.
p-rat
oderint dum metuant
Re: Drying a powder
09/21/2009 10:14 AM
It depends upon the dryness of the air coming in, and the ability of the air to pass through the powder instead of going round the aluminium trays instead.
Field trials will determine the best way of doing the drying, rather than equations.
Re: Drying a powder
09/21/2009 12:33 PM
Heat the tray from the top with infra red light radiation.
This can be obtained with electrical tubes or gas radiators.
The temperature can be controlled changing the height and capacity of the radiation panels.
You will need an exhaust port on top of the radiating panels for as natural outlet of vapour and an inlet port for replacement air.
No need of forced air circulation or blowing.
You will have to do some field testing for the amount of residue humidity. More time less humidity.
We dry sludge this way from 15% to 1% humidity.
cheers
Re: Drying a powder
09/21/2009 11:19 PM
I got it why not just suck up the top dry particles
and leave the wet ones
to go around again until they dry
I love my vacum pump and hair blower
and just slaming the dust particles around with 200 psi
just makes the dance so much more attractive
and if you can get them to spin
hey suck them up
in a swirl
and let them dump free falling into a container
by spin and suck you get to all the granuls
for get the pizza trays
if this is not home work
all rules barred with the exception of .5%
whats with that
why do you need .5%
what is the process that requires .5%
are you mixing it with what
is this powder for your face
and you want to keep .5% moisture on your skin
explain a little more
need more input johnny 5
Re: Drying a powder
09/22/2009 1:19 AM
Wow, are you Tom Waites? Awesome answer, needs piano accompaniment though.
p-rat
oderint dum metuant
Re: Drying a powder
09/22/2009 1:41 AM
hello dear all gurus.
How need make solid dihydrogen oxide objects for project . The should be 6 sides , approximately the size of hail size golfballs and be able to bring the process from proof of concept to continuous batch production, my boss has axed me to do this and don't want ask colleagues, who will sense weakness and cull me from the pack and dent my tiffican. I see from other question -answer post much want know electrical service hear, it is 115-240 , 60 psycles, 3-face. THIS NOT A HOUSEWORK QUESTION.
Sorry, p-rat bad person, will be punished. THE BOSS
oderint dum metuant
Reply to Forum Thread 22 comments
angelo (1); babybear (3); bwire (1); Johnny Flash (2); Just an Engineer (1); ky (1); lyn (2); not so smart (3); packrat561 (4); PWSlack (1); s.udhayamarthandan (2); TVP45 (1)
