Previous in Forum: How to do flow linearization?   Next in Forum: Motor bearing get high temp
14 comments
United States - US - Statue of Liberty - New Member
cleaning 27 yr. old chilled water coils
09/26/2009 10:06 PM
how do i clean 27 year old chilled water coils that have never been cleaned before. The coils are 8 pass, 10 fins per inch, 4ft. tall by 10ft. wide by 10in. thick. we are using the Goodway coil cleaner cc-600 with their cleaner, Coil Shine. Man hours on one coil is reaching 40 hrs. of cleaning and the center of the coil is still clogged up. we are using 120 degree F. water to wash and rinse. are they cleanable or do we replace them?
Re: cleaning 27 yr. old chilled water coils
09/26/2009 11:07 PM
09/27/2009 5:50 AM
I think I would just change them out, but to really decide:
Figure out how much it will cost to clean them,
Find out how much a new set is
Figure out the energy savings associate with a new set of coils.
Then calculate the pay back period. If a new set of coils pay back in a year or so then new coils are the way to go.
09/27/2009 11:16 PM
We went through a similar problem with heating coils. They were so heavily encrusted that we found it cheaper and more efficient to replace them.
bioramani
09/27/2009 11:22 PM
Depending on what you intend to get rid off, the best chemical free way is still steam cleaning. Make certain the pressure is not too strong to damage the coil. Try it and see, literally see the miracle of steam cleaning power!
Good Answers: 120
09/27/2009 11:27 PM
these were probably over designed in the first place if they got more and more clogged over 27 years and only now demand replacement.
Suggest you get a capable design team to compute the correct size, replace them and clean them on a regular basis with the cc-600 and do not wait 27 years.
This will probably be cheaper than replacing the overdesigned and clogged coils with new overdesigned ($$$) coils
Per Ardua Ad Astra
09/28/2009 12:44 AM
CHEMICAL CLEANING WILL BE BEST. ARRANGE ONE PUMP, TANK AND CIRCULATE THE CHEMICAL TO REMOVE SCALE. REGARDING CHOICE OF CHEMICAL, CONSULT SOME CHEMISTRY PERSON OR OEM OF THE CHILLER
REGARDS
IRSHAD
09/28/2009 8:53 AM
www.marinerschoice.net
Clean-N-Green On & Gone Stain Remover – Industrial Strength
Highly effective acid-replacement technology for easy and safe removal of heavy stains (tannic-acid, fuel, rust, etc.), and calcium/lime deposits (barnacles, zebra muscles, and other encrustations). Contains natural organic salts to replace traditional mineral and harsh acids, abrasives and solvents. May be used as a pontoon or aluminum "acid wash". Safe on virtually any surface.
MSRP 35.2 fl oz/1L $12.99 • 1 gal/3.79L jug $33.99 • 32 fl oz/946 ml spray $9.99
MSDS
08/06/2010 5:19 AM
do you have a distributer for clean-N-Green On & Gone stain remover in UAE and Qatar?
Good Answers: 19
09/28/2009 11:32 AM
"are they cleanable" - maybe.
"do we replace them?" - if you want.
Sorry for sounding like a "wise guy", but there are a ton of unidentified variables before anyone could venture a reasonable answer to this.
What are these coils serving? Is the space critical of can you go a month while the coils are replaced?
What is the external condition of coils? What is remaining tube thickness? What is fin condition?
Have conditions changed that a redesigned coil is justified? Original coil lasted 27 years. Was it well designed? Or did it limp along because no one paid attention to it?
What was circulated through the tube? untreated water? glycol solution? tri-methyl death?
What is the space available to wrestle the old coils out vs wrestling new coils in? It could take a week or a month for a crew to make a change out.
There probably is not a cut and dried economic choice, but a gut feel based on long term plans for operating your facility.
09/28/2009 12:24 PM
Hello Jray,
What is the contamination, that you want to clean from the coil/fins, hotwater and even a good chemical will not clean some surfaces, let me know the surface, material, contamination to be cleaned etc.
09/29/2009 2:07 PM
Aluminum coil fins, the air passing through the coils is non-corrosive, outside air is sometimes very dusty, the matter that is coming out of the coil is hard deposits about the size of a #2 pencil lead, large granules. The interior of the outside of the coil is very difficult to reach with this coil washer. We are having some success but now it takes much time to remove small amounts of deposits.
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
09/28/2009 4:14 PM
"27 year old chilled water coils that have never been cleaned before"
I'd say you've got your justification to replace it based on:
  • Permanent loss of efficiency caused by corrosion and pitting
  • Potential EPA/OSHA liability created by continuing to operate faulty/degraded equipment that could lead to a refrigerant release or a technician being hurt.
"If you know about it they call it negligence"
I inherited an ammonia refrigeration plant that had been neglected for years and regretted almost everything that we repaired instead of replaced.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
United States - Member - Old Member
09/29/2009 1:54 PM
First, what kind of enviroment is the air handler in? This might be a varible needed to know to chose which cleaner to use. Keep cleaning until clear water flows through, then start unit and check pressure differential on both sides with magnehelic gauges. Find out what factory specs. are for the paticular coil, and, then make determination to replace or not. Finally, keep the air filters changed on a regular basis (don't be cheap - use good air filters).
10/07/2009 7:30 PM
If the coil that you have is copper tubes with aluminum fins, then the price for that coil would be around $6300.
Register to Reply 14 comments
Anonymous Poster (3); aurizon (1); bioramani (1); CoilPro (1); IRSHAD (1); jray (1); Livewire (1); markar (1); Mikerho (1); Ried (1); Sasnak (1); Steve S. (1)
