Previous in Forum: Calibration of a DP cell   Next in Forum: Pressure Transmitter Tapping Point
One Sleeve, Two Cables
09/28/2009 8:32 AM
Hello Frnds
Thers a Concrete pipe(250 mm ID ) sleeve of 8 M, With concrete road Above it (Road Crossing )
Can V run Instument (Triad and Fiber optic cable ) in the same sleeve as it already contains Electrical cable
Regards
jose
Good Answers: 981
Re: Dist Between Inst and Elect Cable
09/28/2009 11:51 AM
This can be considered a semantic argument but I'll make it none the less. Yes you can run signal cables though the same conduit as power cables. But only if you don't exceed the recommended fill capacity for that size conduit. It would be better to run a separate conduit for signal wires though but sometimes this is impractical. The code for your location will spell out your limits on conduit fill capacity, consult it.
Good Answers: 68
09/29/2009 1:20 PM
Hello redfred,
A good point on the Conduit detail.
GA to you Sir.
Take care.
09/28/2009 12:23 PM
There is no issue with running fibre-optics in proximity with any type of electrical cable.
Re: One Sleeve, Two Cables
09/29/2009 6:47 AM
I would suggest placing Maxcell Fabric Innerduct first to avoid burning the existing cable when placing new cable.
http://www.maxcellinnerduct.com/
Register to Reply 4 comments
Anonymous Poster (1); babybear (1); PWSlack (1); redfred (1)
