Hello Dearhearts,
In posting this I am expecting four things:
1. Well-reasoned posts that explain what I have proposed is not feasible.
2. Well-reasoned posts that concur with my thoughts.
3. Humorous posts questioning my,____________ , fill in the blank; sanity, patriotism, taste in music, odd use of punctuation marks.
4. The Spanish Inquisition, oops, sorry, no one expects the Spanish Inquisition.
So don't disappoint me.
Now the question.
What are the pros and cons of the following process?
Start in a venue with suitable soil for excavating deep, relatively impermeable vertical pits. Use the machines,( I was going to refer to them as boring machines ,but that would be subjective on my part), take the machines that were used to dig wide, vertical shafts for underground nuclear tests. Dig the shafts deep enough to facilitate the process that I will describe. Drill a hole adjacent to, and ,that will communicate with the bottom of the pit, imagine something functioning similar to a sump pump in a basement.
Have persons pay you to collect their household garbage, yard waste , lumber mill saw dust, Chinese drywall, Vanilla Ice Cd's, used kitty litter, disposable diapers, whatever.
Now dump this raw feedstock into the pits. When sufficient mass is reached , I would bet a dollar , some combustible, fluid or gas would be created and that could be drawn off at the bottom of the pit.
Isn't that how nature does it: organic matter+ heat+ pressure+time= hydrocarbons?
Since we are smarter than nature we surely could find something to expedite the process, some kinda catalyst or sumpin'.
In the past it was expensive to make artificial diamonds, now they apparently churn them out like disposable razors. I am counting on you Brainiacs to take this half-baked idea and make it full-baked, or barring that , to point out how I have run off the rails.
Packrat ----out
