Previous in Forum: Scratches on Printed Circuit Boards (PCBs)   Next in Forum: Woodwards EasyGen vs. EGCP-2
Good Answers: 25
NE5554U Data Sheet
10/14/2009 1:03 AM
Does anyone have application data on this Adjustable Dual Tracking Voltage Regulator ?
I have googled the heck out of it and got nothing but relatives without application notes.
NE5554U
Pins 1 and 9 + & - inputs, 5 is common, 2 and 8 are outputs, 3 and 7 are no connection and 4 and 6 are balance and adjust (I don't know which is which).
I saw the the spec sheet years ago and it shows the range of resistors for setting it up with +20 & -20 Volts input and the range of divider resistors desired output and the range of divider resistors for tracking.
I have a fistful of these.
Jon
Re: Can't find an NE5554U data sheet.
10/14/2009 9:01 AM
Have you tried this?
NE5554*
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Good Answers: 25
10/14/2009 1:03 PM
Indel,
Thanks much that helps a lot.
The Signetics Mullard file is good.
The one I want has a range of resistance values. Google has not served well for that.
Jon
10/15/2009 7:17 AM
10/18/2009 7:02 PM
Good Answers: 12
Re: NE5554U Data Sheet
10/17/2009 3:33 PM
Noting the date code on your sample... 1978? They been around for a while. The NE prefix leads me to believe a Signetics part (maybe) but Signetics no longer exists. I don't know what happened to them.
You might try LM5554. This would be a National part number (if they also manufactured it).
Bill
Good Answers: 25
10/17/2009 5:36 PM
Sciesis2,
Yep. pretty old.
Signetics, yes.
No LM5554 data found.
The Signetics NE5554U is unique.
I found info in an unusual place.
Jon
Good Answers: 25
10/17/2009 8:48 PM
Sciesis2,
After a long detailed search I found the Signetics NE5554U in a High Voltage Foldback Power Supply patent used for electrostatic coating application.
The info was included in the text of US Patent 4485427 by Fred W Woodruff and Daniel C Hughey.
It gave me the pin-outs for the unique U type 9 pin SIL package.
I am now a happy camper as I am able to use these ICs for projects.
I used a couple of 10kΩ pots for the adjustments and they work great. I can get the divider values from them and put in selected fixed resistors for R1 and R2, R3 and R4.
Register to Reply 7 comments
indel (3); kudukdweller9 (3); Sciesis2 (1)
