Previous in Forum: GOV SPECIFICATIONS   Next in Forum: How to solve the mismatch of bolt on tapped holes
23 comments
High Vacuum Sealing a Pouch
10/20/2009 5:51 PM
We are trying to seal a material in a pouch made of barrier material at vacuum in excess of 1x10-2mbar.
However, even when the contents of the pouch is inert (ie clean stainless steel washers) we cannot seal a vacuum of less than about 1mbar. We test the vacuum sealed in the pouch by placing the sealed pouch back in the chamber and pumping down until it starts to bubble up (ie show more pressure in the pouch than the chamber). We invariably find this is about 1-5mbar despite making the original seal at 5x10-3mbar or less.
The barrier material is 12micron Aluminium Oxide coated polyester with a 50 micron laminate Polyethylene sealing layer. We are sealing at 135C and about 40psi across a 20mm bar. The sealing bar closes against a 6mm thick silica matt. The pouch dimensions are 25mm sq and about 2mm thick or less. The pouch is held open prior to sealing to ensure good conductance and evacuation. The pouch and contents are baked prior to entering the chamber to draw out water vapour.
We have witnessed the pouch 'inflating' when the sealing bar is applied and afterwards if the pumps are left running - even though the chamber had reached more or less equilibrium prior to sealing. We presumed this was out gassing from the seal.
Has anyone any experience of sealing barrier material at high vacuums in excess of 1x10-2mbar?
Any alternatives to using the process we describe here to seal a polymer pouch at these vacuums?
Any suggestions why we are not able to seal the level of vacuum in the chamber in a polymer pouch, or why despite the levels of vacuum achieved in the chamber, only about 1mbar is always sealed in the pouch?
Thanks for reading...
Re: High Vacuum Sealing a Pouch
10/20/2009 7:02 PM
Know nothing about vacuum sealing, but here's a thought:
Does the pressure at which the "bubbling up" happens vary with the time since sealing? This should at least differentiate between "something" being sealed in from the start, and either something outgassing inside or something permeating through from outside.
Another thought - could be expensive!! - any chance of getting the gas inside analysed?
10/20/2009 8:00 PM
Hi John
Thanks for your reply.
After a period of time there is some minor loss of vacuum. The evidence suggests that whatever is causing the significant drop in vacuum is happening immediately the pouch is sealed. There is little evidence to suggest that any inserted material is out gassing and causing the loss of vacuum as the same happens when an stainless steel is inserted in the pouch.
The barrier material is high grade with very low permeability.
Yes, we are hunting for an RGA to detect the gases given off during the sealing process into the chamber with a view of designing a getter for them.
DT
10/22/2009 3:37 AM
Did you mean to say "as the same happens when no stainless steel is inserted in the pouch."?
If not, have you tried this?
10/20/2009 8:39 PM
While I don't have a huge amount of experience with vacuum systems, my guess is that the plasticizer is coming out of the plastic. The main purpose of the plasticizer is to keep the plastic from becoming brittle, so a little is helpful for the long run. To get rid of it, you could try putting the bag in a vacuum oven at as high of a temp as you dare for a few hours. I would guess that high vacuum for 2 hours at 120C would greatly reduce your problems.
10/21/2009 5:47 AM
I had though it to be out gassing so I left the complete package baking out over 24 hrs at high vacuum with the same results.
10/21/2009 10:59 PM
I get the impression that your sealing process is outgassing something from the pouch material.
Good Answers: 50
10/21/2009 11:12 PM
I'm no vacuum-head either, but I'm interested in your use of polyethylene... On a molecular/atomic scale, polyethylene is very porous. In fact, I was experimenting with batteries a while ago, and I was looking for a material that would keep the liquids separate, but would allow the ions to pass freely. Turned out polyethylene was the best material I could find for doing this.
So is it possible that polyethylene works as a vacuum barrier up to a point, but is too porous for the vacuum you're trying to maintain?
10/22/2009 6:54 AM
Hi, that is an interesting thought. Are you suggesting the seal would rapidly leak until the internal pressure had reached an equilibrium at about 1mbar?
Did you also consider Polyethylene terephthalate for your purpose which is also commonly used as a sealing layer in barrier film structures although it melts at 175C rather than Polyethylene's 135C.
Do you think Polyethylene terephthalate could offer a more robust barrier at this level of vacuum?
DT
Good Answers: 981
10/22/2009 9:37 AM
Most of the vacuum sealed pouches I've seen are aluminized Mylar (aka Polyethylene terephthalate). This is what was used for the old passive communication satellite Echo. To not leak gas for years in space is a testament to how good of a seal one can get. That says nothing about out gassing though.
10/22/2009 3:14 PM
Hi Redfred
Mylar is indeed one of the materials we are using in this application.
DT
10/22/2009 12:32 AM
Please to http://www.iop.org/EJ/abstract/0508-3443/18/10/313 from British Journal of Physics.
I quote the following abstract which might throw some clue to your problem.
"Since stainless steel usually contains large amounts of hydrogen and the diffusion coefficient of hydrogen in stainless steel is high, it was suspected that the hydrogen diffuses to the surface from the interior of the metal and is released into the vacuum. Calculations show that the observed outgassing rate could be explained by such a process and should be reduced by several orders of magnitude by a high-temperature treatment. The effects of residual hydrogen in the treatment furnace and hydrogen permeation from the atmosphere are also considered in these calculations. The greater the thickness of the metal, the higher the temperature has to be. Measurements are in reasonable agreement with these calculations."
Good Answers: 50
10/22/2009 12:40 AM
Just a question... By heat treating the stainless, aren't you running a risk of changing its characteristics?
10/22/2009 2:54 AM
Depending on the material specification a metallurgist will be able to answerer this sensible question.
Most likely an atmospherically controlled heat treatment should take care of this concern.
Good Answers: 93
10/22/2009 6:09 AM
When we use stainless in vacuum applications we stove the parts at 1000°C for 1 hour in a reducing nitrogen atmosphere to ensure that no outgassing occurs later.
10/22/2009 6:48 AM
Hi Krishnan
Thanks for your reply, the stainless steel is a bit of a side track to the issue, I only used stainless steel as a control it is not part of our process, and I believed it to be fairly inert at 10-3 to 10x-8 mbar. At a greater vacuum I can appreciate the need to bake out as you describe.
Trying to evacuate an 'empty' pouch results in the same anomaly I described in the original post - we cannot seal below about 1 mbar.
DT
Good Answers: 93
10/22/2009 6:12 AM
Presumably this is to keep the components clean until used. The alternative would be to purge the bag with components in using dry nitrogen then seal with the bag slightly inflated with nitrogen.
Good Answers: 109
10/22/2009 6:58 AM
Hi,
"12micron Aluminium Oxide coated polyester"
if this is really aluminum-oxide (please check) then there is the possibility that this has absorbed a lot of air and water. This cannot be outgassed in a short time at low temperatures. So if this is really oxide, then switch immediately to metallic aluminum barrier.
Usually these barriers are metallic aluminum as oxides will not be tight. If so your barrier may be ok but be sure that you have Polyester on both sides. Think about films for sealing food under nitrogen: usually up to 7 layers. each with a different leakage behaviour.
Mabe sources of problems:
A.: stored gas and liquids in the plastic material slowly diffusing and outgassing. This can be adressed by longterm outgassing prior to use (150h 130°C would be appropriate at desired vacuum or below). Most problematic: water and nonpolymerised components of plastics.
B.: Surface contamination by fingerprints or "cleaning" fluids or fabrication residues.
C.: Reaction of aluminum layer with water to produce hydroxide and hydrogen.
Let measure the gas that is spoiling your vacuum by RGA (mass spectrometry = residual gas analysis), often used for detection of volatile material and vacuum and environment. Needs 20 to 30 K$ investment but can be done by any vacuum component company and from many institutes/universities. Then you know which gas spoils your sealing, then search is much easier.
I would try as next step: better sealing material. I had (long ago) good experience with "Puma Folie" from a German supplyer (Puma Foil) that is intended to seal machine parts under inert gas or vacuum for prolonged storage or delivery to humid areas.
RHABE
10/22/2009 10:35 AM
Thanks RHABE
Some useful suggestions there.
My barrier material supplier is a specialist and assures me this is the correct material but they normally use it to seal at 1mbar not 10-3mbar. The aluminum-oxide is coated on layers within laminated polyester and 'should' not be exposed to oxidation but I will check with them.
We do try and keep the material clean, handling with latex gloves.
We tried baking out the packages at vacuum over night - they will only sustain a temperature of 50C. There was no noticeable change and it was this that rather ruled out outgassing from the component parts in my mind.
I am already looking for a cheap RGA - if any one has one available (2 1/4 inch con-flat flange) let me know!
DT
10/22/2009 1:45 PM
In a different context, we had problems with oligamers (lower molecular weight polyester) on the surface of finished biomedical implants creating tissue overgrowth. Extracting the oligamers in a Soxhlet extractor removed the anomaly and has been introduced into the process. It is likely that a similar situation may exist in this case as well.
bioramani
Good Answers: 109
10/22/2009 4:42 PM
Hi,
"aluminum-oxide" is a whole bunch of different materials with many modifications and nearly all will absorb large amounts of water.
Only the material deposited as thin-film in high vacuum by evaporation or sputtering or other plasma deposition is nearly non-absorbing (and thus also desorbing moisture).
So try a material with pure aluminum as the barrier, this will be much better.
I have two RGAs for sale, one was in continuous operation from 1998 to 2003 (Balzers), then only in storage, may need new filaments and cleaning at filament site. The other one was purchased as "used, in working condition, but displays: permanent fatal error in the RS232 data transmission, MKS make. Location: Germany. Price to be discussed.
RHABE
Canada - Member - New Member Engineering Fields - Systems Engineering - New Member Hobbies - Hunting - New Member Hobbies - Musician - New Member Safety - Hazmat - New Member
10/22/2009 7:24 AM
I agree with Vermin. I think you need to change materials. I'm not sure what your requirements are but I would use a Buna or Viton material, these "rubbers" perform much better under vacuum and are used in almost all vacuum pumps. Also how are you sealing the pouches? after the pouch is sealed how are you checking the vacuum inside? The actual sealing process could cause a poor vacuum reading depending on how your getting the reading in the first place.
Hey, it may look confusing but it's really just Simple!!!!
10/23/2009 3:07 AM
We are an engineering company marketing vacuum pumps and systems for variety of applications. I will review your requirement and respond.
I would like to have schematic of your process so that I can help you resolve your difficulty.
Best regards,
Hari Rambhia
Avni Enterprises
6/306, Jogani Industrial Complex,
V. N. Purav Marg, Chunabhatti,
Mumbai - 400 022, Maharashtra, India
Tel : 0091 22 3296 8812
Fax : 0091 22 2405 6329
e-mail : avnient@vsnl.com
10/23/2009 3:09 AM
I don't know anything about this sort of thing so please forgive (and ignore) me if I'm being stupid.
Is it possible to carry out an experiment something like this.
1.) Insert a wire or something similar in the "mouth" of the pouch.
2.) Reduce the vacuum to 5 x 10-3 mbar.
3.) Seal the pouch as shown:-
4.) Remove the wire, and, reduce the vacuum to 5 x 10-3 mbar for a while (with the pouch flat).
5.) Make the second seal as shown:-
6.) Remove vacuum.
7.) Re-apply the vacuum, and, check result.
I'm simply trying to reduce the outgassing caused at the edge of the heat sealing process to a minimum.
Register to Reply 23 comments
Anonymous Poster (2); bioramani (1); dkwarner (1); DT11 (6); JohnDG (1); krishnan.ng (2); Nigh (2); Randall (2); redfred (1); RHABE (2); Simple1 (1); vermin (2)
