Previous in Forum: Memory Wire and Corrosion Resistance   Next in Forum: Heat Pumps and Cooling Towers
High Pressure Flanges
11/02/2009 7:21 AM
Hi Colleagues,
We have a design condition of 7260 psig (500 barg) just downstream of the wellhead. At 100 deg C and using group 1.2 material, ASME B16.5 only allows us to go to 429 barg (2500 pound Flange)
Does anyone know of any stronger ASME flanges, or is the solution to go for API 10,000 psi rating flanges?
PS I have Googled and Wiki'ed and have hit the buffers! Please help!
Thanks in anticipation
Stewie
Re: High Pressure Flanges
11/02/2009 9:16 AM
You are in the API area why you want to diversify into ASME?
Good Answers: 49
11/03/2009 1:14 AM
ASME pressure ratings are typically at equivalent steam working temperatures and pressures. This is why "smaller" valves have two ratings- 150 PSIG (SWP) steam working pressure and 300 PSIG (WOG) water-oil-gas because of the higher strength when the metal is cool.
Your 100C condition is essentially "cool", so check flange ratings using air or water in pipes. Obviously, the 10,000 PSIG will work, but at what cost?
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
11/03/2009 8:12 PM
I've just see your question. Refer to ASME B16.5, the highest working pressure of #2500 valve is 6250psi. So you have to looking for solution in API 6A.
Best Regard!
cvt_82
11/03/2009 10:55 PM
Thanks a lot.
Puts my mind at ease.
Stewie
Register to Reply 4 comments
Anonymous Poster (1); dcongvt (1); energygod (1); Stewie (1)
