Previous in Forum: Magnetic Field   Next in Forum: Design rating of Variable Frequency Drive for 20KW induction motor
Sample and Hold Circuit
11/05/2009 4:41 PM
I have been trying to figure out the calculations for a sample and hold circuit (basic) with respect to the capacitor size for parameters.
For an input of 1v sinewave (10khz) being sampled at 100khz. I will be using a mosfet for switching and this will be controlled by a square wave.
Another problem I am having:
I got the circuit done with a voltage buffer input/output and a mosfet/capacitor etc. However by output has very noisey harmonics in the output. Can anyone suggest anything for that?
Thank you for your time.
Re: Sample and Hold Circuit
11/05/2009 6:55 PM
Is this a college project, a bit of DIY, or what?
Good Answers: 119
11/05/2009 7:24 PM
Given:
1 [V] (RMS or peak-to-peak?) sine wave at 10 [kHz]
10 [microseconds] between samples
Please supply the following parameters:
MOSFET Rdson value [ohms]
S&H capacitor C value [microfarads]
Buffer amplifier input impedance and/or bias current [ohms] [nanoamps]
Good Answers: 982
11/06/2009 10:13 AM
I think your ill defined noisy harmonics comes from the charge injection that your solid state switches generate. Depending on the topology and component selection, with sufficient time settling after acquisition this error will either be proportional to the voltage to be measured or a nominal constant value. In either scenario though this should be a predictable offset that can be compensated for, once understood.
Obviously though this relies on the idea that your noisy harmonics are harmonics of your sampling frequency. If you mean something else then please clarify what these harmonic frequencies are multiples of what anticipated frequency. Also don't forget to identify where you measure these signals; after your input buffer, on your storage capacitor, after the storage capacitor buffer. Lastly identify what you used to measure these harmonics; analog oscilloscope, digital oscilloscope with FFT capabilities, dynamic signal analyzer, analysis of data set from A/D converter.
JohnDG (1); mjb1962853 (1); redfred (1)
You might be interested in: RF MOSFET Transistors, Power MOSFET, Circuit Breakers
