Previous in Forum: How to Measure Steering Gear Ratio   Next in Forum: 1978 Ford F150 - Low Compression in One Cylinder Only
9 comments
Diesel Float Switch
11/05/2009 11:21 PM
I want to install a float switch to a diesel tank on a fork lift equipment. Does the float switch have any contacts exposed to the vapors? I dont want to create an explosion. I am guessing that one type of float is a magnet which will close a set of contacts inside the rod once it reaches to low of fluid level. If not, do I need any special permissible relay. The equipment runs off 12vdc power. Any help on this would be greatful. Good luck.
Re: Diesel Float Switch
11/06/2009 12:18 AM
I wouldn't worry about setting a fire on the inside of a fuel tank, since there is no oxygen inside of a fuel tank. Even if this were a gasoline tank, as long as it has any gasoline at all in it, the fuel/air ratio is way too rich to support combustion. Stop and think about how fuel level sensors work, and in tank fuel pumps? There is nothing shielded about either of them.
Test first, replace parts later
11/06/2009 12:27 AM
GA. Not only that, but there are various types of liquid level switches in which the electrical parts (which might arc) are not exposed to the fluid/vapor they are sensing. (My field is ammonia refrigeration, and we are protecting from corrosion rather than ignition, but refrigerant float switches are probably more expensive than needed for this application, though they would work.)
11/06/2009 2:29 AM
They use a totally sealed reed switch (reed relay) which is operated by a magnet housed in the float.
So you will be fine.
11/08/2009 9:37 PM
Awesome, this information is very helpful to me. BTW, the tanks are not air tight because they all have air vents. This is very helpful for me on a 1000 gallon diesel tank in an underground mine.
11/06/2009 9:58 AM
What ever you do , handle negative pole at the switch , so you will avoid any spark if a wire is cut or loose.
All level device in combustible tanks are negative pole connected.
devitg
11/06/2009 11:06 AM
Somewhat off topic here but the fuel level sensor in my, now departed, 87 BMW was a vertical metal tube with a central wire, these two served as terminals for the sensor which read the resistance which fluctuated as fuel level rose up the tube. It was great fun at about half a tank to take a hard right hand turn followed by a hard left and watch the fuel level go from half to empty to full in a matter of 30 seconds.
As for floats i know there are some that are totally mechanical which if worried you could likely purchase made out of brass or something nonsparking. Basically a butterfly or ball valve which closes when the float reaches the "full" level.
-T
You win some, you lose some, but with Cook-out you always win- Jacob Epps
Good Answers: 39
11/06/2009 10:24 PM
There are literally millions of fuel tank level float switches both gasoline and diesel out on the public roads that have one terminal connected to a wire and the other side grounded to the metal tank. Generally this variable resistor grounds out the gauge circuit installed in the dash. Have yet to see such a device cause an explosion or fire. The wire wound resistor is shorted out by a wiper arm connected to the float.
Elnav
Good Answers: 213
11/06/2009 11:08 PM
There are also f leuel level switches that consist of a pressure sensor mounted on top a tube extending into the tank, which sense the change in air pressure inside the tube as the fuel level changes. No electrical contacts inside the tank. Check out marine supply houses for these...
11/11/2009 8:31 AM
its possible to use float switch.!!!
what type of float switch do you want to use...liquid,ball or dipping.?????
does the fork lift has diesel return?
if yes,this what you need to do.due to the heat produce by the returned.there is need for ventilation.a small opening.if not, there's a light foam in the floatswitch{a dunlop}it will melt if the get hotted.
the float switch can be used by AC or DC.use your meter to read the up or down.{ON or OFF}.then apply.adjust the end to your require measure for re-filling.
Anonymous Poster (2); bwrench (1); cwarner7_11 (1); devitg (1); elnav (1); Everenlightened (1); Tornado (1); user-deleted-1105 (1)
