After searching all the threads I could find on CR4 that related to cylinder compression, my question is:
What are the possible causes for one stand-out low compression cylinder given the data offered below, and what are the best steps to take to correctly diagnose this?
In tracking down a steady miss in my 351M Ford engine I found the #3 cylinder to have 50 psi and the others to have 120-130 psi dry and up to +5 psi increase wet. Tested cold. Didn't bother warming and re-testing since the obvious result was significant and consistently repeatable. The 50 psi became 55 psi wet.
For some time I had suspected a slipped damper pulley/timing issue, but this year was the first year it would not meet the HC (hydrocarbon) standards of the smog certification, thus leading me to take steps to diagnose the cause. The technician was helpful in hinting that the 'ping' was probably due to a non-firing cylinder which would imitate low octane or advanced timing 'ping'. It typically rattled on climbing a hill or accelerating but improved some with high octane fuel.
I drive this vehicle rarely, and have recently invested the time to cure other issues that kept the low cylinder less than obvious. The distributor shaft wobbled badly, the engine overheated (leaking freeze plug) and the electric harness was from the wrong year, fried the ammeter, not charging well etc.
With that and a few others cured, this was more noticeable and is now my main focus.
My assumption at this point is that I will be looking for an issue related to the valves, since the 5 psi rise wet over dry seems to indicated normal ring wear compared to the others.
I have pondered lifters, springs, seat deposits, worn cam lobes, bad guide seal, oil passage blockage, slipped spring retainer wedge etc, but none of my experience to date has given rise to an educated guess to guide me in looking for the cause.
I plan to start by pulling the valve cover tomorrow, but failing to find something obvious, I would hate to pull the head or otherwise cause major issues needlessly if there is an obvious list of less drastic things to do first. For instance, I have considered putting a can of SEAFOAM in the fuel to see if that would clear it up.
Some clues are conflicting however, such as noticing that the steady miss was gone entirely immediately when the new distributor was first in, purred very smoothly, but returned a few minutes later after setting the timing and messing with the plug wire loom. Also the vehicle runs smoother after getting up to temp but the miss is still detectable.
I will check here periodically, and also update as details become clearer. Thank you all in advance. It's nice to feel safe asking things that reveal the gaps in my understanding. CJM
