Previous in Forum: Seeking Displacement of 1904 Engine   Next in Forum: 1997 Ford Falcon EL - Wiring Problem or Short Circuit?
11 comments
2005 Chevy Cavalier Has Trouble Starting After Being Driven & Hestitates Driving
11/15/2009 3:46 PM
I'm hoping someone can help me out. I have a 2005 chevy cavalier. A couple weeks ago I noticed after the car has been driven it was hard to start. Fast forward yesterday, it's nearly impossible to start after driving. I have to pump the gas and hold the gas pedal down for nearly 10 minutes before it starts. When it does the engine comes on very faint and finally gets louder and fully starts. Now it starts just fine after it sits all night, or during the day when i'm at work. The car turns over, it just won't start. Also today it started hesitating while I was driving. I would put my foot on the pedal and it would act like it wasn't going to go. It broke out of it and finally did go. I drove about 50 miles and it did it 5 times. My friend in a car behind me told me there was black smoke coming out of my muffler when it was hesitating.
Re: 2005 chevy cavalier has trouble starting after being driven & hestitates driving
11/15/2009 4:02 PM
Clogged/collapsed converter or muffler?
Good Answers: 97
Re: 2005 Chevy cavalier has trouble starting after being driven & hesitates driving
11/15/2009 4:04 PM
A few questions are needed to appropriately answer...
What is your physical geographical location...
Please give a brief but accurate to your knowledge description of vehicle maintenance during the last 5 years, services etc..
Has fuel economy changed over the past 6 months and how so...
What is the overall condition of the car including mileage...
11/15/2009 4:11 PM
I'm about an hour from Philadelphia. I bought the car new, and I have kept up on oil changes, etc. It has 159,000 miles on it. It hasn't had any problems up until last year. Last November it had the timing chains changed on it. After they were changed the car never idled right, and the mechanic told me it had a misfire in one of the cylinders. He told me it wasn't worth fixing so i've been driving it since. I did take it to autozone last night, they scanned it because the check engine light came on. It scanned as an 02 sensor. The misfire didn't even come up. I have heard to 02 sensor won't cause the problems i'm having though. Fuel economy has been normal. It did go through a brief period of running rich and lower gas mileage about 6 months ago. I took it in and they couldn't find anything wrong with it. It seemed to have corrected itself soon after that and is fine in the aspect still.
Good Answers: 97
11/15/2009 11:37 PM
All things considered it seems you may have been taken advantage of by the mechanic that changed the cam chains as Tcmtech indicated in his thorough description.
Bought new and responsibly maintained, I'd expect the engine would exceed 300,000 usable life, so it's a little over half in the bag and may have a half life; another 150,000 miles remaining.
Peruse Tcmtechs post and have the car inspected by a reputable mechanic and the dealer or a quality car care center is a good place for the inspection. Then you can make an intelligent decision with the results of the inspection. The level of expertise at the dealer could be advantageous if actions are take against the other shop.
Give a heads up when you have the results in hand
11/15/2009 6:16 PM
It kinda sounds like something is leaking down and flooding the engine. I would start with a fuel pressure test, then wait and see if it leaks down in to the engine while it sits. Injectors and fuel pressure regulators can sometime leak and cause the symptoms you are describing. Another possibility could be the car thinking its cold all the time and dumping fuel accordingly.
11/15/2009 6:28 PM
Pumping the peddle on a fuel injected engine doesn't do a thing. Sorry but that method stopped working about 20+ years ago on most Chevy's!
The come and go almost running right effect is likely from the vehicles computer system trying everything it can to keep the engine running.
Heres what I suspect from what you have said so far. It is just a guess but still a some what educated guess.
One. They set the timing wrong and where too lazy to fix it because it actually ran without killing itself entirely.
Two. It may have had a slightly bent or damaged valve because they set the cam timing wrong. Thats where the miss could have come from.
Three. Unburned fuel blowing past the bad valve seal destroyed your O2 sensor and catalytic converter.
Four. With a possible bad valve, miss timed cam, bad O2 sensor, now fouled spark plugs, and a burned out and mostly plugged catalytic converter thats why its hard to start and has odd driving problems. Once it cools down there is enough openings in the converter to let the exhaust gasses get by for a while and it will start.
I would recommend finding a good reputable service business or preferably a dealership and get it checked over fully. Should they find that the cam is in fact miss timed and there is other damage as a result of it I would seriously consider getting after the place who did the work the first time around! Maybe even get a lawyer involved if there is enough evidence to prove they screwed it up especially if there is a low amount of miles from when they did the work until it stated getting worse!
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
11/16/2009 12:19 AM
This is not an all-inclusive list, and it is possible under some circumstances to add or delete items. It is a basic performance testing menu.
Basic testing sequence:
Pre (cold) start attempt:
Check for proper battery voltage
Install fuel pressure gauge
Check for pressure and volume (check spec table in repair manual)
Install engine analyzer
Check for spark at a minimum of two cylinders
Check for injector pulse at a minimum of two cylinders
Pull codes
Check ECM/ECU data stream
Attempt to start: if starts and runs:
During running, recheck:
Fuel pressure/volume
Primary/secondary ignition scope traces
ECM data stream
Speak softly and carry a big stick.
Re: 2005 Chevy cavalier has trouble starting after being driven & hestitates driving
11/16/2009 3:26 PM
Similar problem encountered in 2005 Chevy van with 160,000 miles. Problem was clogged catalytic converter and bad O2 sensor. You should always replace O2 sensors in pairs, i.e. if you replace one on the right side you should replace both O2 sensors.
God Bless everyone!
11/16/2009 4:51 PM
Thank -you
from Guest (post) #1
(repair shops always seem to neglect/forget the exhaust system when diagnosing these things - and wild goose chase, spending lots o' troubleshooting money)
Good Answers: 46
11/17/2009 5:16 AM
Here another area to check. The ignition module and/or coil pack.
I had a 1996 Oldsmobile w/3.6 ltr. engine. I had very similar problem it showed it's self in hesitation and missing then hard to restart if driven for some distance. Then it would not start unless it set for several hours. I found the ignition module was dripping some black goop. I made the mistake of touching the housing it was HOT!
Later after I got it home then I removed the coil pack most if not all of the epoxy potting had lquidfied and leaked out. One or more of the transistors,mosfets, was bad.
So I replaced the ignition module and also the coil pack since it had been subjected to high heat also. (I found a crack in the housing also)
And just for good measures I installed new plug wires and spark plugs.
After that the car ran great picked up more power (I had not noticed how much it had lost!) fuel mileage went up 3-5 MPG city/hwy. Wife was happy to have a dependable car and not worry if she was going to get there or back.
Its was an easy check to take the coil pack off it was 4 or 6 screws lift it up and look if the potting is missing or looks like it has flowed out you may just have found your problem. If you drive the car for a few miles then do the check I don't think you could touch it. If you could remove the coil pack the epoxy would be very soft or even liquid.
Hope this helps you.
Charles
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
05/19/2010 1:06 AM
stop using shell gas! If u are I dunno why but my guy that works at gm says the addative they use is bad for ur engine... fuel system, use chevron#1 or esso but not shell in a gm! Sounds like maybe o2 sensor? shell will kill that quick.
Anonymous Poster (4); bwire (2); Franksgarage (1); jamesw (1); metalSmiths (1); standarded (1); tcmtech (1)
You might be interested in: Automotive Services, Face Drivers
