Previous in Forum: Power Factor Correction and Gen Sets   Next in Forum: DC Wire in Metal Conduit
Cable Types
12/08/2009 6:40 AM
What is the difference between control cable, power cable, instrumentation cable & fiber optic cable?
Also posted in: also posted in Instrumentation
Good Answers: 266
Re: CABLES
12/08/2009 7:21 AM
It's designed around the purpose of it's use. Control cable to power controls, instrumentation cable for instruments and power cable to provide power. Even in these categories there are many to chose depending on power consumption of the devices(conductor size), their voltage(insulation properties) and stresses on the conductor under use(insulation properties and and stranding) will the conductor need to flex a multitude of times. Will out side forces disturb the signal(shielding).
Fiber optic cable is cable that carries a light signal not electric.
Re: CABLES
12/08/2009 7:27 AM
Thank u ozzb.
can u give the details of the cable, i.e. how the control cable controls the power? how the power cable provides power?
Re: CABLES
12/08/2009 7:46 AM
Neither of the cables provide or control anything. These are just current or signal carriers and used after calculation of the loads they're going to carry signal. That signal can be of any kind.
Good Answers: 266
Re: CABLES
12/08/2009 11:03 AM
The wires or cables are conduits in which electricity is ran between devices. It neither controls or provides the power. The electricity can be a signal communicating between the devices example a thermocouple to a temperature control. The electricity can be power for example motor starter(contactor) to a motor. The details are in the application which there are too many applications and types of wire.
If you need more information on the details of wire I suggest you google NEMA or NEC
Re: CABLES
12/08/2009 7:51 AM
Power cable does not control power - it transmits power.
Control cable- does not control, it is used for transmitting control signals...
The insulation, noise isolation (shielding), signal attenuation etc all are dependent on uses. Fibre optic is of course a bit different in the way it can be used as control/instrumentation cable.
BTW: Homework?
Re: CABLES
12/08/2009 7:58 AM
control cables are for controlling purposes; the voltage and current that these cables handle are low (24VDC or 125VAC). They are not designed to provide power for the final element. Thus, the insulation and short circuit withstanding capabilities are lower.
power cables provide power to the final element. the voltage can be up to 1000V (for LV systems) and the current can be in tens of amps. Insulation is important for these cables.
Instrument cables carry signals (4-20mA). They are usually 1.5mm2 and come in twisted pairs to minimize noise.
Re: Cable Types
12/09/2009 3:43 AM
The first three are based on metal conductors, usually copper. The fourth one isn't.
Register to Reply 7 comments
aman_2580 (1); Anonymous Poster (2); Jeba Keziah (1); ozzb (2); PWSlack (1)
