Previous in Forum: Derivation Required!!   Next in Forum: Earth Bond Tester
8 comments
Modeling Internal Circuits for Motors
01/11/2010 1:15 PM
Dear All,
I need an aid to learn how to model the DC and AC motor circuits and how to connect supply to each of them ?
Re: DC & AC Motors internal circuits
01/11/2010 1:23 PM
See stevem's response to other question.
01/11/2010 1:44 PM
Really!!!!!!!!!!!!!!!!!!!!!!!
Thanks You are all SOOOOOOOOOOO Supportive
I am sorry I thought it is the questions section>
01/11/2010 3:12 PM
Even the slightest bit of forward explaination would probably have gotten an answer for you.
BYE!
12/10/2012 5:22 PM
What is (or are) the best electrical AC/DC motor design Text book (s) out there?
Any help will be appreciated very much.
Ω Thanks Ω,
Ω
12/10/2012 5:43 PM
I found these by searching at Amazon.com , I do not know which is best one!
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dstripbooks&field-keywords=electrical+AC%2FDC+motor+design+Text+book+
Thanks
Good Answers: 40
12/10/2012 5:59 PM
Apologies if this sounds 'flippant', but, the answer to your question depends on MANY factors ... including, among other things, a) what is your comprehension level, and b) what do you expect to GET out of it?
See my (Post#5) below: both Robert Rosenberg's and John Hindmarsh's books are excellent, in my opinion. However, they are DRAMATICALLY different, in that they are written for different "Target_Readers" and intended to serve different purposes.
No single book is going to contain EVERYTHING that you want (or need) to know, in all likelihood.
Even if you tell everyone here exactly what your "starting-point" is, and what you intend to do with this knowledge, you aren't likely to get the single/best answer that you desire. I would suggest visiting a library first, and see what you can absorb ... and check "references" within those books that you manage to peruse.
Best wishes to you.
Good Answers: 29
01/11/2010 2:45 PM
Try Googling Ugly's Electrical References for easy to read info. Buy yourself one for about $20.
Good Answers: 40
Re: Modeling Internal Circuits for Motors
01/12/2010 9:12 AM
Appears that a "Link-or-two" might be worthy here, as the poster has joined the ranks rather than "Guest-ing" it here...
Admittedly, the question does seem a bit vague; do you have a specific need, or are you looking for a career at designing motors...?
I responded to a simple [CR4] connection problem here,
and gave a response to "motor rewinding course info" here.
Also replied to a dilemma of fire damaged motors here,
and addressed a question regarding specific-to rewinding here.
Throughout such discussions, I stand-by my "support" for this book (by Robert Rosenberg) which was the "bible" used by all personnel in numerous rewind shops (back when I worked in same)... for "learning the basics" only, of course.
even his "Second Edition" is still available.
Of course there are many others in this same category:
and, if you want the "innermost secrets", so-to-speak, read and study John Hindmarsh's Electrical Machines and Drive Systems (mine is an earlier version). There is way more to getting such designs right than meets-the-eye. "Sure", there is always more than one way to skin the cat (hope Del isn't reading!), and so, many different configurations might get a particular/specific job done. Especially if it is for a "One-of-a-kind" application...
However, for a mass-production run, many factors about the service environment, etc, must be considered as well, in order to produce the optimal design.
Wishing you the best ~
Register to Reply 8 comments
cbob12 (2); lyn (2); ndt-tom (2); RDGRNR (1); sarah kandil (1)
