Assuming standard conditions - Sea level, 68 F, 35 Relative Humidty.
I am working on a project which I need to know how long it will take to eqaulize pressure between two air receivers using 150 Feet of 4" diameter pipe assuming no additional air is being supplied. Air receiver #1 is 31,210 gallons and receiver #2 is 65,731 gallons.
Air receiver #1 is 175 PSIG and Air receiver #2 is 80 PSIG. How long will it take to equalize the pressure between these two tanks using the pipe fittings listed above.
Also if Air receiver #1 has 175 PSIG and Air receiver #2 has zero pressure. How long will it take to equalize the pressure between these two tanks using the pipe fittings above.
What is the formula I would use to compute these values? Also please illistrate one of the values by example.
Thanks for your asisstance.
