Previous in Forum: Vacuum Packing Machine for Semiconductors   Next in Forum: Markets for Carbon Steel Pipe
Black Anodising Problem
03/19/2010 2:59 AM
Recently i had done a Aluminium Gravity casting using Alu-LM25.
I took two samples from the same casting one i did Black Anodising and another sample with Clear chromate after maachining.
But the problem is in Black Anodising i found lot of white patches similarlly in Clear chromate i found lot of black spots.
When i asked the person who did the coating he said it happens because of the Silicon %.
Can any one please suggest me what i can do to get uniform coating inn Alu-lm25.
Re: Black Anodising Problem
03/19/2010 11:06 PM
I too had similar problem on 6061 aluminum. I was forced to change to black painting after CrO2 anodizing. You may, however, carryout trials using Sandoz dye stuff.
03/22/2010 2:35 AM
There can be several reason for your problem:
1-Most such problems come out from surface pretreatment. Your degreasing bath may be out of use. Try to change it.
2-If you are using silicon based mold realese agent again such problem can come out. Try not to use silicon based mold realease agent.
3-Your metal may contain too much silicate so after degreasing those silicates can come out. You can see if such thing happen after degreasing, try to dip them in to %1 max. nitric acid solution and wash them well before anodising.
4-wach out is there any oil drops on the surface of the passivation or anodising if there is try to clean them with a papper or change it.
I have not seen the problem so what I can say are those. Hope they help you to solve the problem.
Best Regards
Hasan
Good Answers: 94
03/22/2010 6:11 AM
LM25 won't take a good anodic coating because it has 6.5-7% silicon content to help it flow during the casting process.
Register to Reply 3 comments
arsan50 (1); krishnan.ng (1); Nigh (1)
