Previous in Forum: Motor Over Load & Winding Resistance   Next in Forum: PVC Glands
Neutral of single phase transformer
04/23/2010 1:01 PM
We are using a single phase transformer, 15 KVA, 480/120V. The primary is fed by line to line voltage. The transfomer will be using for lighting. In secondary side, which terminal is phase and which one neutral.
Good Answers: 53
Re: Neutral of single phase transformer
04/23/2010 1:07 PM
None, Neutral lies exactly at the center tap of transformer's secondary winding, which may not be accessible to you,
Good Answers: 244
04/23/2010 6:59 PM
You can connect one of the secondary terminals to ground and the grounded terminal is the neutral, other terminal is phase.
See the figure 15.11 in page 15.9 of this document.
http://www.mhprofessional.com/downloads/products/0071467890/0071467890_ch15.pdf
- MS
04/24/2010 12:16 AM
It means your transformer is not an isolation type. Connect anyone terminal with ground. Neutral is in case of center tap transformer.
04/24/2010 12:26 AM
It means your transformer is not an isolation type ?
MS is correct, no further addition was required. A single word was enough "Anyone"
Adding the information is to create an unnecessary confusion for OP, which we should avoid, considering the level of enquiry.
04/24/2010 2:39 PM
guest; masmad is correct, i would put a 125 amp fuse in the ungrounded line. perry
Anonymous Poster (2); msamad (1); rakesh_semwal (1); Signode (1)
