Previous in Forum: Battery connection   Next in Forum: Two 400hp motors failed to power an 800hp chipper and now they want to add......
Domestic Installation
04/30/2010 6:29 PM
What does the acronym TPN stand for? In domestic installation which comes first the TPN or the Distribution board?
Good Answers: 141
Re: Domestic Installation
04/30/2010 9:10 PM
Should be standing for: Triple Pole (or Phase) Neuter (or Neutral) linked Switch.
The main 3 phase switch, mainly for Star (Y) supply.
Where to put it depends on what you have in your Distribution board.
If you want to fuse it too It will be placed between your main disconnect breaker or fuses and your distribution panel.
In high voltage, these fuses are mostly part of the supplier.
A TPN there is your first component, when you don't count the fuses from the supplier.
Plenty of room here
Good Answers: 244
04/30/2010 9:54 PM
Type of breakers based on number of pole:
Based on the number of poles, the breakers are classified as
SP – Single Pole
SPN – Single Pole and Neutral
DP – Double pole
TP – Triple Pole
TPN – Triple Pole and Neutral
4P – Four Pole
The difference between TPN and 4P (or SPN and DP):
For TPN, protection applies to the current flow through only 3 poles; there is no protection for the current flow through the neutral pole. For the 4 pole breakers, protection applies to current flow through all poles. However when breaker trips or manually opened, all poles are disconnected.
Same type of difference also applies for SPN and DP.
Usage of TP, TPN and 4P in distribution panel:
For any distribution board, the protection system (either fuse and switch or breaker) must be used in the incomer. For a three phase distribution panel, either TP or TPN or 4P can be used as the incoming protection.
TP: It is most commonly used type in all ordinary cases.
TPN: It is generally used where there are dual sources of incomer to the panel (utility source and emergency generator source).
4P: It is used where is the possibility of high neutral current (due to unbalance loads and /or 3rd and multiple of 3rd harmonics current etc).
- MS
Good Answers: 141
04/30/2010 10:44 PM
Your explanation is very extended and useful. I used the word switch intentionally, because however they can both disconnect, the function of a breaker is not a switch and a switch is not a (fused) breaker.
Many countries require, besides a main breaker, also a main switch.
TP for delta, TPN for Y (or star) The connection between ground and neutral is in many countries not allowed. Therefore the N is also switched.
Plenty of room here
02/19/2022 8:25 PM
Register to Reply 4 comments
Anonymous Poster (1); dvmdsc (2); msamad (1)
