Previous in Forum: Flexible Joints   Next in Forum: Crude Oil Fired Generators
48 comments
Canada - Member - New Member
Good Answers: 39
Cockroaches
05/06/2010 3:48 PM
Maybe not a question for engineers but there seem to be so many people here that know something about everything I though i would give it a shot.
I am faced with trying to cleanse a 3 story 27 unit apartment building of cockroaches and bed bugs. The decision has to be made on a "most cost effective basis" and i am considering the 2 following options.
The age old spray-em-dead method with the use of all those nasty chemicals. This will require multiple applications and carries all the associated risks and inconviences. Keep in mind the building houses many children and pets. Or the newer method using heat. One company will heat the interior of the building to about 140 F for 4 hours and claims this is a much better solution. No need to move all the furniture, wash all the clothes and no residual poisons left around. Yes delicate and heat sensitive articles will have to be moved. This method requires only one application and of course has much better penetrating power, into walls, under floors, through ceilings etc. It is however MUCH more expensive. They cannot do the entire building at once however, only 4 or 5 units a day. They assure us however this will not cause a migration and ineffective kill.
Does anyone have experience with this heat method? Is it as good as claimed? Does it work well in a larger building such as I described? Any information would be appreciated.
All that is required for evil to succeed is for good men to do nothing.
Good Answers: 83
Re: Cockroaches
05/06/2010 4:07 PM
Eeeuuuuw.
The remedy I found to work best, when I lived in a region where roaches were so large they could carry off small children, was boric acid. Trays of the powder placed underneath footboards/inside baseboards (so kids 'n pets can't get at it) were pretty effective.
Dunno about the bedbug problem. Maybe the boric acid would work on them, too?
Good Answers: 39
Re: Cockroaches
05/06/2010 4:18 PM
I do not think you have quite grasped the problem. I have billions of them to kill.
This is just one example of what we discovered in a tenant's apartment.
We have since found several units are infested like this or worse.
Don't understand how anyone can live like this but that is another whole story.
Now I am tasked with de-bugging the whole building. My first step was evicting a few tenants.
Good Answers: 83
Re: Cockroaches
05/06/2010 4:27 PM
Surface to air missiles.
Good luck! eeeuwwwww
Good Answers: 213
Re: Cockroaches
05/06/2010 10:50 PM
A good dusting of boric acid will take care of this- followed by a good cleaning.
Re: Cockroaches
05/16/2010 4:18 PM
I live in a downtown high rise building and my apartment and many others have cockroach bed begs problem and pets. I would like to get some of this if their not in apartment there are walking on the floors or going up walls.
Good Answers: 213
Re: Cockroaches
05/06/2010 10:49 PM
Boric acid is safe for kids and pets and most other living things, and is very effective at eliminating cockroaches. My approach is to dust the entire area with boric acid, with special attention to cracks, areas under sinks and refrigerators, and other places the critters lerk. Boric acid apparently works by jamming up the joints in the exoskeleton. I do not know if it works for bed bugs...
Re: Cockroaches
05/07/2010 12:03 AM
Yes, works for bedbugs and many other bugs. I too had an apartment bldg and purchased a 25 pound bag from a chemical supply company.
The roaches and bedbugs walk thru the boric acid and it sticks to their feet. As they lick it off, it acts like glass in their stomach and rips the stomach apart.
Some landlords use a roller pin to make a powder. I have never done that but some claim it works faster and better. I simply use boric acid right out of the bag.
For home applications, you can get an 8 ounce bottle at your local grocery store or drug store or WalMarrt for a buck or two. It is a little over a dollar a pound in larger quantities
PEbobimm
Re: Cockroaches
05/07/2010 7:40 AM
Who's the imbecil who voted this off-topic?
Titi
Re: Cockroaches
05/06/2010 4:38 PM
I have no experience with this heating approach but frankly this seems bogus to me. Since all insects are cold blooded creatures, I would expect raising the temperature to only make them more active and thus easier for them to scamper out of a space that was too hot. Also since no residue remains, nothing will prevent their return. That being said, the best method I've heard of roach treatments though was meticulous thorough cleaning and making sure to limit their source of water.
Good Luck
Good Answers: 39
Re: Cockroaches
05/06/2010 4:58 PM
The system works, as seen on that exterminator show on TV and a bit of information here.
http://chppm-www.apgea.army.mil/documents/TG/TECHGUID/TG208Supp.pdf
I quote a bit of it here.
2-7. Cockroach Behavior During the Heating Process.
a. Within a relatively short period of time (30 to 60 minutes) after initiating the heating
process, cockroaches will start exiting their harborages as the metal in the equipment and/or
building structure begins to heat. At first their movement will appear to be somewhat erratic;
however, as the air temperature within the interior of the enclosure and solid surfaces becomes
hotter, a majority of the cockroach movement will be to the cooler regions of the floor.
b. As the metal surfaces of equipment reach 115ºF and above, personnel should start
noting cockroaches beginning to die on the exposed metal surfaces. At this time, those
cockroaches capable of escaping the increasingly hotter harborages will seek refuge on the floor
in the more protected corners of the area, underneath larger equipment, and at the junction
between the plastic sheeting and floor. Cockroaches are capable of detecting relatively small
differences in temperature and air movement and will seek the least hostile environment. With
experience, pest control personnel will be able to anticipate the most likely areas for cockroaches
to congregate.
c. It is recommended that at various intervals throughout the heating process the pockets
of cockroaches should be vacuumed up and eliminated from the area being treated.
I can find lots of ads on line but not much technical info.
Good Answers: 146
Re: Cockroaches
05/06/2010 7:34 PM
I don't know about this heat treatment - never heard of it.
The cockroach is a tropical beast. The scrawny variety that sometimes inhabits northern buildings is not at all winterproof. This I know. So a freezing treatment on the whole building would be expected to work. Such as, getting everyone to leave for a week in January, and turning all the heat off, and then sending in a cleaning crew. Don't know if this would work for bedbugs as well. But some combination of freezing and cleaning is your best bet for an actual extermination, as opposed to a temporary reprieve.
If it's warm enough for them to survive out, they will leave and return when the heat is done. The claim that heating 4-5 units a day will not cause a migration is crazy. I don't see how they can stop them from migrating - you as much as said that they are expected to congregate where conditions are more favourable and in this case, it's outside the 4-5 units in question, so..... Roaches go everywhere in a building, they spread from one apartment to another up down or sideways. A partial and stepwise approach is just not going to work.
From the pictures you showed, it seems like hell to live in this building. Complete extermination is very difficult to achieve. Maybe it would be best for the owner to torch it and rebuild.
incus opella
Location: West Point, Texas population around 200.Located between Austin and Houston
Re: Cockroaches
05/06/2010 9:12 PM
They live in cedar trees.
Starting on top floor,kill everything,moving at a timed interval for each floor,while at the same time keep Killing power on two-three floors,moving down,,,,,finally remove any access points to structure,barrier EVERYWHERE the structure comes into contact to Mother Earth,,no trees brushing bldg,,no vines,no contact to another structure that touches earth,,I would use those Roach bombs one per room/apt(read directions),,,in fact the directions will tell you how long to air out before occupancy,,finally the barrier to earth.......I used a half Gallon of a chemical called Chlordane,high percentage.Last around 10-12 years,,here in central,rural,Texas,,LOTS of cedar trees also
Joe in Texas
We hold these truths to be self evident,one nation under God
Re: Cockroaches
05/07/2010 12:56 PM
If you will do a search on Chlordane you will find it is a potent carcinogen and is stroed by the body. It has a half life of something like 45 years so it takes a long time to go away. Oh an one other minor detail. IT IS ILLEGAL AND HAS BEEN SINCE 1988!
Good Answers: 39
Re: Cockroaches
05/07/2010 1:01 PM
Ah, thanks for that lil tidbit of info. Kind of handy to know.
Good Answers: 130
Re: Cockroaches
05/11/2010 5:51 AM
Chlordane is so banned!
Though I admit my father splashed it everywhere, but even so, not a good idea.
Good Answers: 145
Re: Cockroaches
05/06/2010 9:03 PM
Roaches are pernicious things, they are reputed to be the only living creature that can survive a nuclear strike. That said they do bleed and if it bleeds you can kill it...
Cockroaches will infest any and all voids within a building which makes them difficult to eradicate in larger building complexes. To be effective it must be a whole of building assault. It won't be cheap, but the tenants will need to appreciate that they contributed to the problem.
Its not just the cockroaches you can see but the eggs which will hatch and release more cockroaches afterwards.
With a severe infestation that you have, your going to have to get the Tenants involved and educated.
First, Clean up everything! Organise a large skip bin to give the tenants an opportunity to throw out all the crap that's harbouring the vermin. Might need a couple of skip bins. Bedding and mattresses will harbour all sorts of critters including bed bugs
Second, arrange to move all the tennants (and pets)out for the weekend so the building can be sealed and fumigated. Make sure all the cupboards and closets and doors that lead into hall ways are open to allow maximum effect for fumigation. Open the hatches to crawl spaces and any service cupboards that are internal to the building to provide the best propogation for the fumigation.
Third, turn the services off. That includes Electricity, Gas mains and water. Also disconnect the phones from all the apartments, don't want a random phone call to blow the joint up..
Fourth, Once the fumigation process is finished and the building has been certified fit for habitation, then your going to have to be a bit hard on the tenants to ensure they don't turn it into a shitpit again. Regular inspections and setting roach traps around the common areas of the building will allow you to monitor your success or otherwise.
You will never rid the building of every last cockroach but with appropriate management you can keep them down to a dull roar.
As for the heat method, it mght be effective in an average suburban home but not in a block of units as the roaches will migrate inside the walls away from the heat. They will also move around in the drainage system. They are an ultimate survivor, which is why they are so successfull at conquering their chosen environment.
The upshot is, its going to cost real money to do properly. It will inconvenience all the tenants some more than others. You will not have an absolute result, but a mangeable one.
Re: Cockroaches
05/13/2010 3:47 AM
Still sounds like an appropriate adjective for a roach.
Re: Cockroaches
05/06/2010 9:10 PM
Dip them in the finest tempura batter you can find, deep fry to a golden brown, rename them as slum-dog shrimp, and enjoy! As Euell Gibbons used to say for wild foraging, some parts are edible.
Good Answers: 266
Re: Cockroaches
05/13/2010 7:28 AM
I was think more like chocolate covered.
Re: Cockroaches
05/06/2010 10:06 PM
3 Story 27 apartment building - whole complex maintaining at 140oF (60oC) for 4 hours. Do you think it will be practical ?
I really don't see really a practical non toxic method of controlling them except this or may be as a previous post says if you can not beat them, eat them (They are supposed to be very high in protein and tasty when deep fried, You can consult Bear Grylls, he is an expert in all these)
In fact the traps (even if it is for millions) may be better since after they are killed (whatever method) you have to retrieve their deadbodies. in case of the heat method, they may try to go out of the way and rest in the coolest place around. At least a couple of million of them, then it will be difficult to take them out.
Good Answers: 18
Re: Cockroaches
05/06/2010 11:39 PM
If you turn everything off ... make SURE that your water lines are ALL empty in winter, or do it when temperatures aren't sub-freezing.
There's no way to burst a whole lotta piping than to shut off water pipes with water still in them. I victimized myself once when I seaed the heating vent to my garage once. The one pipe in there didn't survive a day.
Cheers! DZ
Do unto others. Then run.
Re: Cockroaches
05/06/2010 11:43 PM
Long ago I decided to create my own low cost vermin killer... It must be effective?.. I haven't mixed a batch in 10+ years!
Mix about 50 to 100 parts of boric acid with one part table sugar. ...that's it.
About two to three days after 'squirting' this mix into the tight areas behind.. everything.. everything is dead.
all the creatures love the sugar.. ant's.. whatever.. it makes a perfect bait for the acid making complete coverage less needed.. get it?
..I'd tackle the roaches for a couple go rounds.. some bombs in some places and acid in others. start today.. thin them out little by little. Don't worry about a total kill in one day. When you get things under control and cleaned up. THEN see what you have left in terms of bed bugs and treat these areas separately and as thoroughly as you can.. some stuff might need to hit the trash.
Re: Cockroaches
05/06/2010 11:48 PM
Two ways.
1. Many years ago, the local ALCOA mfg plant was swamped witgh them. They imported giant cockroaches from South America, and we were not allowed to kill the giant cockroaches because they got rid of the normal cockroaches, but it took a couple of months because if you get rid of all them today, tomorrow more will hatch from the eggs.
2. I owned an apartment bldg that was infested with them. I had an exterminator come every 2 weeks for 3 or 4 months, and kept losing ground. Then, I purchased a 25 pound container of boric acud and put it everywhere, under rugs, stoves, refrigerators, basement rafter, attic rafters and floors, etc. It took about 4 months, but I won the battle. I think most of the boric acid is still there. The boric acid was one tenth of one percent as costly as the extermintor and his spray, and 50 times more effective. It is the egg hatching that causes the time period.
If you do not have roaches, it is a good preventive measure. Some landlords use a roller pin to make a boric acid dust, I did not, I used it right out of the bag. 25 pounds goes a long, long way
The roaches step in it and lick it off. The boric acid is like glass to them, and rips their stomachs open.
PEbobimm
Re: Cockroaches
05/07/2010 12:35 AM
Actually you have three problems; cockroaches, bedbugs and tenants. About 20 years ago I bought a small 6 unit rental property in Georgia (USA) that was overrun with cockroaches. The tenants weren't taking their garbage out on a regular basis, the place was a pig sty of food scraps and dirty plates, etc. I kicked out ALL of the tenants and then spent six weeks of spraying in every nook and cranny for roaches. After six weeks I was roach and tenant free - - also my pocket book had taken a pretty good hit. I then brought in tenants whom I carefully screened. I also instituted two iron clad rules that if violated were grounds for eviction. One was that the garbage had to be taken out every evening to a nearby dumpster. If you eliminate the food source you eliminate a lot of your problem. The other was that I had the right to unannounced spot checks to see that rule number one was being observed. When I sold the property three years later we were still roach free. I kicked out two tenants during that period who had a problem realizing that taking the garbage out was important to keeping a reasonable lease in force. As to your bedbugs - - I've never been faced with that problem. From what I've read you're going to have to get rid of the mattresses as the bugs will migrate to the area between the box springs and the mattress if you start trying to kill them. They are parasites that litterally suck blood from there victims. I'd toss the mattresses.
I also agree 100% with Redfred. I think the heat treatment is a scam. At least in a building the size you have it is not going to work as the critters will simply migrate to a cool place somewhere else in the building. Good luck; but remember, if you don't change the tenants and their level of understanding that bugs don't congregate if they can't eat; then you're never going to solve the problem. Whichever tenant had the sink full of dirty dishes shown in your picture would be my poster child for evicted tenants.
vagabond
Good Answers: 58
Re: Cockroaches
05/07/2010 7:37 AM
To some species of lizards, roaches are a delicacy. Let some lizards loose in the building. They usually get along well with pets. After the roaches are gone, you can donate the well fed lizards to the local zoo.
Re: Cockroaches
05/07/2010 9:31 AM
Bedbugs do not respond to bait. They Like DDT. This is a tenacious pest and difficult to control in apartments and hotels. I would recommend the use of dogs trained to locate the pest, so you don't have to treat everything. The department of defense and other sources claim 46-49 Celsius 20-30% humidity for 20 minutes will kill bed bugs. Dry (hot) steam seems to kill on contact.
Neem oil is an excellent low-toxicity insecticide/repellent (watch Billy the Exterminator on A&E). Diatomaceous earth is probably the best, safest product to kill insects.
Visible roaches can be squirted with Neem oil (mixed with detergent and water). Hidden roaches are best killed with bait gel. Use lots of it. It is usually composed of Boric acid and/or Diatomaceous earth mixed with a sweetener. Keep the premises clean.
http://en.wikipedia.org/wiki/Boric_acid#Insecticidal
http://en.wikipedia.org/wiki/Diatomaceous_earth#Pest_control
http://en.wikipedia.org/wiki/Eucalyptus_oil#Repellent_and_biopesticide
I searched ebay "neem oil 1 gallon" by price: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=360089489125&rvr_id=&crlp=1_263602_263622&UA=L*%3F%3F&GUID=358d429f1260a0aad4a1c871fe566be3&itemid=360089489125&ff4=263602_263622
avid0g
Good Answers: 123
Re: Cockroaches
05/07/2010 9:49 AM
I have also heard of using the sugar as bait mixed with the boric acid. I also know that you will have to deal with the 1% that survive and breed for a few generations. But this should save you enough money by doing this to allow you to purchase a replacement mattress for the tenants and charge them 1/2 price and make you look lake the good guy. THAT will help the tenants want to work with you. One tenant that thinks they want to get even with you can spill a 12 oz bottle of soda in a stairwell and set you back 6 months. Good luck.
IMHO there are too many areas that you will not be able to get hot enough to kill a very high percentage of the breeding population. Areas such as the electrical outlets in the walls, and assess holes for pipe runs will provide many cool areas for roaches to hide.
Bob
Good Answers: 114
Re: Cockroaches
05/07/2010 1:02 PM
Boric acid in a liquid
works on ants
observe what food the insects in question prefer, add to a solution with as much boric acid will stay in suspension.
successive generations some times switch food sources
Good Answers: 39
Re: Cockroaches
05/07/2010 10:08 AM
Thanks all.
Some interesting information here to digest and I'm beginning to think the heat treatment may not be my answer in a building this size.
We have definately decided that the tenants are the first problem. This is a condominium where the owners have rented their units out. In Alberta the condominium laws outrank the landlord tenant laws which is good for us. As the condo board we basically have unlimited power to evict tenants. Luckily no condo owners live like the people responsible for those pictures. The tenants who lived in the unit pictures are already gone and we are scheduling inspections of every unit in the next week or so. I will be armed with preprinted eviction notices and a camera.
Thinking now that first clean out the tenants. Then clean up the building. Then begin a long term repeated chemical attack and spread either the boric acid or diatomaceous (spelling?) earth all around. The earth scratches their exoskeleton causing them to dehydrate and die and it is entirely non-toxic to pets or kids.
Thanks again for your input
Good Answers: 123
Re: Cockroaches
05/07/2010 10:17 AM
How will evicting tenants effect the income for the building? Perhaps it would be better to do an aggressive approach to the currently vacant units, and work on compliance from the occupied units.
Bob
Good Answers: 39
Re: Cockroaches
05/07/2010 10:26 AM
Well to be honest that is not really my concern. The Condo Board has been ordered by the health department to "clean up the problem" so complying with that order is our primary concern. In order to clean up and keep the place cleaned up, tenants who live in conditions we have seen will make the second part of that impossible. Keeping your residence in conditions like that are a violation of our health laws as well as the condominium laws and our buildings bylaws.
The owners who rent out their units actually want to sell them, so it is in their best long term interests to take a hit in the pocketbook now and make their units saleable.
Now how do I put this delicately? The tenants who are responsible for conditions like those pictures are ummmmm "of a culture" that finds nothing wrong with living with a few six legged friends. Time to move-em-out and bring in a new population of properly screened and referenced tenants.
Re: Cockroaches
06/04/2010 10:17 AM
"...beginning to think the heat treatment may not be my answer in a building this size."
You can certainly use the heat treatment on the mattresses and sofas of existing tenants. (Place item in treatment bag.) This eliminates the use of chemicals to treat a surface that the tenant is in continuous contact with 1/3 of their life. The balance of bedbug infestation can be treated chemically.
Bedbug infestations have little to do cleanliness or tenant hygiene.
avid0g
Re: Cockroaches
05/07/2010 11:36 AM
Hi Apothicus,
If you have some statistics about the survived/killed when you apply the "heating system", it will be appreciated. Boric acid works close to 100% when applied all around the apartment or house. Let us know, Gil.
Re: Cockroaches
05/07/2010 11:53 AM
OK. Every thread can stand some off the wall info., right?
I learned about this many years ago in a book (now out of print) called "On the Frontiers of Science", by G. Harry Stine. The book subtitle is: Strange Machines You Can Build. There is a chapter about a "Wishing Machine". I recall that the U.S. Agricultural Dept. experimented with this -- or some Federal people -- to do precisely that. At any rate you can read an interesting interview with the inventor of one of the machines -- the Hieronymus Machine -- here. (the last paragraph in the interview refers to a similar incident as to the one I'm referring.)
Enjoy, criticize, flame the info., but don't dismiss it out of hand.
Re: Cockroaches
05/07/2010 11:57 AM
Ah, what does the mumbo jumbo of psionics and sympathetic vibrations have to do with cockroaches and bed bugs?
Re: Cockroaches
05/07/2010 1:16 PM
I tried to spare anyone who had an adverse reaction to this the trouble of reading the whole interview. The last paragraph is about ridding a tree of worms. Worm... cockroaches... critters, no?
Re: Cockroaches
05/07/2010 1:19 PM
As I said, don't dismiss it out of hand. Or have you perhaps built some "radionics" devices, tested them and found nothing of interest that might induce one to further investigations. True scientists will at least go through the steps of testing others experiments before declaring them hogwash.
Good Answers: 39
Re: Cockroaches
05/07/2010 1:23 PM
True scientists usually sign their names to their work too.
Re: Cockroaches
05/07/2010 1:34 PM
He did. T. Galen Hieronymus. Also see John W. Campbell., G. Harry Stine (look for the book it is still available used.)
All you are doing is proving the point made in the first few paragraphs of the cited interview about the narrow-mindedness of so-called scientists. If you are referring to me, meaning I posted as Guest, that has little to do with the subject and info. referred to. I haven't done the experiments (i.e., built any of these devices and tested them) so my authorship is moot, but obviously neither have you built or tested any of these ideas. Don't criticize something that other people say "works" until you've tried it yourself. Besides, the interview makes clear that Hieronymus realizes that "machines" and "devices" aren't really necessary. It really does boil down to possible capabilities of human beings that they don't even know they possess.
Some people have tried this and found reasons to investigate it further. Either way they will go along their merry way as will you and probably never the twain will meet.
Re: Cockroaches
05/07/2010 1:53 PM
Couldn't help notice your sig. How very true. A corollary may be: "All that is required for ignorance to succeed is for intelligent men to do nothing."
I somewhat posted the interview link with a light-hearted intent. Your problem seemed so massive, this just came to mind when reading it. No offense meant.
Re: Cockroaches
05/07/2010 2:02 PM
If this thread and forum was about possible avenues of research, then I can see your point that unproven techniques should be explored for any endeavor. But this forum is an Engineering forum. Engineering works hand in hand with scientific work in two ways. First, Engineers design and build the machines that permit scientific research. In building these machines an Engineer must be capable of providing all pertinent precision and reliability information to validate the information provided by that machine. Second, the proven scientific theory and methods discovered by these machines now provide the tools that an Engineer uses to build machines for all who desire a new machine.
So while this maybe very useful research that may one day help somebody with an insect infestation, it is certainly not an approved method today.
Re: Cockroaches
05/07/2010 4:06 PM
Agreed... to a point. As I said, I' posted in a half-serious manner. Apothicus painted a large infestation, with a somewhat desparate plea. From the cited interview:
"J. G.: I understand that when Campbell was editor of Astounding you were approached by the military. What happened?
Hieronymus: The reason I got into that was that the Air Force became interested and sent a couple of high-ranking officers to my place in Hollywood, Florida. They knew almost nothing about psionics or radionics, but we did some biological experiments for them that they found interesting. But they wanted something more factual and substantial. I said..."
You stated: First, Engineers design and build the machines that permit scientific research. In building these machines an Engineer must be capable of providing all pertinent precision and reliability information to validate the information provided by that machine. Second, the proven scientific theory and methods discovered by these machines now provide the tools that an Engineer uses to build machines for all who desire a new machine.
With all due respect, this is what Mr. Hieronymus had done for some 30+ years... as well as others. The so-called "machine" is real hardware, can be built and tested. It is said to work for many who have. The "why" is where the research part comes in.
The results to be verified are in the last paragraph of the interview, in the book mentioned and in threads in forums on the Web. Untested in this instance really just means most people refuse to try it, therefore there is a very small sample of people who have and by definition it remains "unproven" -- to the majority who didn't try it. For anyone in some third world country out in the boondocks, who can't buy the latest sprayable insecticide, stories of it's success at erradicating pests would sound no different.
I don't want to belabor this any more than you but the status of these "machines" should be made clear. Because the human mind is part of their operation, it necessarily becomes more vague than hard, cut and dried science. From my reading, modern physics has shown the interdependence of the observed and the observer. Similar conclusion.
Please, everybody, just ignore this if it makes you angry. But some few who read this may indeed take a peek and even go to the trouble to "test" it in some fashion.
In the end, Apothicus is the one who has the problem of getting rid of the buggers.
Re: Cockroaches
05/07/2010 6:11 PM
... couldn't resist one more mention. It's been decades since I read the aforementioned book. I remembered another book, which is still in print, entitled, The Secret Life of Plants. I went and checked it out from the university library ( I work at a univ.) To my amazement, chapter 19 is titled, Radionic Pesticides! I just started reading it and would invited any interested readers to check this book out.
O.K. Over and out.
Good Answers: 39
Re: Cockroaches
05/07/2010 1:20 PM
Anyone have any idea the costs to tent and fumigate a building? I'm currently reading some sucess stories about Vikane. Usually used to treat bedbug infestations (which we have also) but it says it kills roches too.
Good Answers: 213
Re: Cockroaches
05/07/2010 5:47 PM
I have never had to mix boric acid with anything. I first discovered it as a valuable insecticide while living in Texas with a number of dogs- after trying all the conventional methods (bombs, dips, spray the yard, some insecticides of questionable legality that were available from across the border, etc.), someone finally told me to sprinkle the carpet with boric acid, and don't vacuum for a couple of weeks. Fleas gone. Never to return. Apparently, the new hatchlings could not survive with boric acid around. Later, problem on my sail boat (not a whole lot to eat on my sail boat, but lots and lots of roaches). Boric acid dusted all over the boat. No more roaches for a couple of years. First roach I saw, more boric acid. No more problems. Since then, I have moved in to a couple of different appartments- all apartments are infested with cockroaches. Before moving my belongings in, dust the place with boric acid. Straight. No sugar, no liquid, nothing but boric acid (well, the stuff I buy is 99.8% boric acid, balance inert material, about $2.00 for a container about the size of a liter bottle). Well, a few months ago, I suddenly had a strange invasion- day time, disoriented roaches- big ones, not usually found in a residence. And lots of them. Out with the boric acid- no help. About four or five days after the invasion started, we had a significant earthqake. After the earthquake, no more roaches...I don't know for sure if this is a new way to predict earthquakes or not, but I have heard that the Japanese keep roaches in cages to predict earthquakes...
Anyway, you do not have to mix boric acid with anything- it does the job, and a whole lot cheaper than more obnoxious chemicals or heat treatment or whatever. In my experience, it has been quick. There does not appear to be a problem with roaches migrating next door because of exposure to boric acid.
I have not had the same results with ants. Maybe if I mixed it with sugar, it would work with ants. My solution for ants is fresh ground black pepper. Drives them nuts, they never return. I don't know if fresh ground pepper would work with roaches or bed bugs. I suspect, knowing how boric acid works, it might be effective against bed bugs- but you have to dust the mattress, the bed springs, and any other surfaces they might inhabit to be effective...
Good Answers: 128
Re: Cockroaches
05/07/2010 11:35 PM
Friends,
Seems the majority all support boric acid. Interesting stuff--also a very good wood preservative and fire preventive chemical when wood gets impregnated with the stuff. (No rot, no mold, no mildew, no insects.)
I add one suggestion: Take time to be tedious about sealing holes and cracks, such as wherever a cabinet meets the wall, inside and outside of every cabinet, etc. They like to hide and when I have sealed all the cracks in a building, the roach problem is generally gone also. This will require a large amount of caulk and a lot of care to apply it in a way that is not ugly.
I toss out one "off the wall" idea: If tenting the building and fumigating it with a poison is an effective method, what about possibly tenting it and filling it with carbon dioxide. This will dissipate in air and is non-toxic in the normal concentrations we breathe. It is a naturally occurring chemical. I have no data, but I suspect that insect infestations will be killed by even 15-30 minutes of this treatment, both roaches and bedbugs.
--JMM
Re: Cockroaches
05/08/2010 4:13 AM
That includes tenenta too .
Re: Cockroaches
05/08/2010 12:43 PM
Purchase food grade Diatomaceous sprinkle were ever you see trails that roaches as for bed bugs you will have to sprinkle between mattress . Hope you have luck . Jerry
Register to Reply 48 comments
34point5 (1); Anonymous Poster (16); Apothicus (7); artsmith (1); avid0g (2); bob c (2); cwarner7_11 (3); DreadZontar (1); Garthh (1); JE in Chicago (1); jmueller (1); Judge (1); ozzb (1); redfred (4); sue (2); Tobugrynbak (1); Tornado (1); vagabond (1); welderman (1)
