Previous in Forum: Effect of Bridge Between Electricity Current Supply and Supply from a Mains   Next in Forum: Regarding Job
26 comments
make nuts
06/02/2010 1:35 PM
can you tell me how to make nuts or say other way that how many processes we need to operate for making nuts?
thanks you
Re: make nuts
06/02/2010 1:48 PM
Nuts as in nut and bolt, or nuts as in walnuts, pecans and pistachios?
Re: make nuts
06/03/2010 12:59 AM
NUt here is nuts and bolts
thank so much
Re: make nuts
06/02/2010 1:51 PM
First you start an open-access engineering forumn. And then you wait. They'll come along shortly.
Good Answers: 46
Re: make nuts
06/02/2010 1:57 PM
Or the nuts that post here?
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Good Answers: 183
Re: make nuts
06/03/2010 8:22 AM
1- you overstress a human being till he/she goes nuts. This is the first and basic technology
2- you drill a hole according to the indications for the thread you want to cut then you use a tool with a thread profile designed for threads cutting and you turn it. It is possible to do it in one step or in several steps with different tools usually 3 tools are used for good results.
3- you use a lathe to drill the hole and cut the thread with radial advance
4- for big threads it is possible to mill or grind the thread with a special tool having a planetary movement. Advantage the full depth is cut in one passage. This technology is more adapted to threaded holes from 6mm up.
But best of all you try to find a book on manufacturing and study the process and the tools.
Re: make nuts
06/03/2010 9:39 AM
First, I want to thank for help.
But because of nuts production so I can not use the way that you suggested.
Here I use cold forging to do nuts and produce with the number of quntity very much of products, then I need a method which can produce them very quick and precision high.
If can, you can give me the picture or nut drawing files.
Thanks so much
Good Answers: 183
Re: make nuts
06/03/2010 9:54 AM
1- what you ask for is know how transfer and it is not to be done for free!
2- if you make the slightest effort to look in a book you find on your own the information at least enough to start a series of tests till you get the optimal parameters for your production quality.
3- When you formulate a question you should give all input in your OP no quantity was mentioned, no nut quality was mentioned, no indication about the parts to be cut was given, so do not expect to get a good answer to a partial demand.
If you are willing to pay use the private channel and you get the information if not then you have to obtain it on your own.
It is a HUGE difference between giving a hint or a counsel for solving a problem and give manufacturing informations to be used to make money.
I was confronted not long ago with same problem somebody who wanted a complete design check for a project ONLY drawn without any computations for a many 100.000$ project for free.
As much as I am willing to help a person in need I am not at all ready to help a Company making money or somebody build up a stature he/she does not deserve based on own knowledge for nothing.
Re: make nuts
06/03/2010 9:30 AM
I am really to thanks for your help. But it will be better if you can give me more exactly picture or major document.
Thanks so much
Good Answers: 60
Re: make nuts
06/03/2010 10:19 AM
why cant you search the links ive provided, ? i dont know what your looking for
the size the thread type fine coarse whitworth metric unified unc unf what ?
Good Answers: 46
Re: make nuts
06/04/2010 2:21 AM
Peter, Don't go NUT's on us! It would be easier if the OP gave a little more info like what you have asked. Sometimes they make you just nutty!
Charles
Re: make nuts
06/04/2010 10:51 AM
peter, your avatar looks great.........you get a hair cut, lose weight or something?
Good Answers: 60
Re: make nuts
06/04/2010 12:21 PM
Lost weight lost hair re sprayed yellow thanks for the comment
Good Answers: 183
Re: make nuts
06/04/2010 12:46 PM
You look as a summer day at noon, full sun, warm and pleasant!
Good Answers: 60
Re: make nuts
06/04/2010 2:34 PM
Ahh Thanks.
Good Answers: 183
Re: make nuts
06/04/2010 1:54 PM
Hi,
I had a look at the provided link and I understood why it was for the OP not what he wanted.
I presume he wants to have informations for cutting the thread for big nut series since although cold forming is a well known technology the thread cutting is less known.
In the thread offer I did not find any (may be I did not see it) indication about this part of the process.
In fact he looked but did not find what he expected.
Good Answers: 60
Re: make nuts
06/05/2010 10:18 AM
i appreciate you comment, But if you understand where i am going wrong, Perhaps you could provide a more suitable link ?
Good Answers: 183
Re: make nuts
06/05/2010 10:33 AM
I could give the indications how the tools and technology are but as mentioned in a previous comment : if I am willing to help for free somebody I am not willing to help for free somebody making money of my counsels.
For earning money one has to invest himself and not only rely on external help or pay for it.
What he asks for is know-how transfer for free nobody would make this. We are not so rich to make this without any benefit even symbolic.
From an other point of view you do fine, the engine does not understand what has to be searched.
Re: make nuts
06/05/2010 11:03 AM
It's really shy of it when I get your help. But now I am a student and I am researching for nut production process. If you are good enough for help me. Please give me some suggest. Here it is not benefit from your help
thanks you
Good Answers: 101
Re: make nuts
06/03/2010 9:54 AM
  1. Buy seeds of desired species of nuts.
  2. Plant seeds in fertile soil and sunny location.
  3. Water and fertilize growing plants regularly.
  4. Wait for plants to flower.
  5. Wait for flowers to be fertilized.
  6. Wait for seedpods to mature, then harvest nuts.
Wait a minute, why am I telling you all these? You should be writing in to a farmers' forum instead.
Good Answers: 183
Re: make nuts
06/05/2010 6:39 AM
I am sorry to make again a comment but a "thread cutting nut" is NOT a procedure to cut threads in nuts it is a nut able to cut the thread on a cylindrical piece of material.
The problem with research engines is that they are "stupid" and cannot understand hidden aspects. I had many times difficulties to find exactly what I needed due to theit peculiar "logics".
As mentioned above for big series there are special procedures which as far as I saw are not presented.
Good Answers: 60
Re: make nuts
06/04/2010 4:19 PM
Re: make nuts
06/05/2010 10:13 AM
So can you give other suggestion or other method for making nut. At here I don't mention to cutting thread. Only make nut's shape without cut thread.
Thanks you so much
Reply to Forum Thread 26 comments
Anonymous Poster (1); DVader1000 (1); metalSmiths (2); nick name (6); peterg7lyq (9); phoenix911 (2); thaihong2007 (5)
You might be interested in: Nuts, Eye Nuts, Way Covers and Shields
