Previous in Forum: Cement KILN Taking High Current   Next in Forum: 3 Phase Air Compressor
15 comments
limit switch
06/05/2010 12:51 PM
dear sir, please send the function of limit switch and working
India - Member - New Member
Good Answers: 164
Re: limit switch
06/05/2010 1:01 PM
Please read what is available on this link : http://www.globalspec.com/industrial-directory/limit_switch
After this, if you need any more information, please ...
  • Register on CR4, it is free. It is of great help. This is a wonderful forum.
  • Then ask your question.
Good Answers: 164
Re: limit switch
06/05/2010 1:20 PM
i apologise. you have already registered, i have been seeing so many 'guests' that i shot off without thinking.
Re: limit switch
06/05/2010 1:10 PM
how to this limit switch
Good Answers: 164
Re: limit switch
06/05/2010 1:15 PM
i am afraid i do not follow what you mean?
Please take the cursor to the BLUE weblink i have given. It will assume the shape of a hand. Click left mouse button. A webpage will open. It will tell you all about limit switch.
Let me know if you can't find anything.
Re: limit switch
06/05/2010 1:35 PM
I'm sorry, but this "question" is very poorly formulated.
In general terms, a limit switch consists of some electrical contacts enclosed in a housing. Some sort of mechanical linkage (lever, push rod, "wobble stick," etc.) extends outside the housing. When an object presses on this lever (or whatever), it turns the switch on or off, just like a finger on a light switch.
Limit switches are used to detect the presence or position of a moving object, and then to initiate a suitable action. For example, on an automatic door opener, a person might push a button that starts a motor to openthe door. When the door reaches the fully open position, it can contact a limit switch that turns the motor off (so that the door doesn't go too far).
Re: limit switch
06/05/2010 2:44 PM
How about a little more truculence, or at least some vitriol.
Re: limit switch
06/05/2010 4:30 PM
Okay, how about a jug of Cu2SO4?
(Ordinarily I would mark this OT, but as the topic has changed momentarily....)
Re: limit switch
06/05/2010 2:13 PM
Tornado has described a mechanical limit switch, as I have shown above.
There are optical, electronic, magnetic, capacitive and other types of limit switches, too.
Re: limit switch
06/05/2010 6:34 PM
I'm home now, and will be for the rest of the evening. So I've now officially switched the limit that I will drink. Whoopee!!
Re: limit switch
06/06/2010 1:41 AM
A limit switch is generally a 3 phase powered Motor and same function of transformer. Some times it functioning like Flouresent lamps and popcorn fryer.
Re: limit switch
06/06/2010 8:14 AM
The only thing that is correct about this answer, is that the sentence structure is grammatically correct. It does not make sense though. Any switch is not a 3 phase motor. Neither a motor or a switch function like a transformer, fluorescent lamp or popcorn fryer.
Now all of these electrical loads; motor, fluorescent lamp, popcorn fryer, and the transitional load of a transformer may have a switch to turn ON/OFF the load. On all of these devices there may also be a thermal limit switch that will turn OFF that device when it gets to hot to prevent a fire.
Now why this guest's nonsensical reply is the only one with a GA vote eludes me.
Re: limit switch
06/06/2010 8:30 AM
"the only one with a GA vote."
Not any more.
Re: limit switch
06/06/2010 9:12 AM
Can't believe TWO Americans didn't get the joke ! Oh, that was not by me...I'm just passing by...
Re: limit switch
06/06/2010 8:42 AM
It is tongue-in-cheek. a joke, in keeping with the iq level of the op .. comprende?
Good Answers: 18
Re: limit switch
06/06/2010 7:03 AM
Simple. Limit switch is for limiting something like the movement of an elevator or the pressure build-up of a compressed-air tank. Working is for getting something done, occasionally to earn money.
Register to Reply 15 comments
Anonymous Poster (3); Bill (1); jvsnlchari (1); kvsridhar (3); lyn (3); redfred (2); Tornado (2)
You might be interested in: Limit Switches, Switch Boots
