Previous in Forum: 1998 XJ8L Jaguar   Next in Forum: Homebuilt Hotrod for the Working Man
32 comments
HHO geneators??
06/23/2010 5:39 PM
I have spent the last several years following up on HHO generator forums and websites about alternate forms of energy to help power vehicles and improve fuel economy.
I have been experimenting on the different designs and most that are sold were only producing about 1-2 liters a minute on a 12 volt design.
Mine is a 24 volt design and I even incorporated a 24 volt alternator in addition to my vehicles 12 volt alternator to power the unit individually.
I am getting approximately 4-5 liters a minute at idle with the alternator putting out about 25 volts but at 1400-1500 rpm when the charging voltage increases to 27.4 volts my dual cells are producing 6-7 liters a minute off Hydrogen/Oxygen gas.
Some people on the thread I was reading were saying that these were only creating steam which is far from the truth.
If I capture 20 ounces in a coke bottle and hold it upside down on a base platform and light the gas from the bottle opening it will ignite and shoot the bottle like a rocket 30-40 feet in the air.
It is not just steam.
I am currently looking into buying an O2 sensor manipulator to fool my ecu into leaning the engines fuel injection down to conserve the fuel while supplimenting the HHO gas into the intake stream. I have already been running it on my vehicle for over a month and haven't had any issues with it as far as causing codes however I am not getting the improvements to my mileage yet due the computer richening my cleaner exhaust back up to a richer state.
Does anyone care to share their experiences about HHO.
Re: HHO geneators??
06/23/2010 5:59 PM
Well, OK. I'll start it off.
This 24 volt alternator; What spins it? Is it in addition to your 12 volt alt?
Are you getting H2 and O2, or HHO? Are you sure? Are you using the H2, or the O2, or combined?
You tell us "...I am not getting the improvements to my mileage yet due the computer richening my cleaner exhaust back up to a richer state." Are you sure that is the reason mileage is not improved?
Re: HHO geneators??
06/24/2010 4:12 PM
Did you catch this: with your chick magnet?
Re: HHO geneators??
06/24/2010 4:41 PM
AH-HA!
My experiment to see how long it takes to notice is over!
Good catch, lynlynch!
And I am sorry to say, no, this is not a legitimate 'catch' with the "Chick Magnet'.
Speaking of noticing, I am surprised no one has mentioned this yet: From #2 "The vapor is hydrogen2 and one oxygen molocule..." But, where to start and stop noting and commenting?
Re: HHO geneators??
06/23/2010 6:22 PM
What is coming out of the tube going to the intake is a vapor.
The vapor is hydrogen2 and one oxygen molocule created from what is called electrolysis of water. Hydrogen is explosive as we have all heard of the Hindenburg Blimp and Oxygen just adds to the heat of the explosion.
There is no carbon atom in Hydrogen like there is in other fuels like gasoline, diesel or alcohol therefore there is no carbon footprint left behind which creates soot residue.
When fuel is atomized and sprayed into the cylinder in modern injection engines about 85% is combusted which drives the piston down in the cylinder to give the engine power and when the oxygen sensors in the exhaust read the unburnt fuel residue in the exhaust vapors the signals coming from these sensors going back to the computer cause the injectors to lean down or take some fuel away till it achieves a 14.5:1 Air fuel ratio in the exhaust for better exhaust emissions.
When you add hydrogen in the mix as well as more concentration of oxygen the explosion is therefore stronger and hotter and will burn the fuel more effectively leaving less unburnt fuel to come out of the cylinder into the exhaust stream. Therefore the computer sees it as running leaner therefore will richen the mixer back up which is not really neccessary.
I built a seperate bracket for my 24 volt alternator and mounted it to the side of my existing alternator bracket and lengthened my serpentine belt to drive it as well as my existing 12 volt alternator. The 24 volt alternator gets energized when I flip the swich to activate the relay which powers the hydrogen cell.
Good Answers: 60
Re: HHO geneators??
06/23/2010 7:34 PM
how the engine works as you dont seem to know the finer points of engines
http://www.howstuffworks.com/engine.htm
running an engine on H2 and O2
http://www.google.co.uk/search?q=what+would+happen+to+an+internal+engine+if+you+fed+Hydrogen+and+oxygen+into+it&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GZEU_en&redir_esc=&ei=uZUiTMKeF4z00gS0_JH9BA
http://www.google.co.uk/search?q=hho+generator&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GZEU_en&redir_esc=&ei=vJQiTPSeN5m60gTx2rTsBA
hydrogen
http://www.ucc.ie/academic/chem/dolchem/html/elem/elem001.html
http://www.google.co.uk/search?q=is+it+practical+to+burn+hydrogen+and+oxygen+in+a+gasoline+engine&hl=en&newwindow=1&rls=com.microsoft:en-gb:IE-SearchBox&rlz=1I7GZEU_en&ei=OJciTOy3JYSi0gS11LTrBA&start=10&sa=N
That concludes the preamble
Now to pick you up on your description of the process.
Oxygen just adds to the heat of the explosion WHAT ?
You don't know much about combustion do you ?
Oxygen is the reason things Burn. no Oxygen no combustion, Try to light a fire in outer space
WRONG the clue is the OXYGEN in the word, the oxygen sensor detects the amount of oxygen not consumed by the combustion the amount of oxygen is directly proportional to the amount of fuel burnt, this information is used to control the fuel input
Wrong again if you add more oxygen than is in the air already, unless you reprogram the engine management the effect of adding the extra oxygen would mean the O2 sensor in the exhaust would detect more oxygen in the exhaust than normal and would interpret this as an over lean mixture and would dump massive amounts of fuel into the engine to try and bring the oxygen in the exhaust down so as to achieve the correct stoichiometric level
http://www.engineeringtoolbox.com/stoichiometric-combustion-d_399.html
An oxygen sensor, or lambda sensor, is an electronic device that measures the proportion of oxygen (O2) in the gas or liquid being analyzed. It was developed by Robert Bosch GmbH during the late 1960s under supervision by Dr. Günter Bauman. The original sensing element is made with a thimble-shaped zirconia ceramic coated on both the exhaust and reference sides with a thin layer of platinum and comes in both heated and unheated forms. The planar-style sensor entered the market in 1998 (also pioneered by Robert Bosch GmbH) and significantly reduced the mass of the ceramic sensing element as well as incorporating the heater within the ceramic structure. This resulted in a sensor that both started operating sooner and responded faster. The most common application is to measure the exhaust gas concentration of oxygen for internal combustion engines in automobiles and other vehicles. Divers also use a similar device to measure the partial pressure of oxygen in their breathing gas.
I appologise for my sarcastic approach but i find it so funny the way people misunder stand how modern computer controlled cars work
Re: HHO geneators??
06/24/2010 5:33 PM
I stand corrected...........
The oxygen sensor does indeed measure the oxygen concentration in the exhaust and if indeed adding HHO gas into the engine will cause the exhaust to have more oxygen in it and cause the engine to run richer which is more or less what I was saying only a different round about way. The fact that I mentioned the ECM was richening the fuel mixture up when I add the HHO into the intake stream is what I was assuming. I have read up on Wide band and narrow band O2 sensors and I know how they work although I misinterperetted it in my write up..
I would think that all the oxygen would burn up in the combustion process when the ignition event occured when the fuel is ignited but maybe it doesn't consume all of it. That I really have no way of knowing.
The point is: Hydrogen is combustible. I asked a simple question and didn't deserve to be condemned by your little man syndrome attitude..
I have been in the automotive industry for a few years as a mechanic in the past and have worked with larger deisel truck engines for over 18 years.
I know that it takes oxygen to have a fire or a combustion event in the cylinder. I was stating a fact that more oxygen should create more heat just as it does with a cutting torch to cut through thicker metal and cause more power to help push a piston down.
I am not trying to replace fuel to run my vehicle. All I am trying to do is add enough HHO to supplement with a smaller amount of fuel to obtain the same power output therefore saving fuel useage.
I do not know all the in's and out's of the computer systems on automobiles and I am learning which is why I came on this thread to get some ideas. Not BS and put downs.
I would hope not everyone on this thread is as rude as you have been or I will be a short term guest of it.
Thanks for insiteful input.
I will admit I was wrong about the way I worded some of it but I do know engines other wise I wouldn't be teaching for an engine manufacturer.
Thanks
Good Answers: 60
Re: HHO generators??
06/24/2010 7:37 PM
the oxygen content of the air is 21% it isn't all consumed during combustion
I would think that all the oxygen would burn up in the combustion process when the ignition event occurred when the fuel is ignited but maybe it doesn't consume all of it
Sorry it doesn't work that way the amount of fuel will only need a certain amount of oxygen to burn adding extra oxygen without adding extra fuel will do nothing.
So sorry its nothing like a cutting torch.
You say your a mechanic of 18 years experience, Not experienced in the way the vehicles work i see.
I have come across a lot of mechanics who know nothing about the way the vehicles work which explains why a lot of them cant diagnose complex faults.
I am sorry if i upset you but you should really research your topic before asking questions that to most of us appear impossible.
as others on this site have stated over unity and other applications that suggest getting H2 and O2 from water is not a feasible idea as it requires more energy to get the gasses than burning the gases produces
I also have to challenge the amount of Gases you say your equipment produces it sound like a lot, and if you can indeed produce the stated amount then you have a really good system that should enable you to produce a really good system.
But from what little i know of electrolysis it appears to me to be impossible to achieve
My appologis for upsetting you but we do get a lot of really silly questions on here.
06/24/2010 8:30 PM
It's all good.
I do not know much about the chemical combustion process and how much oxygen is left over after combustion occurs in a cylinder. I do know that too much fuel ends up causing black smoke and unburned fuel and too lean causes lack of power and other issues.
Most of the systems sold are using 12 volts to make it easy to adapt to a vehicle. There aren't many 24 volt cars running down the road.
Using 12 volts and depending on the size of the hho cell as well as the amount of neutral plates and the voltage drop across each plate and the electrolite solution to increase the conductivity of the water the amperage can get quite high and demand alot of power to operate which would indeed cause the alternator to work harder.
Higher voltage and the same amount of resistance will lessen amperage (current draw) which is in Ohm's Law.
I was running a 12 volt system cell and at 40 amps of total draw on 2 seperate cells I was creating approximately 2-3 liters a minute. To me that wasn't very efficient.
I am guaging it using a 1 liter bottle submerged in water and filling it from the bottom with the gas till it floats up and the gas is coming out of the bottle top.
U tube shows the design plans for measuring the production and it does work better than a flow meter in my opinion.
My 24 volt set up while charging my batteries and alternator turning at 1400 eng rpm is at approx. 27.5 volts. The amperage dropped to 20 for both cells running and my production doubled because the voltage drop across each water passage increased slightly from 2.3 with 12 volts up to 2.7 with 24 volts which increased the voltage pressure flowing through each path and therfore increased my production of HHO with lower amp draw.
It is working well in my opinion and the gas is quite explosive when lit so I figure adding into a cylinder along with fuel to ignite the mix should create more power and therfore allowing one to lessen the fuel to get better fuel economy.
It could all be a hipe but at $60.00 a fill up once a week I figured it wouldn't hurt to try to build my own set up and play around with it.
I honestly feel if I can make the ECM see a "less oxygen" signal from the O2 sensors which is considered to be "rich" to the point that it leans the mixture I might could see a desired result and improved mileage without any hinderance to power.
I might be dreaming though.
I know there are cars that run on hydrogen and the amount it takes to run the engine is alot. I am not trying to run mine on hydrogen alone. I know my cell won't produce enough of it. I do not want to store the hydrogen in a liquid state that these such cars do. I am just trying to produce enough on demand that can be suplimented as an alternate fuel and improve the economy of my vehicle.
It has been an interesting project to say the least and has been fun experimenting with.
Thanks for the input.
Re: HHO geneators??
06/23/2010 8:00 PM
If you want to save fuel and gain power on a gasoline engine you richen the fuel supply not lean it out. Around 12.9:1 is the power and efficiency range 14.5:1 is the cleaner emissions range.
Ask any off road enthusiasts or old school mechanics how they get improvements is fuel efficiency and power. In the old days when emissions compliance first came out for carburetted engines the common mechanics secret to improve the fuel mileage and power of a new factory vehicle was to increase the jet sizes by one or two over the emissions compliant ones.
Study up on "quenching effect of gasoline" if you want to know why a slightly richer than stoichiometric ideal ratio is better for fuel efficiency instead of worse.
If you want all of the supposed improvements that HHO is purported to have without actually wasting all the time, effort, and money on the HHO junk just build an O2 sensor signal re-calibrator. You can easily tweak your O2 sensors to make your computer run your engine at a far richer or leaner levels with just the turn of a simple knob if you build one right. I would bet good money that once you tweak the O2 sensor signals so that the engine runs slightly a richer than its factory setting you will get better fuel mileage and power while a leaner ratio will make it only get worse.
Re: HHO geneators??
07/02/2010 2:41 PM
I agree this HHO BS is just that you can manipulate your O2 sensor and improve your gas mileage without the HHO. The amount of energy required to run your engine or even improve your mileage is just not possible, energy in versus energy out you will need a much bigger alternator much bigger than 24 volts. If you choose to attempt this anyway beware that leaning your engine can reuslt in major engine damage. I would check into all the web sites that warn against this with as much enthusiasm as those who are for it. In any case good luck.
Re: HHO geneators??
06/23/2010 10:06 PM
I hate to burst your bubble, but most of the sentiment you will find here on the subject of HHO / over-unity / more-energy-output-than-energy-input can be summed up in this post
by Blink:
A while ago, in a post in one of our too-frequent over-unity threads, I wrote about having a lot of respect for science, scientists, engineers, and academic mentors. The post rambled, like most of mine (actually, more than most), but it struck a chord with a lot of readers, garnering a surprisingly large number of GAs. So I know that there are a lot of people here who share my views, as you'd expect in an engineering and science forum.
It drives me up a wall when I search for "hydrogen" and most of what comes up on the web is pseudo-science, and a very large portion is just plain fraudulent -- one HHO booster scam after another. We now have frequent visitors at CR4 promoting the use of HHO (Brown's gas, oxyhydrogen, Hydroxy, magic, Joe cell) injection to boost fuel efficiency. 15 years ago, an internet search on "hydrogen and engine" would give you plenty of interesting hits about real uses of hydrogen in engines. Now, pseudo-science and anti-science are gaining ground against rational thought. (Ironically, the first HHO booster was patented in 1918, and looks just like those of today -- although some of the loonier promoters of today have added more obfuscation: molecular resonance, pulse width modulation, AC electrolysis, etc. (None of these has the potential for improving efficiency to 100%, whereas just breaking even on an energy balance would require over 500% efficiency -- so it is all just distraction.)
There is a $1,000,000 prize offered to anyone who can devise an HHO device that actually works as the frauds claim. Of course, that prize remains unclaimed. There is a far bigger prize, however, available for the developer of any device which can be shown by the EPA to actually work. A device that can improve the mileage of a car by 50% (Dennis Lee's "guarantee") is worth billions to the auto industry. Toyota spent a billion dollars just on coming up with an expensive, complicated scheme for improving the mileage of a small car to make the Prius. Imagine how much they would pay for a device that, instead of increasing the price of the car by $4000, increases it by $20. What an unbelievable advantage Ford would have if they could offer a $16,000 Focus which would beat the $23,000 Prius on fuel efficiency.
The same guy who offers the $1,000,000 prize put together a good video about these devices. This is perhaps a good place to steer people who seem incapable of reading the relevant studies, or opening a chemistry of physics book.
Elsewhere on this site I've written loads of posts about HHO, some going into considerable detail re the thermodynamics and combustion science involved. Generally, there is no way of knowing if some of the people arguing (on CR4) that HHO boosters work are scammers or only deluded, ignorant of the issues involved, insane, or incapable of designing a valid test. (This last is not a good excuse, because the EPA has been doing tests of such devices for years, and they can do a valid test for you -- or if you read their reports, you can see what is required.) An alternative is that the claimant has uncovered a real way to overturn physics and combustion science -- in which case, he or she should be running to the patent office, rather than trying to convince people at CR4.
So far, I have not seen any argument presented on CR4 that stands up to even light scrutiny. The more common arguments presented are these, the unlucky 13, which I came up with in an early response to some HHO promoter.
1. 15% (or 20% or 30%) of the fuel goes past the exhaust valve unburned: Flat Lie.
The percentage is never more than 1% either side of perfect, and is typically closer than that. Catalytic converters are damaged by values outside these limits.
2. HHO improves combustion: Misconception. The 1977 NASA study scammers routinely refer to (but never actually read) shows that injection amounts must be at least an order of magnitude higher (than HHO units produce) to have enough effect on combustion speed to have any significant effect on energy efficiency. Even this only applies when the H2 is delivered for free thermodynamically. The situation is actually much worse with electrolysis units, which consume engine power.
3. HHO simply adds additional fuel to the engine, which you get for free from the water: you are just "releasing the energy of the water". Flat Lie. This is the classic perpetual motion scheme, and was the standard HHO promotion lie for years. Water is not a fuel, which should be incredibly obvious to anyone who has put out a camp fire. Making H2 from water requires more energy than you can get from burning the fuel. Always, and by any method. (The fundamental chemistry of water dictates this. Claiming otherwise is much like saying that every time you put salt on your food you risk chlorine poisoning. This principal, re H2O, applies even if you use the highest quality electrolysis equipment, and burn the hydrogen in a calorimeter -- which measures its entire heat value. In an engine, the situation is much worse, because you only get 25% the energy converted to mechanical output.) The alternator load, and the fuel used to power it, goes up with the electrical load.
4. There is excess electricity being generated all the time by the alternator. Flat Lie. The greater the draw on the alternator, the more HP required, and the more fuel consumed. This should be obvious to anyone who has seen generators at Home Depot: big ones which (consume a lot of fuel) produce more electricity than small ones. It is also obvious to anyone who has read how a car alternator works, or who has worked on one.
5. I've developed a method for splitting water that is twice, five times or 50 times (yes there really is such a claim!) as efficient as "brute force" electrolysis. Flat Lie. A reasonably efficient HHO unit is 50% efficient. 100% efficiency is not possible, nor is any efficiency over 100%.
6. But my method "jiggles" the molecule apart with pulses of x frequency (or ac) at some frequency. I use "resonance." Flat Lie. This suggests that (in the inventors corner of the world) the laws of thermodynamics do not apply. It matters not whether you use tweezers or rocks, or high voltage or low, the laws of thermodynamics apply: even assuming 99% efficiency of the electrolysis process, the net loss is still large: for each ounce of fuel you consume to produce HHO, you get back 1/5 oz of energy in HHO (because, at best, the engine and alternator making the HHO is only 20% efficient.)
7. But I'm getting a 50% or 100% improvement despite the fact that you stupid science types think it does not work. Profound misconception, bad test method, mental instability, placebo effect, Flat Lie? Imagine yourself an inventor with a billion dollar device but sitting around making videos on YouTube, or spending your time trying to convince CR4 members, most of whom apply science every day, that science is bogus. Plausible?
8. You stinky meany heads would have kept the Wright Brothers from flying. Profound misconception. The Wright Brothers were classic scientists, and relied heavily on aerodynamics texts by Chanute and others, and on the experience of a very long line of aviation pioneers.
9. Stanley Meyer was convicted of fraud because of the Big Oil conspiracy against him. Profound Misconception. Stanley was convicted because he was a fraud who claimed that you could run a car on water, and bilked investors.
10. I'm not proposing any kind of perpetual motion machine. Profound Misconception. For the amount of HHO generated to even creep up anywhere near close to the point that its effect would be measurable (and not a net loss), the process must operate at multiples of over-unity (in which case you have a perpetual motion machine -- just plug the out put into the input and it runs forever.) In a typical engine of today, the electrolysis process would have to operate at 500% efficiency, just to get to the break even point. That is the physics of perpetual motion.
11. Well, if these things operate at a net loss, then I'd see my mileage going down, but I don't. Slight Misconception. These units draw about the same current as headlights (100 watts). The effect of 100 watts is very hard to measure on engine of 150,000 watts. (Obviously the potential benefit would be unmeasurable as well.)
12. HHO is monatomic, with completely different properties than H2. Flat Lie or profound ignorance. HHO is similar to oxyacetylene -- if you crack open both valves on an oxyacetylene torch when you light it, you get a bang. Ditto for lighting an HHO torch. However, when you put HHO into the intake airstream in the incredibly tiny amounts produced by an HHO "booster" the two gases separate, and all that is left as an energy difference is the tiny additional amount of H2, surrounded by and intermixed with an incredibly large amount of air (into which the O2 has mixed) with a small amount of gasoline vapor. At the instant that HHO comes out of the common duct, all you have is a tiny amount of hydrogen. Wackos claim that ultra high flame front speeds will prevail, thinking apparently that HHO remains in one place (about the size of a rain drop in the relatively huge volume of a cylinder) but it does not. It simply mixes with everything else. If it did not, it would be impossible to make the other silly claim -- that it has a measurable effect on combustion -- because only one in 500 times would that little chunk of separate HHO be anywhere near to the spark plug, to "explode" and improve combustion.
13. The HHO units makes the ECU "think" the engine is running lean, so the ECU increases the fuel flow. Therefore, you must tamper with your emission system. Flat Lie. These differences are not measurable (just as you'd expect because of the tiny amount of H2 injected) as verified by perhaps the best recent test of HHO devices, that done by Popular Mechanics. The Popular Mechanics test is particularly good, because it is easily understandable, but also because it was performed by a body that is beyond independent -- they gain ad revenue from mileage improvement devices, so it is clearly in their best interest to say that these things work, rather than that they don't work. If you poke around HHO websites, you'll find many "reasons" why HHO can only work if you buy additional stuff: solvents, magnets, fuel heaters, etc. Ironically, some HHO sites which said that their unit worked just fine a year ago, now say that you must buy additional stuff to make them work. ("We were lying then, but now we are telling the truth.") Suckers keep coming, though.
So... I've written about all I can about these units in zillions of posts here. I plan to generally ignore the HHO threads other than the really egregious ones. Perhaps others who are inclined to take up the slack, can use this post as a sort of summary for those people who stumble into CR4 with apparently genuine questions about whether these things work or not. Warning: the "apparently genuine questions" are hard to weed out from the "hard core scams". We had a guy recently who started with a few questions, then a wild claim of doubled fuel efficiency, then an admission that he is in the business, then a list of papers which he apparently hoped nobody would read which show (to anyone with a little science background) that these devices cannot work as claimed.
Re: HHO geneators??
10/17/2010 3:18 AM
Hello every one, please check dingel in youtube who claimed that he invented a device to run his corolla by extracting hydrogen and oxgen as fuel.
Re: HHO geneators??
10/18/2010 12:17 AM
I don't even have to go there for me to say BS!
How do I say this without shouting? OK, well I guess I can't:
YOU CANNOT, YES, I SAY CANNOT, GET MORE ENERGY OUT OF A SYSTEM THAN WHAT YOU PUT INTO IT!
THERE IS NO FREE LUNCH!
YOU ARE NOT GOING TO CHANGE THE WORLD WITH SOMETHING THAT JUST POPPED INTO YOUR HEAD WITHOUGHT DWELLING ON IT AND SUBJECTING IT TO HOW IT IS SCRUTINIZED WITH THE UNDERSTANDING OF PHYSICAL LAWS! (Sorry for the run-on sentence).
YOU CAN'T GET SOMETHING FOR NOTHING!
WOULD ALL OF YOU IDIOTS QUIT TRYING TO CIRCUMVENT CHEMISTRY AND PHYSICS AND JUST DO THE MATH!
Good Answers: 145
Re: HHO geneators??
06/23/2010 11:05 PM
When I spotted this thread this morning (Oz time) I thought, gee Dumej0803 is going to be on a hiding for nothing.
I didn't have anything constructive to say, and I knew the usual Lurkers would join in the fun, and so I didn't post anything at the time.
Having read all the posts, I'd suggest that Dumej0803 needs to re appraise why he is doing this experiment in "HHO".
A he has discovered so far, but not quite understood, that he hasn't gained any benefit. Fiddling with the EGO feed to the ECU may give him some changes to overall performance but I'd be betting that at the end of the day he will not be better off.
Now I'm all for people having a go, at just about anything. But I suspect that if we didn't give these threads the oxygen of participation then maybe, they might wither from the atrophe of apathy.
Just my Tuppence worth.
Re: HHO geneators??
06/24/2010 7:17 AM
"Does anyone care to share their experiences about HHO."
In the mid 60s Popular Mechanics or Popular Science, I can't remember which,
had an article on this topic.
It didn't work then and it doesn't work now.
But, it sounds like you're having fun playing around with it, so go for it.
Re: HHO geneators??
06/24/2010 7:42 PM
Could you please explain how you get the vapor you talk about
the reason i ask is oxygen and hydrogen is color less and you would not therefore see it.
I am curious about how you prduced the vapor Thanks
Re: HHO geneators??
06/24/2010 8:46 PM
Ok. I will explain it the best I know how.
It's called electrolysis of water.
If you take 2 pieces of stainless steel and attatch a 12 volt DC battery + to one plate and - to the other and gap them approriately apart and dip them in say a bucket of water with one gallon and one tablespoon of sodium hydroxide which is a chemical powder found in draino. The powder will increase the conductivity of the water to allow current to pass through it easier without as much resistance.
When the plates are dipped into the water and solution mix bubbles will start coming off. The reaction causes the water to heat up gradually which if left unchecked could boil the water and cause steam. The vapor seen could be a slight residue of the sodium hydroxide reacting during the process which does make the gas slightly visible.
It doesn't really have an odor and I wouldn't want tobreath it anyway but none the less if you capture this gas in a plastic bottle and ignite it you will see the result that this stuff could definitely be used to power a piston engine.
The space shuttle side rocket and main booster rocket is a hydrogen fule cell for Pete's sake.
What is water? H2O (hydrogen 2 parts and 1 part oxygen). When it combusts it is pretty much turned back into water.
Google it: HHO generator.
There are all kinds of videos on utube but not all are that efficient and some are quite worthless and not worth building in my opinion.
I built what is called a HHO dry cell design.
Re: HHO geneators??
06/24/2010 11:31 PM
I AM SHOUTING NOW. IT TAKES MORE ENERGY TO PERFORM THE ELECTROLYSIS THAN THE ENERGY YOU CAN GET BY COMBINING THE TWO THROUGH COMBUSTION. INPUT > OUTPUT. THERE IS ALWAYS A LOSS. THAT IS WHAT ENTROPY IS ALL ABOUT. WHAT ABOUT THIS IS SO DAMN HARD TO UNDERSTAND? IF YOU REALLY WANT TO UNDERSTAND WHY THIS IS SUCH A STUPID IDEA, YOU NEED TO STUDY PHYSICS, WITH A CONCENTRATED EMPHASIS ON THERMODYNAMICS.
Good Answers: 60
Re: HHO geneators??
06/24/2010 8:18 PM
Any one know anything about this guy meyer
http://www.rexresearch.com/meyerhy/meyerhy.htm
Good Answers: 60
06/24/2010 9:45 PM
HHO Generators How it all started By Stanley Meyers.
It would appear not to be elctrolosis but some form of molecule breaking, ie allowing hydrogen and oxygen to be split using electricity at a specific frequency, I havent studied all of the information yet and so cannot comment further
  1. Stanley Meyer: Water Fuel Cell Eye-witness accounts suggest that US inventor Stanley Meyer has developed an ... This raises the granted patents to the level of independent, critical, ...
    www.rexresearch.com/meyerhy/meyerhy.htm - Cached - Similar
  2. Stanley Meyer: Water Electrolysis -- Canadian Patent # 2067735 ... Canadian Patent # 2067735. Water Fuel Injection System. Stanley Meyer. Abstract. An injector system comprising an improved method and apparatus useful in ...
    www.rexresearch.com/meyerhy/2067735.htm - Cached - Similar
  3. Stanley Meyer's water fuel cell - Wikipedia, the free encyclopedia In 1996, inventor Stanley Meyer was sued by two investors to whom he had sold ... Meyer's patents are still available online, although there has as yet be Get more video results
  4. Stanley Meyer's Gas Voltage Control Circuit - Patents | MERLib.org 12 Dec 2005 ... I personally feel that reading this patent will give you the best explanation of the Stanley Meyers Discovery of using Voltage Potential. ...
    merlib.org/node/3394 - Cached - Similar
  5. Stan Meyer's Dune Buggy Stan Meyer's Dune Buggy that ran on water. Hydrogen/Oxygen fuel in an ICE motor. .... Then Meyer loudly and falsely protested that he would "lose his patent ...
    waterpoweredcar.com/stanmeyer.html - Cached - Similar
  6. Directory:Stanley Meyer - PESWiki Stanley Meyer on Water Fuel Cell technology at 1989 free energy ... the late Stanley Meyer, who allegedly ran vehicles on water, and whose patents have just ...
    peswiki.com/index.php/Directory:Stanley_Meyer - Cached - Similar
  7. Stanley Meyer Additional Illustrations gathered of Stanley Meyer patent applicationsfrom the internet not sure of source possibilty of them from Keelynet.com ...
    www.linux-host.org/energy/stanleymeyer.htm - Cached - Similar
  8. Stanley Meyer's bad science Stanley Meyer was a scammer who claimed he'd been able to split water into ... There are a great many patents issued every year for devices that simply do ...
    www.aardvark.co.nz/stanley_meyer.shtml - Cached - Similar
  9. IceStuff.com: Stan Meyers United States Patent: 4389981 from The ... Stan Meyer System and apparatus for the controlled intermixing of a volatile hydrogen gas with oxygen and other non-combustible gasses in a combustion ...
    www.icestuff.com/~energy21/injectorsystem.htm - Cached - Similar
Searches related to stanley meyer patents
stanley meyer water fuel cell
stan meyer patents
stanley meyer circuit
stanley meyer fraud
stanley meyer us patent 4798661
Good Answers: 60
06/25/2010 3:40 AM
If the generator does what they say it does the engine should run on this vapour as its hydrogen and oxygen.
but i would doubt that burning the H2 O2 would yield much power,Compared with a hydrocarbon
http://en.wikipedia.org/wiki/Gasoline The chart below is taken from this link and as you can see energy of hydrogen is only 10 compared with 32 with gasoline
87 Octane (AKI)/91 Octane (RON) Gasoline/Petrol32.044.4
[11]
150,100125,000Min 91
[clarification needed]
Autogas (LPG) (60% Propane + 40% Butane)
26.846108
Ethanol
23.531.1
[12]
101,60084,600129
Methanol
17.919.977,60064,600123
Butanol
29.236.6
Hydrogen
10.1 (at 20 kelvins)142130
[14]
http://en.wikipedia.org/wiki/Stanley_Meyer%27s_water_fuel_cell
Re: HHO geneators??
06/24/2010 10:45 PM
HHO is a misnomer, anyway, because what you get is 2H2O → 2H2 + O2. When the basic terminology is wrong, quite likely there will also be other conceptual and computational errors.
Re: HHO geneators??
06/25/2010 12:09 AM
It often gets worse than that. Some of these dreamers can't even do arithmetic properly, and some that can do arithmetic can't figure out correctly what arithmetic to do where. Or what constitutes a valid practical or theoretical test of anything.
Good Answers: 60
Re: HHO geneators??
06/25/2010 3:51 AM
HHO This is where it all started.
Meyer's claims about his "Water Fuel Cell" and the car that it powered were found to be fraudulent by an Ohio court in 1996.[1][3]
Meyer has demonstrated his fuel cell device before Professor Michael Laughton, Dean of Engineering at Mary College, London, Admiral Sir Anthony Griffin, a former controller of the British Navy, and Dr Keith Hindley, a UK research chemist. According to the witnesses, the most startling aspect of the Meyer cell was that it remained cold, even after hours of gas production as his system appeared to operate on mere milliamperes, rather than the amperes that conventional electrolysis would require. The witnesses also stated:
"After hours of discussion between ourselves, we concluded that Stan Meyer did appear to have discovered an entirely new method for splitting water which showed few of the characteristics of classical electrolysis. Confirmation that his devices actually do work come from his collection of granted US patents on various parts of the WFC system. Since they were granted under Section 101 by the US Patent Office, the hardware involved in the patents has been examined experimentally by US Patent Office experts and their seconded experts and all the claims have been established."
Water Fueled Car
It Runs on Water is a video with Stanley Meyer demonstrating the water fuel cell in a car. Meyer claimed that he could run a 1.6 liter Volkswagen Dune Buggy on water instead of gasoline. He replaced the spark plugs with "injectors" to spray a fine mist into the engine cylinders, which he claimed were electrified at a resonant frequency. The fuel cell would split water into hydrogen and oxygen gas, which would combust back into water vapor in a conventional hydrogen engine to produce net energy. Estimates made showed that only 22 US gallons (83 L) of water were required to travel from one US coast to the other. Meyer also demonstrated his vehicle for his city's local news station Action 6 News. A video of the buggie in action can be found here.
Fraud Charges
It failed to work during a required demonstration of the water-fueled car in a 1990 court case. An Ohio court found Stanley Meyer guilty of "gross and egregious fraud" in a case brought against him by disgruntled investors. The court decided that the centerpiece of the car, his water fuel cell, was a conventional electrolysis device, and he was ordered to repay the investors $25,000.[1]
However, in their 1 December 1996 issue , the London Sunday Times published an article entitled "End of Road for Car that Ran on Water" by Tony Edwards. It upheld the court case, stating that three "Expert Witnesses" were not impressed and decided that the WFC was simply using conventional electrolysis. It stated Stan Meyer was found guilty of "gross and egregious fraud" and was ordered to repay the investors their $25,000. It implied that Michael Laughton, professor of electrical engineering at Queen Mary and Westfield University, London was due to examine the car, but was not allowed to see it. However, not mentioned was that this occurred in 1990 and that the WFC Water Fuel injector tech-base was still under U.S. National Security Review as in accordance to U.S. Patent Law and not available for public viewing. Also not mentioned were the many WFC Patents, verified laboratory and university testing that supports the bases of WFC technology nor the WFC appeal filing to dismiss Judge Corzine ruling due to Judicial default and other relevant information.[2]
On 18 October 1995, a pretrial deposition hearing to inspect the WFC Dealership demonstration units (Variable-plate Electrical Polarization Process (VIC) Fuel Cell and Rotary Pulse Voltage Frequecy Generator Tubular-Array Fuel Cell) was held in the office of the plaintiff's attorney, Robert Judkins. Present were the plaintiff's, their attorneys, plaintiffs expert witness, Michael Leverich (Electronics Engineer), Stan Meyer, Dr. Russel Fowler, WFC witness and defense attorneys Judge Roger Hurley and James Detling, as well as a deposition recorder. During the deposition, Attorney Judkins attempted to have the WFC dismantled prior to implementing proper test procedures, which Stan Meyer refused. Michael Leverich confirmed that his initial measurements of the WFC Fuel Cells showed that it operated exactly as the WFC documentation stated it should, as so recorded on WFC Deposition Video Tape. However, he then added a unknown white substance (powder) for additional testing. Stan objected to this, since the WFC Fuel Cell uses plain tap water and does not require a chemical additive. The plaintiffs also admitted that, during their observances at WFC Dealship Seminars, tap water was always used without any chemicals added to the water. Despite Stan's objection, plaintiff measurements were taken of this chemicallized water-bath and recorded. This illegal act of tampering with WFC Evidence of Records was witnessed by WFC Cameraman, Dr. Russ Fowler, and all others who attended Plaintiffs Deposition To-Test.[3]
In 1996, Stan Meyer gave oral testimony before the court demonstrating the WFC Fuel Cell "Mode of Operability" by using the Voltage Intensifier Circuit (VIC) to produce voltage of opposite polarity to separate and disassociate the water molecule into its component gases, hydrogen & oxygen. However, the court audio sound recording equipment seemed to malfunction and was switched off. Judge Corzine said proceedings should continue without it. This was a violation of judicial protocol, since the recording system is used to verify testimony given during the trial and as such becomes "Evidence of Records." After his oral testimony, Stan expected Attorney/Judge Hurley to start bringing forth WFC witnesses and counter arguements. Instead, Attorney/Judge Hurley spoke up, stated he had to leave for a pre-planned vacation and said that there was no more testimony to be given and waived the right of the defendant to give a case summary of the WFC facts brought before the court. Stan Meyer immediately stated he would protest and Judge Corzine ended the hearing. Stan wrote a "Request to Retract" fax-letter to the Sunday Times on 2 December 1996. He attached WFC documentation on the filing with the Disciplinary Counsel. He further stated that Judge Corzine had no right to turn off the court audio sound recording equipment, nor to rule against U.S. Patents, or overrule Government and University lab reports in the public domain concerning the mode of operability of the WFC Technology. Furthermore, Stan pointed out that no US Federal "Cease and Desist" order has ever been issued against WFC since the WFC Technology has been fully legalized under US Patent Security Law 35 USC 101 and other US Federal regulatory Acts. His final statement was that "WFC is here to stay" in contradiction to the Sunday Times statement.[4]
The above published under the terms of the GNU Free Documentation License
Since the combustion step is the exact reverse of the electrolysis step, the energy released in combustion exactly equals the energy consumed in the electrolysis step, and—even assuming 100% efficiency—there would be no energy left over to power the car. In other words, such systems start and end in the same thermodynamic state, and are therefore perpetual motion machines, violating the first law of thermodynamics. And under actual conditions in which hydrogen is burned, efficiency is limited by the second law of thermodynamics and is likely to be around 20%. More energy is therefore required to drive the electrolysis cell than can be extracted from burning the resulting hydrogen-oxygen mixture.
Good Answers: 60
Re: HHO geneators??
06/25/2010 4:09 AM
To Dumej0803
ref research as you can see i gave your idea the benefit of the doubt and researched the idea, and all my posts on here have the best links i can find, some links support the theory some do not.
Most of the evidence available suggests it cant be done, Though there is a slight doubt, this doubt is about how Stans device actually worked, ie splitting water, but there is so far as i can find insufficient evidence to suggest it works, main reason for this if it did work, even with the oil companies trying to stifle it , the idea would have eventully got through, and it hasent.
I am still looking into the idea, but so far it doesnt seem to work.
Taken from
http://www.biofuelmanufacturer.com/
A common fallacy found in connection with this type of modification is the mistaken assumption that cars generate excess electricity via their alternators that normally goes to waste and therefore is available for electrolysis. The amount of force required to turn an alternator or generator depends strictly on the electrical resistance of the circuits it is supplying, and residual heat lost due to friction. If an electrolysis unit is added to a car, the amperage it draws from the car's electrical system will make the alternator harder to turn, which will put additional drag on the engine. As a result more fuel will be required to maintain the same rotational speed (RPM
http://www.top-alternative-energy-sources.com/water-powered-car.html
Good Answers: 60
Re: HHO geneators??
06/25/2010 4:17 AM
Good Answers: 60
Re: HHO geneators??
06/26/2010 4:04 AM
Other HHO enquiries on here
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=hho&order=asc
http://en.wikipedia.org/wiki/HHO
http://en.wikipedia.org/wiki/Oxyhydrogen
http://en.wikipedia.org/wiki/Evaporation
Water was thrust into the scientific limelight this past April, when a team of scientists led by Anders Nilsson from the Stanford Linear Accelerator Center presented evidence that water is more loosely bound than previously thought.
The response has not been all that welcoming. "A lot of people have a very strong opinion about water," Nilsson said in a telephone interview.
At a recent conference on water, some of the attendees stayed up all night debating these results. Saykally was one of them. He calls the results from Nilsson's group a drastic revision of how water is understood.
"If they are right, they're going to win a Nobel Prize," Saykally told LiveScience.
But he doesn't think they are right. In the Oct. 29 issue of the journal Science, Saykally and his collaborators published results that contradict the revisionists' findings.
http://www.livescience.com/environment/041201_water_bonds.html
CR4 Admin: Modified Post
Copyright Violation: Reduced copied text according to copyright law. Please see Section 13 of the CR4 FAQ about posting copyrighted material.
For a darker view of water, see the Ban DHMO page
http://www.dhmo.org/
so the question is under what circumstances is it possible to break the molecular bond of water ?
Good Answers: 60
Re: HHO geneators??
06/26/2010 4:56 AM
http://www.youtube.com/watch?v=_aRcO_974k0
i am looking for catalyst that will react with water.
Re: HHO geneators??
07/06/2010 1:16 PM
what we need is to have external generation of hydrogen gas, and a gas storage/deliver system,. The H2 can be generated using solar cells or wind power to create the electricity to feed an electrolyis unit which will break down the water to H2 and O2 and even collect it. Eventually we will need to have a long term development of what I call the Solar/Gravitational Hydrogen economy. We will eventually be able to drive up to a service station and fill our car w/ H2 gas. This will power fuel cells to power electric motors at the wheels. If anyone wants to know more, they can email me at livagain1@yahoo.com HLG
Register to Reply 32 comments
Anonymous Poster (2); Doorman (2); Dumej0803 (4); JonathanM76 (1); livagain1 (1); lyn (2); Mikerho (3); peterg7lyq (13); tcmtech (1); Tobugrynbak (1); Tornado (2)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
