Previous in Forum: Carbon Credits for Small Solar Systems   Next in Forum: Are Solar Panels Efficient?
32 comments
How to Design and Make a Low Cost, Low Tech. Solar Tracking System
06/28/2010 1:23 AM
Dear All,
Pl help me to find out:
How to design and make a low cost, low tech. Solar Tracking system. I mean the type that can be made at a normal mechanical workshop and with the use of easily available material. Only other requirement is: it should not use electricity but mechanical energy i.e. in the form of spiral spring or gravity pull can be used.
To elaborate: we can daily wind-up the spiral spring manually, so that it keeps moving the tracker for 12 hours of solar tracking. Similarly if gravity pull is the driving force then the system should be able to continue tracking for 12 hours once the weight is manually lifted up in the morning.
I wish to further explain: These systems are to be used for the areas where electricity is not available and for thermal (heating/cooling) applications only, however manpower is available for daily morning adjustments/ human intervention required to run the system.
Regards,
Dr N P Singh
Re: How to Design and Make a Low Cost, Low Tech. Solar Tracking System
06/28/2010 2:07 AM
Rework an antique "grandfather clock." If the whole collector assembly rotates, gear the hour hand down 2:1 to create a 24-hour clock drive. If only the reflector rotates, feeding to a static collector, gear down 4:1. The axis of rotation is parallel to earth's axis. Alternatively, there might be spring-wound equatorial telescope drives that are already set for 24-hour rotation. See http://www.instructables.com/id/Portable-Sun-Tracking-Solar-Panel-With-A-Windup-Cl/
This whole scheme assumes that the sun is shining, so you could also use a small PV panel to drive an electric motor.
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
06/28/2010 11:10 AM
could you go with solar electricity generation for your system?
With a solar powered system, tracking the sun could be as simple as a sensor with a sight guage (tube that points between the sun and sensor to insure direct alignment)
Give me enough duct tape and I can fix anything!
Good Answers: 179
06/28/2010 11:59 AM
Can't rely on the wind to blow in your area every day to help wind the spring mechanism used for sun tracking purposes.
There are already electrically powered tracking systems on the market. You can also build your own control circuitry from parts ordered on the Net (Radio Shack is one source)...the plans are available online from several sources for free: Google search them Doc. The motor uses energy provided by solar PV, but has a battery backup...
The most expensive parts of the system are the geared motor and the actuators to turn the equatorial mount/solar array frame, + the pole mount and foundation.
Why try re-inventing the wheel? Just curious....
Signed CaptMoosie, LPE/PhD
Good Answers: 119
06/28/2010 12:54 PM
I don't know if this fits your application, but I'm currently researching systems like these
http://davidmdelaney.com/scheffler-precis/scheffler-precis.html
http://solarcooking.wikia.com/wiki/Scheffler_Community_Kitchen
Seasonal adjustments are manual, but a fairly easy task.
These designs can use a mechanical (gravity driven) clockwork mechanism to track daily sun position. Resetting each morning should be a trivial task. A full 12 hour mechanism may be unnecessary. Realistically (and depending on where you live) I don't think you will gather much useful energy beyond 8 hours per day. When I find any useful designs for a simple mechanical clock drive, I will post links here.
Good Answers: 119
06/28/2010 6:32 PM
These are some examples of gravity powered clockwork mechanisms from the solare-bruecke.org site ...
http://www.solare-bruecke.org/Bauanleitungen/clockworkmanualv3.pdf
http://www.solare-bruecke.org/Bauanleitungen/Manual_ind_07.pdf
Not quite as simple as I was expecting, but still made from common parts.
06/28/2010 10:49 PM
If sunshine is available, you can use a system I saw in Mother Earth News. Two pneumatic cylinders filled with refrigerant and connected to move the collector. There's a vertical panel shading one. They are connected together so that the sun heats the one on the sunny side of the panel, extending that cylinder and moving the collector. Once the sun hits the other cylinder, pressure builds there and stops the collector.
As the sun moves, it's shadow causes one cylinder to be partially shaded and the different solar heating moves the collector.
Good Answers: 114
06/28/2010 11:05 PM
Here's a tracking system that uses 2 canisters of freon. the heat from the sun causes the liquid to boil & transfer from one side to the other. The system requires no human intervention, after the initial set up. dampers are fitted to counter act any gusts of wind
06/28/2010 11:46 PM
Very good idea. That is similar, if not the same as the one I remember.
Good Answers: 114
06/28/2010 11:54 PM
it's cool to watch it reset 1st thing in the morning when the sun hits it
Good Answers: 130
09/18/2010 12:01 AM
This is similar - the RHS frame is the container. The fluid is less exotic. Bit larger.
09/18/2010 12:44 AM
The original poster wanted something for solar thermal, presumably concentrating.
Which might means that the freon thing (and similar systems) are not accurate enough?
If it is 5 degrees off or more, much of the sunlight will not be concentrated on the receiver. (I know this will not matter for photovoltaic) but he said solar thermal.
Good Answers: 130
09/18/2010 2:09 AM
Works as well in the thermal context - centers on the 'hottest' point in the sky. If it's a concentrating application, then how good is the mirror focus? how big is the receiver? what is the focus shift permissible drift? More than 50 I imagine.
However; 'accuracy' is more a function of dynamic balance and receiver surface consistency/properties - or how well the thing is designed, built and set up.
Overcast will confuse it - but that usually means if there is not enough energy to center - there is not enough to usefully harvest anyway.
09/18/2010 11:10 AM
5 degrees is pretty much the max for parabolic dish. I do not know for parabolic trough. If they are using one of Winstons curves , the max can be a lot greater.
Good Answers: 25
06/29/2010 8:21 AM
http://makezine.com/22/solartracker/
Nifty little solar tracking cooker made from inexpensive components.
Make Magazine is great for geeks and wannabees!
Goodness has nothing to do with it.
06/29/2010 4:51 PM
06/30/2010 11:08 AM
Why not just use a solar (photovoltaic) panel and small motor geared down a lot. Mount the panel behind the reflector so that when it's in the shade it does nothing; when the sun shines on the panel the motor starts to run to return the panel to the shade; if there is a period of cloud cover the cooker will not move, but, when the sun re-appears the whole of the panel will be exposed and the cooker will quickly move round to the correct position. The whole cooker just needs to be reset in the morning.
Clearly the point around which the whole assembly rotates needs to be at the centre of gravity of the whole assembly including panel, supports and cooking pot.
07/09/2010 11:28 PM
I use WATTSON trackers systems--all the time depends on the total size your output is at each tracker--great systems and I connect a data logger to there systems and down load once a month to computer. It's called the angle of the sun dangule.
From Indonesia
07/11/2010 12:52 PM
I've been working on exactly this for the last year, and am now almost finished the prototype.
Details can be found here.
http://solarflower.blogspot.com/
And the main site will be http://www.solarflower.org once I get a chance to make it.
Basically it's a non electrical tracking system for a solar concentrator (or pv) which uses solar energy to boil ethanol and power a _very simple heat engine, which provides the tracking motion. Unlike clockwork systems it tracks the sun directly, rather than figuring where it should be, and unlike coolant based systems is accurate to about 1.5 degrees and not affected by wind.
There's also no need for manual resetting, and should be very low maintanence.
The project will be completely open source and the main design consideration has been that the device be almost completely makeable from scrap materials using the most basic tools and skills. Cost per unit will vary according to available materials, but I wouldn't think it would be over 100 $€£, probably closer to 30, potentially free, and each unit can gather up to 1 kilowatt raw solar. Possibly more.
I'm hoping to have the prototype up and running in the next month or two, after that I'll be making full construction tutorials to be placed on the website. Then I hope to spend the next 2-3 years travelling with the project, working with community groups and NGOs, conducting free workshops and generally getting the thing out there.
Also will be designing applications for utilising the energy, such as electrical generators, water purifiers, ovens, bio char/gas/oil/diesel, etc. These will also be as free and easy as possible.
07/12/2010 1:05 AM
Yes dear,
Thanx for the interest in the topic.
I will explore the links you have sent.
I must admit that your commennts defines the requirement that I had in mind, and as mentioned by you that the tracking system can be made from locally available material and general engg, skills are sufficient to run the system. Yes dear Material and skills both are important in any system which is desigened for community uses. Simple and easy to use systems have more acceptability in community uses as we shuold not expect that a well trained or highly skilled person will always be available to run the system soomthly.
Thanks a lot again.
I wish all the sucess for you system that you are working presently.
Any discussion on this or related topic is welcome.
Regards-
Dr N P singh
09/17/2010 2:08 AM
This is one that I have not built. You would use a soft rubber tube (like on old bicycle valves but larger diameter) that get pinched by the weight as the valve. (I know it will work because I used that old bike valve tubing successfully in a similar manner to regulate air intake in something). http://solarcooking.wikia.com/wiki/File:Gimp_equa_float_pistons.jpg It should be very accurate. It might be included in the "mecatronics" course at university of Victoria. (I was told that it would be but I do not bet on these things). So feel free to make it yourself Brian
09/17/2010 11:20 AM
Why use a sensor to control another power source, when you could simply fix a photovoltaic solar panel in the shade behind the solar collector. When the sun falls on the panel it drives a motor which is geared down and used to turn the whole assembly and return the panel to the shade.
Good Answers: 179
09/17/2010 11:45 AM
Because this sun tracker circuit with a sensor will automatically track the sun, stop the tracking at sunset, and auto reset the solar array pointing back east for the next run. Basically, this is a hands off system, except for adjusting the azimuth angle for the various seasons which is a no-brainer. Works for me.
It appears to me that your mechanical geared system will require you to do the array reset manually each and every day.....labor intensive if you ask me....wanna get up at 5 AM some cold winter morings to move the array? Not me, call me lazy in that regard!!!!! LOL
09/17/2010 12:01 PM
Fair enough in some circumstances, but, look at the OP's requirements.
Good Answers: 204
09/17/2010 1:31 PM
The sun doesn't come up until 8:30 am in the winter here, and disappears around 4:30 pm. If I understand you correctly, you are saying that a system that tracks the sun 360 degrees, or 24/7, is simpler? (only having to be adjusted for season/azimuth bi-weekly)
Chris
Good Answers: 179
09/17/2010 6:44 PM
Chris, may I ask to whom you're addressing your question? :-)
If you're asking me the question, then the answer is that the electronic tracker and sensor only track the sun's radiant energy (even on a cloudy day) while the sun is above the horizon, but it cannot do it 360 degrees and 24/7.
This is for a pole mounted solar array (with polar mount, much like those used to support telescopes and clock motor drives) with actuators. After the Sun goes down for the night the tracking sensor (a diode) that is mounted on the array frame senses there's no more radiant energy, so the computer (in a sense) stops sending signals to the electrically operated actuators that are used to move the solar panel array frame. It'll stay in it's westerly-facing attitude all night until the Sun rises above the eastern horizon. When the Sun does come up, the sensor will then activate the actuators to turn the solar array panel back to the eastern-pointing day start position. From there it'll track the Sun the entire day while it's in the sky. Hope info that helps!
Randall, yes I know that the OP wanted a mechanical system, which to me is a bit archaic and a throw back to the start of the Industrial Revolution if you ask me! LOL I'm just giving him a more modern approach and another option, though either system will be adequate for use as a sun tracker........
Good Answers: 204
09/17/2010 7:12 PM
Hi Mark,
yes, i was responding to your post. I was thinking simply of a clock drive that drives the array one revolution in 24 hours, rather like a telescope on an equatorial mount.
cheers,
Chris
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
03/19/2012 7:47 AM
hi am doing project on solar tracking system by using
1) RTC real Time Clock or LDR
2)stepper motor
3)microcontroller
4)solar panel
5)stepper motor driver circuit
I wanna just do a model. I prepared power supply circuit for microcontroller. Now i need help on how to use Ldr in this? pls send me some circuit showing connection of ldr with microcontroller
All is well !!! All is well !!
03/19/2012 11:17 AM
Start a new thread.
Try to avoid acronyms: I'm sure you mean Light Dependent Resistor; but Large Deployable Reflector is also common in this field.
09/18/2010 3:57 AM
This is pretty much how my device works as well, just replacing the electronics with mechanics.
It resets itself each morning, there's no need for manual interaction at all.
Yes this is all a bit early-industrial, but then so are most of the world's population, for all intents and purposes...
(I like to think of it as steampunk :)
The solarflower is nearing completion (I mean it this time), now if I can just get German weather to calm down a bit the next and final stage is integration of the tracker into the collector.
10/05/2010 10:42 AM
I know you were asking for a solar tracking solution, but it is important for consumers to know IF a solar tracking solution is even appropriate in a solar heating collector. This is certainly unnecessary for solar room heating and usually the same for solar hot water (for bathing temperatures).
When one considers that a stationary collector and plumbing is less expensive than one on a rotating frame, and then the added cost of the frame, hinges, tracker and daily labor - it may be more cost effective to make many simple collectors instead of fewer but more complicated collectors.
Once again, for solar room heating and bathing water, if you are considering the use of heliostats to reflect light onto stationary collectors, consider painting surfaces near the collectors with white paint as a low cost alternative, especially those surfaces that may be covered with snow part of the year.
avid0g
10/05/2010 11:00 AM
I agree, but I think he is asking for high heat concentration. "Thermal heating and cooling". Which I take to mean solar cooking and solar powered fridges. (Using solar heat instead of the propane that was used to power some old rv fridges).
I have seen some US university work on solar fridges. But they use the typical full parabolic dish and pv trackers. (I just think they are daft because the fridge has to move!)
And I guess the fridge needs to be dual powered but that is not a big deal, is it?
(If the fridge does not move).
You can still use pv trackers if you have equatorial mount. And the fridge does not move.
I am arguing against culture so I will lose.
But there is a lot of stupid culture out there. Even in technical stuff.
Good Answers: 114
10/05/2010 5:23 PM
No you are correct,
it is daft to have a moving fridge
the return on investment is not going to be favorable & the usefulness of such a device questionable
but a university may not set out to build something that makes sense as an overall package, more of a design exercise.
Register to Reply 32 comments
34point5 (2); Anonymous Poster (1); avid0g (1); beriberi (1); bharath boss (1); CaptMoosie (3); chrisg288 (2); farmatt (1); gaiatechnician (4); Garthh (3); HarryBurt (2); mjb1962853 (2); npsdhillon (1); Randall (4); sugarandfat (2); Tornado (1); vicini (1)
