Previous in Forum: NDT for PE Welds   Next in Forum: Commercial Kitchen
Omniscience, is The Origin of Conscience and Science!
08/03/2010 8:27 AM
The modern science expedite to expiate it"s observatory outlook from a perspective, from below upwards, instead of, from above and then cascadingly downwards. Athough gravitatinally acceptable to the ground-nature of it"s norms of prcessing principles, only upon the earthly surface. Science, inconspicuously is preceded by an enthalpy of finer constituency of Con-Science, which has been simply known as "Conscience" (Conducive-Conscious State in Science, the very seat of the Mind (Memory Interpreter Norms-Natural Dispensation) , which is also preceded by The Omniscience, which is Independently Maximized, for Intrinsic Activation of It"s Latent Omnipotency, to dispense a divergent dissipation of The Omnipresence of It"s activitty of OMNISCIENCE which is the Origin of Conducive-Conscious State of Scence, which is Conscience, whose location is the soul relavisticly, the seat of the Spirit, and also the earthly visible Science, locally subcribed ipon earth, for gross material re-structuring and funtioning. SCIENCE IS NO SCIENCE WITHOU THE SURGING PUSH OF THE PRECEDING CONSCIENCE, WHICH ALSO PRECEDED BY THE OMNIPOTENCY OF THE OMNIPREXENCE ENGENDERED OF THE OMNISCIENCE OF ALMIGHTY GOD. VIRTUOUSLY COMMENCING IN GOLDEN RULE MANIFESTATION AS FIBONNACCI : Waves - N X Ne X fi x fL x fC x L...
Pathfinder Tags: Omniscience.
This discussion was "closed" on 08/03/2010 9:01 AM. No new comments are allowed.
Message from admins:
This is not an appropriate topic of discussion for CR4. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
Good Answers: 83
Re: Omniscience, is The Origin of Conscience and Science!
08/03/2010 8:44 AM
and who can argue with that.
08/03/2010 8:48 AM
Who can make sense of it?
08/03/2010 8:48 AM
As the sideways component is moving in a spiral, there must be 12 spiral components that jump between the 8 nodes in the 7 anti-nodes. This means that there is an orientation of the spiral components within the sushumna. The circle of the sushumna has 12 spiral components but only 8 jump points and 7 twists. The angular twist of the spiral is theorized to be 180 degrees in order to match the (+) to (-) switch at each node. Thus the orientation always remains a mirror of each other along the length of the sushumna as they switch polarity at each node. What is set up then is 2 cylindrical fields, each complementary to each other in spin orientation, the left side moving out from the back to the left side to the front and returning to the center; with the right side just exactly opposite. Thus we have the smaller central sushumna closed tube cylinder at the core and the 2 larger side open tube cylinders as overlapping anti-nodes connected to the core cylinder at the nodes of the sushumna. Remember that the length of these tubes is what determines the fundamental frequency and harmonics at which these tubes will resonate. It appears that each of the 3 axes has a particular health status associated with it, according to As stated, the vertical axis relates to geopathic stress and disharmony results most often in insomnia. The disharmony in horizontal axis results in problems with free radicals and affects primarily the large intestine, sigmoid colon and the liver (dealing with wastes and toxins). The disharmonies in the transverse axis results in problems with heat creation and distribution, or as known in TCM - the yin/yang balance. As you can imagine, there are combinations that result in different disease symptoms. The transverse axis is easily disrupted by air travel as a person is raised from 20,000 to 40,000 feet above the Earth surface and thus is exposed to solar radiation due to the rarified atmosphere at those altitudes. This tends to greatly reduce the competency of the immune system by affecting cell production in the white and yellow marrows. Again, according to Nutri-energetic Systems, the kidney and lungs collect matter waves from the following elements: kidneys - Carbon, Boron, Aluminum, Silicon, Phosphorus, Potassium, Calcium, Magnesium, Manganese, Chromium, Scandium, Vanadium, Cobalt, Ruthenium, Rhodium, and Cadmium; lungs - Hydrogen, Oxygen, Nitrogen. This fits with TCM theory as the kidneys and lungs are said to be the main systems involved with the distribution of energy within the human body. Those that meditate have learned to correct disharmonies in their human body field through experience and to direct bioscalar energies to correct energy flows in their body field. This is only 1 of the reasons that meditation was initiated in the first place. Meditation allows one to become more aware of and sensitive to but not adversely affected by the various causes of human body field disruption. Awareness always precedes intent!
Good Answers: 83
08/03/2010 8:51 AM
Hey, you're cross-pollinating! Is that allowed?
08/03/2010 8:57 AM
I'm hoping for a giant explosion at the confluence.
That, and the fact that I hit the report button when I first saw the maniacal ramblings appear, make me hopeful that this idiot will soon be gone.
lyn (2); Mikerho (1); sue (2)
You might be interested in: Check Valves, Economizers, Colleges and Universities
