After leaving my prototype collector trough:
http://solarflower.blogspot.com/2010/07/collector-improved.html
out in weather for ten days, I discovered that the mylar thermal blanket I'm using for the reflective surface is not at all robust enough. It seems that wherever dust settles on the surface (and there was a lot of that) it eats through the silver layer, leaving only the clear plastic.
I also have some plastic backed hydroponic supply mylar, but it's not a lot more durable. If I rub either with my thumb for more than a few seconds the silver rubs off completely.
This is a huge problem. I need something which can withstand rain and dust, and can be wiped clean without greatly losing its reflectivity. It also needs to be as cheap and common as possible. The thermal blankets were perfect, if not for their lack of durability.
Ideas?
