Previous in Forum: Request for directions to web site   Next in Forum: Install solar panel
Removing rust from Stainless Steel
09/14/2010 3:14 AM
I have noticed several conversations regarding removal of rust and rust treatment of stainless steels. Our company: Orbios Metal Treatment is a stocking distributor for the Innosoft B570 and Innoprotect B580 rust removal and prevention solutions for stainless steel. Please take a look at the site www.eliminaterust.com
I would be happy to answer any questions you may have.
Thank you,
Dax Hamilton
503.686.4684
Product descriptions are below:
Innosoft B570:
- Deep cleaner that removes contamination such as oxides and rust from stainless steel surfaces.
- White viscous liquid consisting of organic acids and surface-active agents.
- Completely free from abrasive particles.
- Gentle on the metal but strong against oxides and dirt.
- Is a non –pickling agent and does not attack the metal in any way.
- Works well on aluminum, copper and mild steel.
- Removes rust on chrome-plated items.
- Removes hard water deposits.
- Removes discoloration from stainless steels and other heat affected items.
Innoprotect B580:
- Mild cleaning fluid used in conjunction with Innosoft B570
- Completely removes any residue left after the use of Innosoft B570.
- Passivates or leaves a protective microscopic surface layer which helps to prevent corrosion.
