Previous in Forum: Easiest Way to Convert Silver Nitrate to Pure Silver?   Next in Forum: Best Wicking Material
13 comments
Ingredients of Household Bleach
10/24/2010 11:17 AM
Dear friends,
why do manufacturers of household bleach state that their main ingredient is sodium hypochlorite NaOCl. According to my knowledge, it is impossible, since if you have sodium hypochlorite NaOCl in one bottle and watter in other bottle, and you mix them, you get hypochlorous acid HOCl and caustic soda NaOH.
Please, comment that.
Re: Ingredients of household bleach
10/24/2010 11:41 AM
This is for the exact same reason that when one puts common table salt (NaCl) into water (H20) that you get salt water and not the acid base combination of hydrochloric acid (HCl) and caustic soda (NaOH). If you take just the right amount of hydrochloric acid and caustic soda and combine them you will get salt water and some amount of heat released. So the ionic salt water combination is the lower energy condition that actually exists in solution and not the higher energy acid base combination.
Now the critical details on why and how this happens requires much more formal education than what one can get at a blog. This should be covered in your undergraduate Chemistry and Physics college courses.
10/24/2010 11:44 AM
Re: Ingredients of Household Bleach
10/25/2010 12:00 AM
"you get hypochlorous acid HOCl and caustic soda NaOH"
HOCL is an acid and NaOH is a base. How can they co-exist in the same container as such? They will react and salt would be a product of reaction.
If you add water to Sodium Hypo solution, it will only get diluted and would not have a chemical reaction.
Sodium Hypo is produced by adding (dissolving) controlled amount of Chlorine to dilute caustic solution. This is an exothermic reaction and reaction temperature has to be controlled.
Good Answers: 109
10/25/2010 9:04 AM
Here is a very old paper on Dakin's Solution. I think it describes the stability very well and is still apt today. Enjoy.
10/25/2010 10:57 AM
Thank you for your answers.
You helped me a lot. After surfing the web, consulting some books and carefully reading what you wrote, I came to conclusion:
Sodium hypochlorite disociate to Na+ and OCl- ions in water. If solution is acidic (ph<7) folowing reaction starts: Ocl- + H2O = HOCl + OH-. Futher decomposition happens:
3HOCl = HClO3 + 2HCl
and finally HOCl + HCl = H2O + Cl2
So finally we have highly corrosive Cl2 needed for disinfection.
In order to start that chain of reactions, the solution has to be acidic. Acidity of solution we achieve by mixing bleach with lot of water. In order to prevent this from happening during shelf life of bleach, sodium hydroxide NaOH is added to bleach, which increases pH value of bleach thus preventing those reactions
10/25/2010 11:36 AM
You reached the wrong conclusion on several counts. While it is true that Cl2 and water react to form HOCl and HCl in solution, the reverse is not true. The reaction is irreversable. It is also true that when NaOH is added to the solution, NaOH and HOCl react to form NaOCl which in water disociates into Na+ and OCl-. NaOCl can be crystalized from aqueous solution as can Ca(OCl)2 by evaporating the water.
HOCl does not react with HCl to form water and Cl2.
The OCl- is the actual oxidizing agent that disinfects (oxidizes) the impurities in water or in other material.
The next time you are tempted to jump to conclusions about chemical reactions, please talk to someone who knows something about chemistry. Failure to do so is a good way to get into trouble.
A note of caution: NaOCl is an extremely potent oxidizing agent when concentrated beyond the 5% by weight found in bleach. If you attempt to concentrate bleach you run the risk of fire, explosion, severe chemical burns, lung damage, and so on.
10/25/2010 11:51 AM
Thank you very much for your answer, but can you please comment information from following link
http://www.lenntech.com/processes/disinfection/chemical/disinfectants-chlorine.htm
Thanks in advance,
Good Answers: 32
10/25/2010 12:33 PM
As others have pointed out, a little chemistry knowledge can be a dangerous thing. You do not want to acidify the solution, because this will form gaseous Cl2, which will leave the solution (and is very dangerous to breath).
The article is strictly not correct. It is highly simplified for the average reader. Yes, Cl2 is widely used for disinfection, but only when dissolved. When it dissolves, it forms HOCl and OCl- ions, the same as NaOCl does. Strictly speaking, it is the OCl- ion that does the disinfection. Dry CL2 would have little sanitizing power.
If you Google sodium hypochlorite and sanitizer you will get a better feel, including appropriate Ph levels for sanitation. But, I I highly recommend that you consult with someone that is knowledgeable in this field.
10/25/2010 11:54 AM
GA
The wrong conclusion by the OP is exactly why I tried to emphasize that a formal collegiate education is required to really understand which reactions will happen at what pressures and temperature. Many introductory Chemistry classes just handle the balancing of reagents in a stoichiometry relation. To discern which possible set of reagents will actually occur, one must also include the energy applied or released for the reaction to occur. A major part of this is understanding how to use the electro-negativity of the elements involved, the dipole moments of the molecules involved and sometimes even the three dimensional nature of all of the reactants.
Chemistry is one of the fields that personifies the phrase "A little knowledge is dangerous."
Good Answers: 32
10/25/2010 12:20 PM
Sorry, not a great answer.
If you acidify a NaOCl solution with HCl, Cl2 gas will be given off. It is a reversible reaction.
Your explanation of the formation and dissociation of NaOCl is not totally correct.
Concentrating the NaOCl will result in a more aggressive oxidizer, but the real danger in attempting to concentrate a NaOCL solution is that it contains traces of NaOCl3, which is explosive. It is correct that both NaOcl and Ca(OCl)2 can be dried to a powder, and 0CL- is the ion which does do the disinfection.
Your general summary is correct, however, the OP has come to the wrong conclusion.
Good Answers: 109
10/25/2010 1:23 PM
GA. OP best be careful he doesn't form Cl2
04/16/2024 8:35 AM
It is easily made by the electrolysis of common-salt brine, though the process does liberate hydrogen, which is flammable.
Water softener grade salt should be used for this electrolysis, as common "table salt" contains anti-caking agents that get in the way.
04/19/2024 12:16 AM
It might be worthwhile to go back to the fundamentals and study up on Le Cahtelier's principle and understand the equilibrium state of the solution.
Register to Reply 13 comments
abotha (1); harralrw (1); Ingeniarius (2); kevinm (2); lyn (1); PWSlack (1); redfred (2); Tad (2); yesyen (1)
