Previous in Forum: AC Generator Cooling Air Flow   Next in Forum: Regenerative Braking
8 comments
Electrical Meters
11/09/2010 3:19 PM
Does anyone know how "Primary Meter Cubicles" Operate?
This will be used for monitoring energy consumption and for billing purposes.
These "Primary Meter Cubicles" will be tapped into the electrical distribution, not on individual residences.
Trying to capture the consumtion of "X-number" of homes as a whole, but each home is fed from different feeders coming from the substation.
Thanks
Still in Graduate School :(
Re: Electrical Meters
11/09/2010 4:15 PM
CR4 Admin: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Register to Reply Off Topic (Score 10)
Good Answers: 299
11/10/2010 2:51 PM
I must admit, yours is one of the more clever spams I have seen at CR4. Chatty, friendly, and welcoming... make me want to have a look. But I did not.
Your comment on this thread together with your comment on this thread are clearly intended to drive traffic to your site. Will you be posting another?
Oh, I have reported these comments to Administration, and I believe them to be short lived. Thanks for stopping in!
Register to Reply Off Topic (Score 11102011)
Good Answers: 299
11/10/2010 4:37 PM
WOW! Is this a new record?
11 Million OT points! I really managed to torque that guy off!
Thanks merph! Pretty funny!
11/10/2010 5:30 PM
"Oh, I have reported these comments to Administration, and I believe them to be short lived."
Maybe a confusion over the antecedent of "them," as in the administration being short lived?
Good Answers: 299
11/10/2010 6:22 PM
CR4 moderator merph was on patrol when I reported the spam. We visited a little bit, and I invited him to be creative with my OT on this one. I don't mind, kind of funny.
And you are correct: my sentence structure was not solid. oops!
11/10/2010 12:12 AM
Be aware of local laws about buying/selling electricity. The meters may need to be certified for level of accuracy, and they may need to be accessible for viewing by each individual consumer. For aggregate readings, you can add up all the individual meters, or you can put a separate meter on the main bus.
Good Answers: 131
11/10/2010 3:05 PM
The usual context where I have seen a "Primary Meter Cubicle" is in power distribution switchgear (medium voltage). The source to the switchgear is the secondary of a power transformer (often something like 13.2 or 13.8kV). The primary metering is usually the first or second cubicle (it's a section of the switchgear, walled off from the other sections and with its own door to access the equipment and bus inside), often jsut before or after the primary disconnecting means (a group-operated switch or power circuit breaker).
In the metering cubicle, there are usually revenue-metering accuracy class CTs and VTs on the switchgear bus, which feed the actual revenue meter which is mounted on the door of the cubicle or nearby in the switchgear. There is not often much else in there except an anticondensation heater, ground bus, and maybe a light.
This snapshot of part of a new switchgear (34.5kV in this case) has the metering compartment or cubicle after the main switch/breaker section:
Does this fit with what you are looking at?
11/13/2010 9:19 AM
This diagram does help.
Thanks for this appreciate it.
Register to Reply 8 comments
Anonymous Poster (1); Doorman (3); PeterT (1); Stanford (1); Tornado (2)
