Previous in Forum: PVC Pipes with Integrated Cables   Next in Forum: How Do I Unscrew Nylock Nuts?
How to Unscrew a Nylock Nut
02/01/2011 1:32 PM
Help! I just received a small elliptical exercise machine and bolted the base of it with carriage bolts and nylock nuts...to the wrong side! How can I unscrew the nylock nuts and can they then be reused? Mostly...how do I unscrew them?
Thanks
This discussion was "closed" on 02/01/2011 2:06 PM. No new comments are allowed.
Message from admins:
This thread has been closed because it is a duplicate. Please add your comments to the original thread: http://cr4.globalspec.com/thread/65489
Re: How to unscrew a nylock nut
02/01/2011 1:39 PM
Just stand in front of the mirror when you exercise, then you won't notice.
Seriously, how did you screw them in in the first place? Just reverse that process.
Yes, you can use them again. Their locking capacity may be slightly diminished, but you'll never know it.
United Kingdom - Member - British
02/01/2011 1:40 PM
I'd think they can still be re-used without any problems, but if you really want to, they may be thermo plastic, so you could screw them on, and melt the plastic, or you could use a little locknut solution.
bondy111
Register to Reply 2 comments
You might be interested in: Nuts, Bolts, Eye Nuts
