Previous in Forum: Suggestions - Civil Engineering Project   Next in Forum: Study
8 comments
Shift Key Dont Work
02/05/2011 3:13 AM
my whole keyboard work properly but lshift starts to not work.after 4 -5 days it starts to work properly whats the matter.i want to work my lshift work properly.
Re: shift key dont work
02/05/2011 3:38 AM
beat the snot out of it with a crowbar and then buy a new keyboard
i never said it would look pretty when i built it. BUT IT WORKS WHAT MORE DO YA WANT!!!!!!!
Good Answers: 97
Re: Shift Key Don't Work
02/05/2011 1:04 PM
You could debug the keyboard.
Take a compressed air gun and blow away dead bugs, dust or bread crumbs from between or under the keys.
It is possible to remove , clean and replace the keys but you may and up with some funny looking words if you mix them up.
Re: Shift Key Dont Work
02/06/2011 1:27 AM
Tell archy to jump harder.
Good Answers: 117
02/06/2011 8:22 AM
Keyboards are very cheap. You could clean it out, which sometimes works, or you could just get a new one. If the problem is still there with a new keyboard, come back here and we will work on a software issue.
02/06/2011 1:21 PM
If a good clean of the keyboard doesn't help, either buy a new keyboard or switch to using the other shift button (don't forget there are two).
02/06/2011 11:02 PM
All good advice! last but not least make sure you have caps lock deactivated to get the results you want with your keyboard.
Worth checking.
02/07/2011 10:56 AM
You can buy a new no-name USB keyboard for between $5 and $10. Why fight with a defective one.
02/11/2011 9:20 AM
I had a similar problem, certain keys not working, sporadic in nature. New keyboard didn't fix it. Problem was ribbon cable connector slightly warped but it's unnoticeable to the naked eye. The pressure was uneven across the cable. Fixed it by applying a piece of packing tape onto the cable to increase pressure. Also had and fixed this problem on my son's Nintendo Wii. The ribbon cables are very thin and the connectors are surface mount so they're not replaceable. I imagine many boards have been replaced due to connector problems.
Where hath all the overtime gone?
Anonymous Poster (2); Hendrik (1); jack of all trades (1); kromburner (1); steven phaneuf (1); Tornado (1); Yusef1 (1)
