Previous in Forum: ASTM A106 VS ASME A333 GR 6   Next in Forum: Dial Test Indicator Cosine Error
Parts Identification Methods
02/21/2011 1:49 PM
Wondering if anyone can provide feedback on parts identification; I need to be able to identify parts which leave the area of the plant I work in and are taken to another part of the plant. This doesn't have to be any specific individualized method; just a generic method which indicates these parts come from my part of the plant.
I have some limitations; no stamping with ID stamps, no paper tags and the method needs to stand up to light oils and water soluble coolants/machining fluids. I was considering a dye, but I don't have much experience with such things.
Good Answers: 29
Re: Parts Identification Methods
02/21/2011 2:00 PM
Maybe this?
02/21/2011 2:26 PM
Yes, spray paint sounds like a good idea (I'm not the OP, and I don't know all the constraints).
Possibly RFID tags would be worth considering, also. (They can be fairly inexpensive, and could identify the exact type of part.) Again, I'm not the OP, I have no idea of what is driving this desire, nor the value of a solution (how much money is worth spending).
02/21/2011 2:25 PM
Sharpie!
Forney paint markers.
Glyptal 1201
Good Answers: 145
02/21/2011 3:08 PM
It might be cheaper to give up and replace them. Trying to get tools to make a round trip seems to be a violation of one of the fundamental laws of physics.
02/21/2011 4:19 PM
Don't know what exactly you are doing, but if this is meant to be temporary, go get some bumper sticker stock in a particular color to identify your section of the plant and cut it into little squares. You would have to do an initial cleaning to stick it on the parts, (quick wipe with alcohol or acetone), but once stuck on, the adhesive is pretty tough. If you need to remove them later, use a hair dryer to soften up adhesive and remove.
02/21/2011 10:46 PM
Put the parts in boxes that have tags on them or whatever you want to indentify the parts within. Move in the box and hope nobody puts the right part in the wrong box!
You did not say if your parts look the same, you also did not say what size teh parts are. More input will get better results!
Cheers Icke
02/22/2011 9:50 AM
Not sure what type of parts it is that you are trying to keep identified....but I know that our company has actually applied fluoropolymer coatings of different colors (orange, blue, green, yellow, etc...) to tools which go on oil well rigs. Tools are color coded differently for each level on the rig making it real obvious which tool came from what level. The fluoropolymer coatings are resistant to oils, solvents, etc...no problem. Thickness of the coating is very thin(Typically less than 1.0 mil thick) therefore no problems in fits, etc....The company is located in Houston, Texas and is called Southwest Impreglon Inc. You can do a google search.
Register to Reply 7 comments
Anonymous Poster (1); BruceFlorida (1); kramarat (1); lyn (1); RDGRNR (1); rhkramer (1); Viper18 (1)
You might be interested in: Parts Feeders, Parts Washing Services
