Previous in Forum: WW3   Next in Forum: Design of Vertical Falling Film Evaporator
23 comments
Ice Block
03/04/2011 10:58 PM
dear all, i have an doubt. An ice block submerged in the water, if the ice melts level of water will be? give suggestions. thank you
Re: ice block
03/04/2011 11:34 PM
"if the ice melts level of water will be"
Colder.
Re: ice block
03/05/2011 12:48 AM
Here are six suggestions:
a) The water level will rise.
b) The water level will remain the same.
c) The water level will fall.
d) None of the above.
e) Some of the above.
f) All of the above.
Hmm, a nice little multiple-choice test....
Good Answers: 34
Re: Ice Block
03/05/2011 2:34 AM
Van der Waals bonds
The bonds so far described have been strong 'primary' bonds, but weaker bonds are important, especially between molecules in fluids and gases. The bonding force is electrostatic attraction, but no electrons are transferred. Instead, the attraction results from uneven distribution of charge within the molecule. This asymmetry produces a small static 'dipole', combining balanced positive and negative charges.
In some cases, a distortion of the charge distribution between two adjacent atoms can create a weak 'induced' dipole in otherwise neutral molecules. However, higher bond energies are found between 'permanent' dipoles, where the charge asymmetry is built into the molecular structure. The most important example of such 'polar molecules' is probably water. In water, the hydrogen atoms are at an angle to each other, and not in line with the oxygen atom. As the electron sharing tends to make the hydrogen atoms more positive, and the oxygen atoms more negative, there is an in-built imbalance of charge, as shown in Figure 1.
Figure 1: The 'hydrogen bridge' after Shackelford 1999
The bond formed between permanent dipoles in adjacent molecules is referred to as the 'hydrogen bridge'. When water freezes, this bridge aligns the molecules into a regular and relatively open structure, which is why ice is less dense than water: on melting, adjacent molecules pack together closely in a more random arrangement.
Re: Ice Block
03/05/2011 10:48 AM
So, which is it?
Credit: Tornado.
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: Ice Block
03/05/2011 1:36 PM
Don't overthink it. Does water expand or contract as it freezes?
Re: Ice Block
03/05/2011 1:56 PM
If you take a look at some of OP's other questions, you may discover that he likely doesn't know the answer to your "good answer".
Good Answers: 146
Re: Ice Block
03/05/2011 6:01 PM
My own preference is to drink the water before the ice melts. Therefore my personal experience in the matter is of no help to the OP. Unless I can convince him to go ahead, drink some, and the level will surely fall.
incus opella
Re: Ice Block
03/05/2011 9:18 PM
Rather than leave everyone hanging in suspense, the answer is b) the water level stays the same. (Unless we do the artsmith thing and drink some of it!)
Good Answers: 137
Re: Ice Block
03/07/2011 2:51 PM
Tornado
That's only the case if the ice block is floating in water. OP may have meant that, but what he said was "An ice block submerged in the water" so presumably held underwater somehow. In that case the water level will fall.
Cheers..........Codey
Good Answers: 58
Re: Ice Block
03/06/2011 3:06 PM
Anybody that has experienced frozen pipes knows that water expands as it freezes. As the ice melts, the water level will decrease.
mike k
Re: Ice Block
03/06/2011 3:21 PM
Wrong.
It is true that the melting ice contracts--precisely into the volume of the originally submerged portion. This leaves surrounding water level the same as before.
Re: Ice Block
03/06/2011 6:32 PM
To be a bit on the criticism side, OP didn't formulate correctly the problem:
An ice block, frozen from the same water where is going to be immersed....
And now, if the final temperature in the container is 4 degrees C, at which water has maximum density, the level will decrease! For different temperatures, go to tables. (Where are our physicists?)
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Good Answers: 39
Re: Ice Block
03/06/2011 7:46 PM
You have a bucket of water.
You take a block of ice and completely submerge it in that water.
You measure the water mark on the bucket.
After the ice melts completely, measure the water mark again. It will be slightly lower. The volume will be less.
The volume of liquid water is 91% of the volume of frozen water. If you used a big chunk of ice, relative to the amount of water, the difference will be substantial.
Good Answers: 130
Re: Ice Block
03/06/2011 8:19 PM
Because it was resting on the bottom, or because the 'full system' is cooler, so contracted?
There is another good one like this, that involves a water filled flask and riser tube.
Good Answers: 39
Re: Ice Block
03/06/2011 9:01 PM
Not necessarily resting on the bottom, but due to the word submerged, below the surface, in any case; however it is kept there.
Since we don't know the original water temperature, the density of the water can't be taken into consideration. Although that would also have an effect, it would be minor compared to the phase change from ice to water.
Re: Ice Block
03/06/2011 8:33 PM
You just moved the goal posts. The original situation had the ice block floating, not submerged. The amount of ice above the water is the same amount that the block shrinks as it melts. Further temperature change could raise or lower the water level, but within the basic terms of the problem, it remains the same.
Good Answers: 39
Re: Ice Block
03/06/2011 8:50 PM
I don't believe I moved any goal posts at all. The original post reads thus "dear all, i have an doubt. An ice block submerged in the water, if the ice melts level of water will be?
"Submerged" is stated in the second sentence. The word "floating" is no where to be seen. Nor is it implied.
Re: Ice Block
03/06/2011 9:03 PM
Maybe I missed my target.
I doubt that we will ever know, but I bet that the OP's usage of "submerged" is not what he/she really meant. Who or what would be depressing the ice block until it was actually submerged? But given that interpretation, you are perfectly correct. Nice catch, and GA!
Good Answers: 39
Re: Ice Block
03/06/2011 9:12 PM
Thanx. But I'm thinking OP may have meant actually submerged for the following reason: He was trying to wrap his head around the fact that the level would actually go down; which simply seems odd and unnatural.
But we'll only know if he tells us his intent.
Re: Ice Block
03/06/2011 9:36 PM
You might be right about the OP's intent, but the submerged block problem seems too trivial to be of interest. The ice block melts/shrinks, so of course the water level goes down. That's just too easy.
On the other hand, for a floating ice block, it is tempting to think that when the block melts, the portion of the block formerly above water level then increases the water level. (I would bet that this is what the OP expects.)
Instead, the cute thing is that the above-surface protrusion of the ice block just matches the shrinkage of the ice block as it melts. (Unless further warming/cooling throws things off.)
Good Answers: 130
Re: Ice Block
03/06/2011 11:19 PM
Ok #13 was perhaps too 'cryptic'
In the scientific version; ice is added to a Pyrex vessel of water at room temperature. The ice is 'floating' or suspended by it's buoyancy.
The level is noted and contents left - usually covered to limit evaporation - and/or stirred to speed the 'system' returning to room temperature. The level is then noted and found unchanged.
"Unchanged" is therefore the science result.
If the question is alluding to polar sea ice and 'flooding' - the outcome will be substantially per the 'science result' for 'sea ice'.
Or a rise will only occur due to ice on land melting.
However in both 'World' and 'science'; at any other stage before 'room temperature' the level may be above or below the original due to temperature effects on the water body or vessel characteristics.
For example;
If one were to conduct the 'science' version using a - say aluminium bucket, a further distortion 'during' the experiment would be raised level due to the cooled bucket reducing in circumference - so volume.
If you were to add room temperature water to a bucket of -200C ice - the expansion of the bucket would give a 'lower level'.
As would evaporation, in a vessel left uncovered.
As would, in the 'scientific' version, if the solution attained 40C and the 'result' was taken at that point.
I hope this makes clear where and how, many strange opinions originate in "blog-science" and are repeated by "salubrity-scientists"
Re: Ice Block
03/06/2011 11:37 PM
Some of that was as clear as a bell; some was as clear as mud. Alas, the poor reader has to figure out which was which.
Good Answers: 130
Re: Ice Block
03/07/2011 5:59 AM
Ok, ok, so which is the "mud" bit?
Register to Reply 23 comments
34point5 (3); artsmith (1); Codemaster (1); indel (1); lyn (3); mike k (1); Out of Box Experience (5); Tornado (7); Whitephone (1)
