Previous in Forum: Getting Back Into Programming   Next in Forum: HTML Coding Help
Auto Range Selection of Column Chart by Macro
04/28/2011 2:43 PM
I am using a macro which plot a chart using macro in excel.
X-axis: machine no. & Y-axis : no. of motors
Range of X & Y is variable and may be 5 to 60 nos.
I want to plot a chart using macro by auto selecting the range without empty/blank cell.
How to plot a chart with variable auto selection of given data range?
Thanks
Pathfinder Tags: macro
Good Answers: 983
Re: Auto Range Selection of Column Chart by Macro
04/28/2011 3:47 PM
Ahem, maybe you should read the help notes for the application that you are using. In Mathcad auto-ranging is a simple function.
04/29/2011 3:24 PM
Websites below define how to make an automatic chart that resizes without a macro to match the size of the square of data.
You will need to use a named range and offset commands.
http://www.techrepublic.com/article/create-an-excel-chart-that-automatically-updates-with-new-data/6064314
http://spreadsheetpage.com/index.php/tip/update_charts_automatically_when_you_enter_new_data/
http://office.microsoft.com/en-us/excel-help/using-named-ranges-to-create-dynamic-charts-in-excel-HA001109801.aspx
Or you can use the result from offset command to define the square for the graph. You can use the result of that cell inside your macro to create a chart.
All truth passes through 3 stages. First it is ridiculed. Second it is violently opposed. Third it is accepted as being self evident. --Aurthur Schopenhauer
05/04/2011 9:45 PM
Thanks Smitch!
You have solved my major problem...
Very useful & perfect reply you have given.
Thanks
Register to Reply 3 comments
dhanesh.koshti (1); redfred (1); smith (1)
