Previous in Forum: Cars, Drivers, & Roads: Sharing the Responsibility   Next in Forum: Effect of Sulfur Content of Fuel to Diesel Engines
10 comments
Speedometer Stepper Motors
05/01/2011 3:24 PM
Were can I buy up dated speedometer STEPPER MOTORS for my 2004 H-2 Hummer.
My speedometer is stuck and starts working at 80 mph. I'm going to install the up dated Stepper Motors my self.
Good Answers: 88
Re: Speedometer Stepper Motors
05/01/2011 3:48 PM
You mean a:it doesn't return to zero and adds 80 mph to your real speed? Or b:it just doesn't move at all till you hit 80 mph. Different situations. Usally at ignition switch ON their controller has a routine to turn'em left till it finds a preset obstacle. So it can figure zero speed position and calibrate itself. If something makes it stop before (i.e. 80 mph) first case makes sense. Since you intend to dissasemble you could start on checking that. If the second is your case I wouldn't bother with it since problem looks much worse. Changing stepper won't do jack.
05/01/2011 5:30 PM
Hey Frend,
I mean, it stickes at 80 mph at a dead stop after running. (don't return to 0 mphh) From a dead stop at 80mph it works well up to 120 mph at about 2000rpm.
Thats why I thank I need a new up date Stepper Motor.
Thanks so much,
BF
Good Answers: 88
05/01/2011 6:25 PM
If stepper loses a step or more, MCU has no way to tell, so the error becomes "permanent" untill the next restart-calibration. If for some reason stepper stops and restarts, the position error would be mostly random. Having correct speed after dead stop is higly impropable. If this happens it's a sign that MCU for some reason was reset (possible powering problem) or just CW lost steps were more than CCW ones, so it calibrated by mistake. That's some clue to detect if the stepper is at fault. If yes I would first verify it moves freely. If it does, problem could be just a bad electrical connection or solder point typical for the Pb-free solder. Trying to replace stepper would be my last resort. S.M.
05/01/2011 9:35 PM
In order to tell that the speedo works above 80mph, you must have gotten this Hummer up to that speed...glad I wasn't there on the same road.
Good Answers: 137
05/02/2011 6:09 AM
And 120mph at only 2000rpm is pretty impressive!
06/04/2011 12:33 PM
You just an't right, At 0 mph (stoped) the speedo was reading 80mph, my Hummer was not moving. I hope you got it now.
05/02/2011 12:16 AM
Very unlikely that it's the motor. Stepper motors do not fail by stepping across part of their range. If they can step forwards, they can step back. There may be some mechanical blockage preventing full motion. Or there is something wrong with the controller.
Martin
Good Answers: 53
05/02/2011 12:39 AM
Is it possible that the pointer has slipped on the shaft? Repositioning the pointer is a simpler and cheaper fix than replacing parts.
05/06/2011 10:33 AM
Hi, GM used bad instrument cluster motors in all 2003-2006 SUVs, trucks, and in half of the cars they sold. It was not recalled as it was not considered a safety feature and the US gov agreed. Eventually all 7 motors (Gas gauge, pressure, temp, etc) will go. New Cluster sold by GM for 400+ or you can get repaired from $100 to $150. If you remove yourself and send away you can get for 90 plus shipping. No wonder GM is going under. There are currently 40+ flaky parts on GM model SUVs and Trucks 2000 to 2006 that tend to oddly go just after warranty is up. There are several companies that can repair the cluster and some just do an exchange and the vehicle can be driven without the cluster while it is out being repaired just do a google search for hummer speedometer repair or if you live in a larger metro area then you can look for a speedometer repair facility which can repair your dash for a lot less than a dealer.
Jim
05/08/2013 3:52 AM
Internet auction sites (name withheld) are ideal for solving problems like this. Get rid of it.
Ace Boeringa (1); b weaver (2); baxterm (1); Codemaster (1); Jspeop (1); PWSlack (1); SimpleMind (2); Tornado (1)
You might be interested in: Stepper Motors, Brushless Motors, Linear Motors
