Please see what I am proposing at tiltplane.com. This is a new rotorcraft technology which offers VTOL capability plus an efficient high speed cruise speed of 300 Knots or more.
This rotorcraft consists of a streamlined fuselage with one set of rotor blades at about 1/4 of the length of the fuselage back from the nose. The 4 rotor blades on the rotor rotate around the center-line of the craft. A second set of 4 rotor blades is positioned axially along the craft's length about 3/4s of the length of the fuselage back from the nose and also rotate around the center-line of the craft but in he opposite direction.
All 8 rotor blades support the craft when its axis is vertical and it is hovering or climbing vertically. When the craft is flying horizontally one can say that in a snapshot in time the craft is supported by 4 horizontal rotor blades. But in transitioning from vertical to horizontal flight it can be shown that at some point only two advancing rotors must support the craft. They can do this because their rotational velocity gets added to the craft's advancing horizontal velocity.
The wing area of an airplane is determined primarily by its weight and takeoff speed. The speed of the rotor blades for a tiltplane at their 0.7 radius is greater than the takeoff speed of most aircraft, so the total rotor blade area for a tiltplane can be less than the wing area of most aircraft. The result is that this VTOL aircraft can have a more efficient cruise than is found in most fixed-wing aircraft.
Comments?
