Previous in Forum: star delta   Next in Forum: Power Transformer Low Voltage Protection
3 Phase Compressor
07/06/2011 3:40 PM
Dear friends,
Please share some knowlede about 3 phase compressors. If by mistake changed the phase sequence of a compresor then it,s direction will also be changed. I want to ask that what will happend when compressor changed the direction. And how we could know that it,s direction is right or wrong. Could be a 3 phase compressor internaly thermal protected? If yes then definately it will be protected on all 3 phases? Not 1 or 2 phases?
If any 3 phase compressor is not starting and it,s 3 lead,s are showing open(no continuty). So how can we knw that it,s winding is flashed or it,s internally overload is triped.
Thank,s and regard,s.
Ikram Shehzad
Good Answers: 53
Re: 3 phase compressor
07/06/2011 4:13 PM
If the compressor is a single stage recip rotation direction may not matter. If it is multi stage, or scroll then direction does matter.
A 3 phase motor could be equipped with integral thermal overload protection. If two were open, would they not all indicate open?
Did your compressor come with a manual? If not the manufacturer might provide one to you. Reading the manual might be a good place to start.
Re: 3 Phase Compressor
07/06/2011 5:40 PM
07/06/2011 10:42 PM
re your tag - dilligaf works for me too - there is a song about it to
'Nunc est bibendum'
Register to Reply 3 comments
Ace Boeringa (1); crashcol (1); Kilowatt0 (1)
