Previous in Forum: Water Hammer - Software Called AFT Impulse   Next in Forum: High Vibration in Steam Turbine
Efficiency Calculation - Flue Gas Analysis
08/23/2011 2:59 AM
Can some body told me how to calculate the efficiency by flue gas analysis?
Presently we are following mcp(T2-T1)/ heat input.
Any other alternative method can be follow?
Pathfinder Tags: Energy
Good Answers: 19
Re: Efficiency Calculation - Flue Gas Analysis
08/23/2011 10:53 PM
Buy an flue gas analyzer which does everything after measuring all flue gas %.
A Fyrite Boiler Test Kit from Bachrach will give you Co2/o2/Co/Temp/Draft/Smoke # etc., use your formulas to manual calculate or the slide-rule which comes with it will indicate efficiency %.
08/27/2011 2:16 PM
Dear Mr. gMathur189,
There is an error in your question.
T1 and T2 will be Temperature, and Heat is in K.Cal. or Kilo Joules and different from Temp,
Pl. be clear in question.
rajeswari
Register to Reply 2 comments
