This is kind of a "back of the envelope calculation" type of question. I'm not trying to get homework solved, or avoid hiring a civil engineer (that requirement comes later), but rather to get some ideas as to the cost of what I'd like to do.
I pretty much have a full-blown earthmoving and construction company's equipment at my disposal, including a 50-ton reach-stacker, a concrete mixer with a 100 yard-per-day capacity, dump trucks, backhoes, bulldozers, several semi-tractor-trailer rigs, a really well equipped workshop (120 x 80) and a 15-man crew who are pretty creative and really hard-working.
What I want to do is build a few underground houses. The basic design is to use High-boy shipping containers as the "building blocks". Stacked 2-high on a properly footed concrete pad, 6 40' containers on each side with a 24' space between the two rows of containers. Front and back of the house will have a row of stacked containers running perpendicular to the two rows of containers. The end result is a 2-story house that's 72' by 56'... and I want to bury it. The location is about 20 miles north of Lexington, Kentucky.
Support for the roof would be the perimeter wall and 2 supporting walls at 24 foot intervals running front to back the length of the house. I'm aware that shipping containers aren't going to support the weight of the roof, but the perimeter wall will be reinforced concrete with reinforcement steel welded to the exterior of the container walls, and an integral outer form made from steel taken from the shipping containers, again with the rebar welded to make this an integral wall filled with concrete. Same technique with the inner support walls.
In order to accommodate the 24' span across the "great room" in the middle, I want to precast some double-T support panels and place them across the top of the supporting walls and then pour a monolithic pad on top of that to join it all together and finally cover it with about 3 feet of earth.
I've done some simple calculations and I figure that if I make the double-T panels 4 feet wide with supports on 2-foot centers (these are 72 feet long) that I can have 18 inch support beams underneath and I'll be using about a thousand pounds of steel in each panel.
Figuring the height of the two containers to be 20 feet, how thick do I have to make my perimeter wall? Given that it's a steel-encased retaining and support wall, I was thinking that this didn't have to follow the old rules of thumb which would say that I need a 1-foot thick wall around the perimeter. The two interior support walls would likewise be formed with steel on both sides, reinforcement welded to the steel sides. Should they be the same width as the perimeter walls?
With those double-T panels and an additional pad poured on top of that, I'm looking at about a 10-inch concrete pad on top with 4" x 18" support beams below that on 2-foot centers. Lots of rebar and mesh. A lot of weight. On top of that, sits about 3 feet of earth, although that could be modified to 2 feet. The roof has to support light tractors and cows wandering across from time to time... It would be wonderful if we could increase the great-room's size to 30 feet wide, but at some point it becomes cost prohibitive.
The issues for me are the costs of the concrete, steel and containers. We can make concrete for about $60 a yard and we can get the containers for about $2000 each. Steel looks like it's about a $thousand per ton at the moment. Labor is not considered (think Habitat for Humanity) because it's a community thing. The houses are huge because they are for families with 8-10 children. These are farm dwellings, exempt from the building code in Kentucky.
We want to use shipping containers because we can pre-install all the wiring and plumbing, insulation, drywall, etc., in a central workshop, along with all the rebar welded to the exterior. When they're ready, we haul them to the site and weld them together. By having the form for the exterior perimeter wall already welded into place, we can use much closer tolerances in terms of the excavation. We can pre-cast the support panels at the shop and let them cure under controlled conditions prior to installing them. The idea is to be able to have everything ready, and then throw a modern-day version of an Amish barn-raising.
The major goals of the project are to have housing that is very low-cost in terms of both construction and later in terms of heating and cooling; safe, secure, sustainable and which blends in with the rural environment. We're building for the generations to come. One of the alternative floor plans has 11 bedrooms, 8 full baths, 4 water closets and in the words of the guy who drew it "would be perfect for a family reunion in about 20 years.... I figure we'll have about 40 grandchildren by then..."
Any thoughts? Am I off in the size of the support beams? How much of an additional pad do I need to pour on top of them? How thick should the support walls be? What kind of foundation (heavy clay/shale soil) would I need underneath the support walls?
This is in the design phase at the moment, so I can plan to cast columns and support beams if needed, but that changes the requirements for the foundation and it goes from there. Nothing is "set in stone" at the moment except the need to keep costs down. Free labor and all the available equipment is really helping in that respect, but I must be able to make some reasonable estimates.
I'm looking for basic ideas and figures. If we go forward with this an engineer is going to have the joy of doing all the math and getting the pencil sharpened for exact answers... and then stamping his seal all over the plans. He can even have the Droit du seigneur for the house if he wants it.... Right now, I'm just looking for cost estimates and that relates directly to the amount of concrete and steel I have to put into this. I do have experience building underground homes, just never anything this big.
Thanks
Brian
