Does anyone know of any manufactures out there who make equipment to sort "bottles" of TiO2 (Titanium Dioxide) and PET (Polyethylene Terphthalate) into two different streams?
Are you referring to a mix of clear PET bottles with other PET bottles that have been colored white by adding TiO2? If so, the answer to the OP's question is simple: put a photo-emitter on one side and a photo-detector on the other side of the bottle stream. The white bottles will scatter the light so less gets through. Another option would be a carefully placed sensor on the same side of the bottles as the emitter to detect the scattered light - the clear bottles will let the light pass on through or be reflected in another direction, while the white ones will scatter light to the detector.
Dick
