Previous in Forum: Severe Service Control Valve   Next in Forum: Pressure Switch or Flow Meter?
9 comments
How to Determine RPM of Compressor Shaft
10/08/2011 10:43 PM
Anyone have an idea how to measure and display RPM of the compresor shaft onour machine?
Re: how to determne RPM of compresor shaft
10/08/2011 10:56 PM
10/09/2011 12:10 AM
Nope, I haven't the foggiest idea how to measure or display your compressor shaft rotation. I've searched three times for an "onour machine", an "honor machine" and even an "honour machine" but have not found anything that resembles a compressor. So I have no idea what your compressor looks like or the environment and room you have for instrumentation. For all I know your compressor could be a scroll compressor for a refrigerator, a roots type compressor for an intake manifold, a reciprocating piston compressor for compressed air or any of the myriad of ways that humanity will compress something.
Now along with the optical method that kramarat provided links for, you might also consider attaching a magnet to the shaft and as the magnet pole crosses the windings of a coil the voltage induced will be linearly related to the velocity of the magnet. This will provide an instantaneous measurement instead of an average measurement.
I have no idea what you want, but I do have an idea of what you need.
10/09/2011 12:45 AM
Tachometer.
Motor rpm times drive ratio.
10/09/2011 5:19 AM
What isyour machine?
10/09/2011 6:45 AM
Put a line of white or black paint on the shaft, then use a stroboscope:
http://www.ehow.com/how_5021934_use-strobe-light-measure-rpm.html
Good Answers: 804
Re: How to Determine RPM of Compressor Shaft
10/10/2011 9:57 AM
Lick your finger, touch it to the spinning shaft using 3.62 lbs of pressure and hold it there for 6 minutes. Then use an infra red scanner to measure the temperature of your finger tip and look up the yards-per-degree-F on the finger tip temperature coefficient of friction chart on page 398 of the infra red scanner manual. Punch that number into your PC and display it in a spreadsheet that converts YPDF to RPM by using the circumference of the shaft divided by the YPDF x the 6 minutes. Note: if using metric values, hold for only 5 minutes because of the 50Hz speed.
10/10/2011 10:31 AM
But what if he's a diabetic and there's less sugar in his saliva?
Good Answers: 804
10/10/2011 6:19 PM
Adjust for finger stickiness with the SGI (Salivary Glycemic Index) quotiient.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
10/20/2011 9:15 AM
The last time I laughed this hard at a CR4 post was when someone asked for help getting a "pneumatic hooter" to work! Thanks, you brightened my day!!!
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Register to Reply 9 comments
JRaef (2); kramarat (1); lyn (1); redfred (2); tonykuphaldt (1); Tornado (1); Usbport (1)
