Previous in Forum: A Valuable Service for Humanity   Next in Forum: Applied Math
63 comments
What is it?
10/09/2011 7:36 PM
This is a steel (not lead) ball that one of the boys found in the yard. The diameter varies from .999" across the gates to 1.043 across the parting line. There are gates/sprues on both sides which leads me to believe that it was cast in some type of gang/multi-cavity mold. There is one at 7 o'clock in the photo. It's about .25" in diameter. Both sprues are broken off and no post-finishing is apparent. It's pitted and rusty and this is the desert.
I can't get a closer shot of it in focus. I'll try another camera tomorrow.
What is it?
Re: What is it?
10/09/2011 9:41 PM
Part of a ball valve mechanism from a kitchen faucet?
Re: What is it?
10/09/2011 9:45 PM
Don't think so. The parting line and sprue marks are still there. Unless it was overmolded with polymers. No holes, either. No way to control it.
Good Answers: 179
Re: What is it?
10/09/2011 10:37 PM
Possibly a "raw casting" of a steel ball bearing that never made it to final finishing?
Just curious where you're located and if any steel machining/manufacturing ever occurred in that locale!
Can't wait to see a close up shot of the steel ball.....
Re: What is it?
10/09/2011 10:46 PM
No clue of the source, it wasn't native to this area, as far as I know. No marks of any kind that would indicate any post-finishing.
Remember, I'm in the land of many guns, wide streets and narrow minds, Mesa AZ.
Good Answers: 204
Re: What is it?
10/10/2011 1:55 AM
65 million years ago.. the earth was struck by a small moon, which ripped the earth in half... and scattered small spheres of melted rock and metal everywhere...
okay, probably not the source, but you never know...
but perhaps if you test the metallurgy (milo?) you can figure out what sort of process formed it. (cast, forged, recipe etc.)
cheers,
Chris
Re: What is it?
10/10/2011 3:28 AM
In Cat terms it's what we know as a 'play with' or 'roundy thing' .
Or more technically a
'Non specific prey simulator / sensory & coordination enhancement device'
Re: What is it?
10/10/2011 9:08 AM
To PlbMak it will be a thing of great wonder that it didn't appear in a Friday afternoon picture quiz.
Good Answers: 179
Re: What is it?
10/10/2011 9:26 AM
lyn, sometimes steel shot is used in a tumbler to break down minerals into powder form, such as limestone used for cement products, borax, talc, garnet, some metals/ores, etc. And sometimes they're used to help polish gemstones
Are there any active or closed mineral processing mines near to you? Even an inactive cement plant?
How much corrosion is present on the surface? Any pitting observed? Due to the low humidity in your area the amount of corrosion, or lack thereof, may help determine or narrow down the age of the steel ball.......
Just a thought!
Re: What is it?
10/10/2011 9:34 AM
It could be from a ball mill. That's a definite maybe. However, it appears to me that it was never used as such because the two sprue marks and the parting line are still well defined. The surface gives the appearance of having been glass beaded or lightly sand blasted. It's rusty, like it's been outside for years.
There is a cement plant about two miles from here, but nothing closer since we've lived here. That's 36 years.
I'll try to send a clearer picture later.
Good Answers: 130
Re: What is it?
10/10/2011 11:15 AM
Just a thought
Re: What is it?
10/10/2011 11:25 AM
What a load of balls...
Good Answers: 130
Re: What is it?
10/10/2011 11:38 AM
Have to hurt
Re: What is it?
10/10/2011 1:30 PM
Dimensions don't tie up with the image
Good Answers: 130
Re: What is it?
10/10/2011 3:07 PM
They're American Imperial
(but you'd think they would at least break down that improper fraction to 1.8125")
Re: What is it?
10/11/2011 9:47 AM
Butt its aspect ratio is all wrong - should look more like this: or this:(depending how improper they're being).
Or mebee it should have "Image representative of range only" somewhere near the pic.
Good Answers: 130
Re: What is it?
10/11/2011 9:53 AM
Ummm - it should, shouldn't it. Much better looking. I wonder how much better it would look in metric?
Good Answers: 299
Re: What is it?
10/10/2011 3:06 PM
Three questions:
1) How cold does it get down there?
2) Have you seen any brass monkeys hangin' around? If yes, do they seem unhappy?
3) Is there only one?
[edit] Post Script: I wouldn't put it on the kitchen counter!
Re: What is it?
10/10/2011 6:43 PM
OK,
it's 25.40mm across the sprues and 26.1/26.3mm across the parting line.
I'll post the other picture here, now that I can.
No brass monkey balls, and since it's not lead, I doubt that it's a mini ball. You can pick it up with a magnet.
So far the ball mill charge seems most likely, although I've never seen mill balls that were unfinished like this is. I may take it out to the grinder and take some rust off it later. Maybe grind a small flat on it to see what the metal looks like.
Later.
Good Answers: 179
Re: What is it?
10/11/2011 9:30 AM
lyn, please don't take your grinder to that ball, as you may damage it. Instead, use a rust remover of some sort.
You may want to contact the local historian in your area to ascertain if this ball may have been manufactured or used in some industrial processing plant somewhere in your region.
Or, you may want to contact a museum that deals primarily with industry and the industrial revolution? May even want to contact the Smithsonian and get there take on the steel ball.
I doubt that it is a mini-ball or a musket ball, as those were generally made of lead, not steel....but hey, you never know!??? Take it to a local gun shop, especially one that deals with antique guns and see what they think it is.
Re: What is it?
10/11/2011 10:40 AM
I've decided agains any modification, at this time, even rust remover.
Good Answers: 117
Re: What is it?
10/10/2011 10:27 PM
Ball joint off a 47 Ford pick up truck.
No wait, its too small for that. A 42 Ford pick up truck.
Re: What is it?
10/10/2011 11:47 PM
It's just one of Pluto's Moons that made it to Earth. That's all.
"Real Bass Players" do not use picks
Re: What is it?
10/11/2011 12:43 AM
it looks to me like the mill balls in this link
here
Good Answers: 22
Re: What is it?
10/11/2011 12:49 AM
I don't know what it is, but I've got one too!
OK, mine's a bit different, but it's got a pretty weird back story.
When I was a teenager my parents cut down a 100+ year old English oak tree that was taking up much of their garden. I got the very large job of cutting it all up for firewood.
Anyway, I split one of the big logs and there, somewhere in the middle of the tree, was this steel ball - about the same dimensions as yours - a little smaller.
As you can see in the pictures, I kept the bit of wood that had grown around it.
I have included a ruler in the pictures (one side of the ruler had these really funny units called "inches" on it ?? weird huh? - I included those too for a laugh).
The ball, like yours, is attracted by magnets, but this one has a spike on it which I think is the rusted remains of a steel dowel - like a thin handle - coming off from one point.
So this doesn't solve the mystery, but adds a new mystery Australian dimension...
Re: What is it?
10/11/2011 12:55 AM
How astronomical are the odds that you would have split the log in such a way that it was exposed?
Interesting story. Thanks for sharing.
Re: What is it?
10/11/2011 3:46 AM
could it have fallen into the crotch of the tree decades ago and then the tree grew around it? could it be from something that was hung on a tree limb and this item may have fallen off it? it looks like a tack, possibly from a saddle or harness. is it silver plated? count the growth rings from it's original location going outward to determind the time period.
Re: What is it?
10/11/2011 5:36 AM
This one seems to have been nailed to the tree, which then grew around it.
Good Answers: 179
Re: What is it?
10/11/2011 9:35 AM
"AN ALIEN IMPLANT"?
Re: What is it?
10/11/2011 10:36 AM
Are you suggesting the tree was abducted?
D.G.
Good Answers: 299
Re: What is it?
10/11/2011 10:27 AM
RobertOz, I think I know what you have. The fact it was stuck in a tree and forgotten supports this wild a$$ guess.
From the images, It appears the 'ball' part is closer to the bark. If so, it very much looks like a screw starter used by loggers, timber cruisers, tree trimmers...
If a steel hook or eye needs to be threaded into a tree, a worker will take the starter and, with a swing of the arm, pierce a deep starter hole into a tree. This makes turning the wood screw in quite a bit easier.
All this assumes an amount of the spike has corroded away; the remaining spike is much too short in the images. Can you confirm?
Good Answers: 22
Re: What is it?
10/11/2011 11:58 AM
That makes sense (except that it was in a garden - cheeky loggers!)...
But yes - you can see in the wood a trace of where the remainder of the original spike was...
I'll do some reseach on that angle - it's been a mystery for a few years now!
Thanks
Robert
Good Answers: 15
Re: What is it?
10/11/2011 1:45 AM
It may have been a working design model of prosthetic devices needed by the current American president.
For every action, there is an equal and opposite criticism.
Re: What is it?
10/11/2011 3:02 AM
Howdy, off hand, due to the lack of any kind of post casting tool marks, i would say it resembles the steel shot from an old naval shell, I.E. exploding round, "grape shot" type of ammunition, are there any old military installations near your area? Or a train station, maybe it got lost in transit? Also, it could definitely be from a ball mill, excess stock that was never used? Anyways, interesting find, goodluck!
Re: What is it?
10/11/2011 5:51 AM
'one of the boys found in the yard' -as in children?
This type of unfinished ballast can be found in children's toys, as in 'weebles wobble but they don't fall down'
cnc
Re: What is it?
10/11/2011 10:44 AM
Yes, as in children. Three boys, 5/7/12. There's not much they can't take apart. I'll see if I can find a weeble to mutilate, if it looks like it could be the right size. I realize it could have come from any number of toys.
Re: What is it?
10/11/2011 8:42 AM
Lyn, I'm sure that is remanence of a Super Nova from billons of years ago!
It's not Rocket Science
Re: What is it?
10/11/2011 11:21 AM
From your photo it appears to be iron ore. Have you considered that? If there is a train track close by, they are mounded in cars and lots of the ore falls off as they travel.
Good Answers: 123
Re: What is it?
10/11/2011 11:29 AM
Bob
Re: What is it?
10/11/2011 12:18 PM
Ball mill balls for processing Borax or some other mineral in the Southwest. Looks like it has been discarded in some way, stolen for later sale, or possibly rejected for some reason. Aged look tells a story, very common occurences, have seen often, & aging appearance confirms my thoughts. Any inventory on quantity also can mean a lot. Any RRs or truck routes in the vicinity.? I really do see things like this a lot around mining sites that use crushers and/or ball mills at the source of attraction. Sell them as an oddity, with a bit of color history. I have even did that with sintered iron ore. Milo, are resident Metals Guru will probably agree, Milo, call me & we can do a lunch on Shell's ticket before I leave Holmes County within the month. Respectfully. Don "Luigi" qaqcpipeman
Re: What is it?
10/11/2011 1:16 PM
It's from a ball mill
Re: What is it?
10/11/2011 1:17 PM
If you put it on the grinder and it appears too grainy consider this: http://en.wikipedia.org/wiki/File:TaconitePellet.JPG
I used to see them in lots of sizes when I was a kid. Kept a bunch for souvenirs but they are all gone now. Most of the ones I had were right at one inch in size. They all had parting lines.
Re: What is it?
10/11/2011 1:37 PM
Mine is obviously cast in a mold.
Good Answers: 130
Re: What is it?
10/11/2011 5:05 PM
Just curious - could that 'sprue' be a broken screw?
Re: What is it?
10/11/2011 5:12 PM
Interesting point.
BTW - you any good at crosswords?
Good Answers: 130
Re: What is it?
10/11/2011 10:36 PM
I'm astounding at crosswords - given a scribe who can spell.
Re: What is it?
10/11/2011 10:50 PM
Be sure to use the "monkey guy" as your scribe.
Good Answers: 130
Re: What is it?
10/11/2011 11:06 PM
Heheheheeeee - Slowly, slowly catchy 'Z-logik' monkey - as they say.
Re: What is it?
10/11/2011 5:24 PM
Don't think so.
There's a duplicate feature on the other side which leads me to believe that there was more than one cast in a multi-cavity mold.
Good Answers: 130
Re: What is it?
10/11/2011 10:50 PM
Ok. only asking because in the pic it has a different hue/crystal/texture/feel, to it, like mild steel verses wrought iron. Have you got a hardness tester handy by chance?
Re: What is it?
10/11/2011 7:46 PM
Could be a musket ball.
Re: What is it?
10/11/2011 7:50 PM
It's iron, steel.
Re: What is it?
10/11/2011 7:57 PM
It is a steel ball that one of the boys found in the yard.
Re: What is it?
10/11/2011 8:00 PM
Right! Good job. Thanks.
Anonymous Poster #2
Re: What is it?
10/12/2011 11:29 AM
It looks like a Tuit.
A procrastination prevention device.
Most of us are familiar with the phrase:
"I'll do it when I get a round Tuit."
Re: What is it?
10/12/2011 11:24 PM
Looks like a mill ball to me?
Regards JD
Re: What is it?
10/12/2011 11:54 PM
Me too.
Re: What is it?
10/13/2011 1:21 PM
As Zork returned to his home planet millenniums ago after a weekend bender. He told his story, how he graffiti these big pictures on the ground in the southern hemisphere, draw pictures of space ships in the Mideast. and then unloaded his spent fuel balls through out the planet.
What a character.
Re: What is it?
10/13/2011 1:55 PM
I was with ya till the spent fuel balls bit......
As Zork was probably a Vogon sent to earth to lay out an intergalactic highway construction project...It is a safe bet that that he dumped his waste processing chamber's contents before hitting hyper space .....
That right you got an ET turd in your hand....
Cheers,
Eric
Re: What is it?
10/13/2011 2:02 PM
Tastes like an iron ball to me.
I'm thinking ball mill charge or very remote, but maybe grape shot.
In reply to #59
Re: What is it?
10/13/2011 2:31 PM
Concidering what Vogons eat it should taste like iron...
YUCK!
Ciao,
Eric
In reply to #59
Re: What is it?
10/13/2011 2:47 PM
Actually Zork mentioned he acquired a pet from planet ozmo which he named "Dumper". Zork complains that he has to walk Dumper often. Dumpers diet is rich in iron.
guess why they named it Dumper?
Is that a iron ball eatin grin I see on you?
Good Answers: 123
Re: What is it?
10/13/2011 2:53 PM
I remember an old line that went.."How did you get their legs apart?" Does that fit here?
Bob
In reply to #59
Re: What is it?
10/13/2011 7:01 PM
Looking at your 2nd photo (at #16) and jdretired's (at #55) - I reckon jdr's cracked it. GA to him.
Register to Reply 63 comments
34point5 (8); Anonymous Poster (1); Beenaround (1); bob c (2); brettj1au (1); CaptMoosie (4); chrisg288 (1); cnc jim (1); Doorman (2); Ducdude (2); dyfedg (1); engineertony (1); Gazu (1); genemdragon (1); jdretired (1); Jimh77 (1); JohnDG (4); Kalboon (1); lyn (13); phoenix911 (2); PWSlack (1); qaqcpipeman (1); RobertOz (2); Rockyscience (1); silvCrow (1); StandardsGuy (3); Usbport (1); user-deleted-1105 (2); Yusef1 (1)
