Previous in Forum: Automotive Origin of a GM Hyster Forklift Motor   Next in Forum: My 2000 Cavalier Will Not Start When Being Pulled
29 comments
Good Answers: 52
Perplexing Car Problem Solved!!!
10/23/2011 11:56 AM
For those that didn't read it I posted a question to the forum about a car problem that we just couldn't seem to solve where the engine wouldn't start and then would run backwards.
Well the problem has been solved the car is now running, and while some of you were off the mark, some of you had the right idea.
Let me start off with what it was not.
It was not the valve timing
It was not the spark timing
it was not the timing belt
It wasn't timing related at all, let me repeat that, IT WAS NOT THE TIMING, I told you we checked it.
It was not the computer
It was not the coil
It was not the ignition module
It wasn't the hall sensor
It wasn't the cam position sensor or any other sensor for that matter.
It wasn't the distributor cap
It wasn't the gear driving the distributor or anything timing related as I said.
It wasn't the plug wires
It wasn't the spark plugs
It was not the starter switch
It was not the starter motor
It was not bad fuel
it was not the injectors
it was not the fuel pump or pressure
It was not the exhaust or pressure building up from that
So what was it? well if you thought it was related to the spark you were close even though it appeared healthy. As I said it wasn't the coil or igniting module or hall sensor. If you said something about a resistor in the distributor you were close. We did however measure the resistor in the rotor with an ohm meter and it was spot on.
Well it turned out to be a defective rotor that costs about $5 that although it was new was causing the problem. It wasn't the resistor in the rotor, it was arcing over from the top to the metal shaft that turns it.
When the car was running but missing he replaced the cap, rotor, plugs and wires. He knew the wires were not that good so he was surprised when that didn't solve his problem, so he then went on to replace the coil and ignition module with no change.
What he didn't know when he replaced that stuff is that while he solved one issue with the wires, he caused another issue with a faulty rotor.
The problem was discovered when he used a device with an adjustable gap to measure how far the spark will jump. He noticed that it jumped a large gap no problem when connected directly to the coil, but not that far after the distributor.
This time he got a different brand rotor as he didn't trust the same brand, put it in and the car started right up.
So to answer my own question, for his car at least it appears a properly timed engine can in fact run backwards for a short time if the fuel comes from the exhaust side.
I will now leave you with a picture of the part that caused all the problems.
Re: Perplexing Car Problem Solved!!!
10/23/2011 1:13 PM
Frank, well done, glad its solved. I have seen faulty rotor arms cause big problems before. However, there is a big lesson here for your mates. Do not go on a wild replacement spree. one thing at a time and check properly first. You posted that the car had been on an oscilloscope. If the mechanic had checked the peak voltage attained when a plug wire was pulled he would have quickly found a high tension leak. Finding the cause shouldn't have taken long. I agree the symptoms must have seemed bizarre but simple tests on a scope could have had him started in 15 minutes. Change the mechanic! Good luck to all, Richard.
Good Answers: 52
10/23/2011 4:18 PM
We did check the voltages on two different scopes and it checked out, I imagine this was more current related which is not as easy to check for high voltage.
10/23/2011 5:15 PM
Frank, absolutely not, tracking and tension leak is voltage related. The resistance of the leak would have to be less than the correct route ie the rotor arm to distributor cap gap, the plug leads and the spark plug gap otherwise it wouldn't take it. A non leaking circuit would show a markedly different High tension and primary circuit trace on an oscilliscope than a leaked circuit which would necessarily show a lower peak voltage than normal. Richard.
Good Answers: 52
10/23/2011 7:32 PM
Richard, while I am sure you mean well I have found some of your comments to this question and to the solution to be a bit insulting. I am sure you know your stuff, but we do know most of what we are doing. I guess I can't take this too personally since this wasn't my car, my money and I did not perform most of the tests, but I did do some and watch many of the others. In addition from the beginning I asked for ideas that were not timing related since even then we suspected it was not timing, but all your comments are about timing, and to be fair a lot of other people did the same.
Just to point out some things below are some quotes from your replies and some comments I added.
You said "This engine does not have a crank position or speed sensor it uses a Hall effect sensor in the distributor."
This is incorrect it has both which are used by the computer as inputs to calculate the timing.
You said "The guy says the plugs are all sparking. It is not an ignition issue. It is clearly a timing issue."
The plugs were firing so obviously this statement was incorrect, and so you discounted the ignition from the beginning, we did not.
You said "No computer, just an ignition module."
Without knowing the exact car which I wasn't sure of when I first posted, their is no way you could of known this.
In reply to me asking about a properly timed engine running backwards you replied as below, yet the engine is properly timed and this is exactly what happened.
You said "Frank, no not in any normal circumstance."
You said "If these people posting don't understand the first principles of an engine then why post?"
You said "Don't want to make obvious comments but one can clearly see from the cam pictures that the firing order is 12453 yet the protractor fitted to tha crank pulley is marked 153... Have you got your plug leads back to front too?"
You said "Trevor and Frank, please disregard my last Post. It was the sort of C**p I normally accuse others on this thread of talking. Trevor is correct; the firing order looks good. Richard"
You said "Finally, if you can't get your mates mechanics to get it going tell your mate he needs a decent mechanic. If he wants to buy me an air ticket from the UK and pay expenses I'll get it going for him in 30 mins max."
To be honest I seriously doubt this as it is obvious you would of focused on the timing for well more than 30 mins.
As I said we did measure the voltage very early on, this test did not escape us, I don't know what else to tell you.
I make no claim of being a great car mechanic but I do know a thing or two. I am not one to argue and I don't know where we go from here on this topic so this is the last and only comment I will make to you about this.
10/25/2011 2:25 PM
Frank, only just picked up your reply to my post. Basically I would stand by nearly everything I said. Obviously not the firing order post which was careless of me. You did say that the voltage had been checked at the sparking plugs and that they fired. "A multi channel scope connected to all plug leads" But, the voltage could not have reached a decent peak and in fact, I think you said that the mechanic had eventually found it by testing with a variable spark gap tool and finding that the voltage was low. However, I would not have wished to offend you so please accept my apologies if I have. I haven't knowledge of any Volkswagen Audi vehicles which use an engine management computer that controls the ignition by using Crank speed and position sensors together with an Hall effect distributor based system. Why would it? and what model is it? Glad your sorted anyhow, Richard.
10/23/2011 1:58 PM
Thanks for getting back to us frank. Glad it's fixed.
I've been there and done that. There's nothing that can cause more frustration than buying and installing a new part that's bad.
Good Answers: 11
10/24/2011 12:29 AM
I hope that you guys applied a sufficient quantity of dielectric grease this time to prevent the arc-over. It's also good to put about the seal of the cap and the spark plug covers to keep them from arcing to ground.
Wish I'd seen this post earlier before you paid a kings ransom in parts.
10/24/2011 2:56 AM
Couldn't disagree more with the last poster. Clean all high tension wires and components scrupulously. Around the coil nose and inside the cap and rotor arm etc and leave it at that. I always used to use brake cleaner and an air line to clean these components and it was done to every car that came in for service. Grease, damp proofing etc, just leads to dust and dirt collection; the next voltage leak route. We are lucky nowadays that so many of these components have been eliminated from the ignition train.
Good Answers: 70
10/25/2011 10:06 PM
I couldn't agree with you more, people get way over zealous with the dielectric grease and then wonder why after 2500 miles on their last tune up, their car lacks power or it starts missing. My Golden Rule with distributors with rotor caps, is to look in the shaft bore for signs of grounding. I use to make a lot of money rebuilding GM HEI distributors from people not changing the rotor caps or using inferior rotors and seizing the inter-shafts. $75.00 for 1/2 hr of work that included R & R, that was over 30 years ago and people were thrilled to pay it, too.
10/24/2011 6:38 AM
why would you start a new thread?
anyone who cares is following the original
http://cr4.globalspec.com/thread/72939
Good Answers: 52
10/24/2011 9:32 AM
The number of comments in the old thread was high, and I felt that my post of the issue being solved would get lost since you have to go back and find the post and then go to page two of comments just to see I posted anything.
I did post a link in the original to this post, and I posted a link in this post to the original question.
10/24/2011 9:42 AM
Why is finding a new thread easier
than having a email announcing a new post directed to everyone who is interested [subscribers]?
Good Answers: 52
10/24/2011 10:16 AM
Really you want to argue about this? because I have no desire to. Consider it a matter of opinion, I will agree to disagree.
10/24/2011 11:43 AM
great that you figured out what the deal was & want to share the good news with
the subscribers to the original thread
consider this education about the nuts & bolts of the forum, not an argument
you can't disagree with reality...
Good Answers: 123
10/25/2011 9:35 AM
"consider this education about the nuts & bolts of the forum,"
Hey, while you are sprouting the rules and regulations covering forum use here, could you please cover the section that deals with no name, no backbone posters that don't have the eggs to write some made up name here.
Bob
10/25/2011 9:44 AM
Good Answers: 123
10/25/2011 9:48 AM
No, not that one, the one about the no name...............
Bob
Good Answers: 70
10/25/2011 10:31 PM
I'd give you 2 GA's if I could! I usually don't give Anonymous Poster's much merit or credibility, it seems that they're either to embarrassed about what their posting or they don't want people to know what fools they can be. I was going to post this as an AP, but I'd rather own up to it.
Good Answers: 123
10/26/2011 9:21 AM
Thanks for the support!
Bob
10/25/2011 9:44 AM
Starting a new thread worked out well for me. I had stopped checking the original, because the posts were becoming redundant and boring.
I don't understand what the big deal is.
Good Answers: 70
10/25/2011 11:20 PM
He couldn't find his Heli-coil kit, why else would he start new threads?
10/24/2011 6:43 AM
Congrats on getting that beast working. I just thought of something. I had an ignition problem and it was a lttle different in that the cables were arcing across, but I looked at it as someone cranked the car over in the dark. I'll bet you have seen the unusual arcing within the rotor cap and narrowed it down a lot quicker. Again glad you got it working. Sounds like you now have a good story to tell at the local bar.
Good Answers: 52
10/24/2011 9:34 AM
We did crank it over in the dark, since the rotor is inside the cap and the ark was going through the plastic of the rotor to its center there was no arc to be seen.
10/24/2011 7:30 AM
Congratulations on the final solution to your friend's Audi problem. The distributer was always the main suspect and people are always surprised at how 'sneaky' high- voltage can be in finding a weak path to earth. I made a Scorpio electronic ignition system a few years ago and put too many turns on the transformer. As a result I had sparks jumping from the top of the coil to the car chassis and had to scrap the project as it was too dangerous to use!
Good Answers: 123
10/24/2011 9:15 AM
See, I told you the crankshaft was bent.
Seriously, I am glad you solved the problem, and even more pleased that you took the time to reply to those of us that were trying to solve the problem. Just another thing. The early GM HEI distributors were very prone to burning through rotors. I never heard of it from Audi.
Bob
Good Answers: 58
10/24/2011 5:07 PM
I suspect the bad rotor has a resistor cast into it, and that resistor failed. The voltage could not pass through the resistor, so it found another path.
mike k
Good Answers: 52
10/24/2011 5:51 PM
It does have a 1K resistor cast into it, although I am not sure this was the point of failure although it is possible. A digital multimeter reading showed the resistor to be 1K as it should be. The failure seemed to be that the plastic must of had an unseen crack or void and a carbon trail in the center that allowed the spark to jump to the metal shaft it sits on.
10/24/2011 6:03 PM
1. Originally the carbon resistor in the rotor was for radio intererence control.
2. Was given a little-used 1955 Buick that had not seen more than 30 MPH in 10 years. On the way home it gave out one backfire and slowed to a stop. Found the remains of the resistor spread around the inside of the distributor cap. Long walk to Auto Parts Store. Had never seen a resisitor in rotor before ( 1970s .)
3. Was given early Honda Civic CVCC by family who had given up in disgust at not being able to keep it running, and when running was difficult to control engine.
I took to Honda Specialty shop, paid dearly for tune-up which they claimed was all it needed. Few thousand miles later, back to same deal. Took to another Honda Shop who did and said the same thing. Same deal, few thousand miles and behavior was back. Finally, I took a look at it myself .
Turned out that the worn rotor conductor across the top was too short and left a larger than designed gap between rotor and individual distributor contacts to wires.
Total resistance was excessive! With a tune-up, spark plug gaps were at their minimum and there was just enough spark to do the job. As plugs wore, gap increased and eventually the gap was too much for the total system. Became hard to start and behaved badly under load. New rotor solved the problem for years.
(This engine was pretty fussy overall. First one to pass California Smog standards without a Catalytic Converter.)
Any good tune-up shop should have spotted the TOTAL RESISTANCE issue. Why they had not been changing the rotor, I don't understand
10/25/2011 11:55 PM
Thanks for letting us know the cause. One to add to the memory bank. I would not have considered the rotor, given it was new. In future i will keep all old parts so i can go back to the beginning if the new ones don't work.
Cheers,
Jim
Register to Reply 29 comments
Anonymous Poster (4); bob c (4); dj95401 (3); frankd20 (6); hatchera (1); JIMRAT (1); kramarat (2); mike k (1); Not too Smart (1); Oregoon (1); richard harris (4); tom (1)
