Previous in Forum: The LED Revolution   Next in Forum: Underground Cables vs Inductance
9 comments
Panel SFU Rating & Cable Size
11/21/2011 12:23 PM
I want to procure a panel load of 12 no. of welding receptacle feeders of 63A rating,Pls tell me what should be the incomer cable size & how its calculated.What should be the main SFU rating of the panel.Pls guide me.
"Know something about everything and everything about something"
Re: Panel SFU Rating & Cable Size
11/21/2011 1:31 PM
Do you the NEC as your reference.
11/22/2011 3:02 AM
Even that would be okey to refer,though I work in India.
Thanks.
11/22/2011 3:14 AM
British Standard 7671.
11/22/2011 4:58 AM
I would be happy if you can give a rough estimate of the same.
Thanks.
07/05/2024 9:29 AM
Declined. Prices can be ascertained by contacting the British Standards Institution website. All that is needed to obtain a copy is a valid credit/debit card.
The other option is to delegate the task to a qualified local Electrician.
<unsubscribes>
Good Answers: 170
11/22/2011 5:52 AM
What is the diversity factor and what is the simultaniety factor?
11/23/2011 2:22 AM
What I can say is that,maximum 3-4 feeders will be ON at a single time.
I cant find any desinger over her.
Pls help for atleast approaximate estimation of the same if you have any idea.
11/23/2011 12:34 PM
The information I gave you give a diversity factor for you project.
Register to Reply 9 comments
electricalexpert65 (1); giri (3); PWSlack (2); wareagle (3)
