Previous in Forum: Battery Charger versus Power Supply Unit   Next in Forum: Is it Possible to Have Different Number of Phases in Stator and Rotor of SCIM?
18 comments
Effectively Grounded?
12/01/2011 8:47 PM
Re: Effectively Grounded?
12/01/2011 9:01 PM
So whatza da problem??
12/01/2011 10:41 PM
LMAO
Oh that's so funny!!!
What size fuse did you calculate for this?
12/02/2011 12:19 AM
"What size fuse did you calculate for this?"
We're still working on that....
12/01/2011 11:29 PM
If the yellow paint is scratched off where the "ground rod" touches it, this scheme might have a chance (depending where the railing pipes go).
Good Answers: 130
12/02/2011 12:50 AM
(great sight gag for inspectors, but in reality, it would be)
12/02/2011 2:22 AM
Whoever designed this goofy lash-up should be sent to their room for a week...;
i.e., effectively grounded!
12/02/2011 3:03 AM
What on Earth is that?
Good Answers: 181
12/02/2011 5:10 AM
10 out of 10 for ingenuity!
Good Answers: 140
12/02/2011 9:34 AM
Two scary things come to mind...
1) Some clown either got paid to do this or made a buck off of doing it.
2) Some unsuspecting worker who does not know any better (yes... I know, unlikely, but possible) may thing this pile of ?? may be safe to use.
Sad...
12/02/2011 3:31 PM
The stuff in the bucket looks a bit dry to me, maybe it would have been better if he'd added some water.
But wait: I think he's forgotten to strip the insulation off the wire wrapped round the rod.
12/02/2011 3:44 PM
Water? Beer and whiskey would be more suitable here.
But only after they pass through my kidney.
12/03/2011 2:21 AM
Wireless is the technology of the future !!!!
The sum of intelligence on earth is a constant. And the population grows and grows and .....
12/03/2011 2:43 AM
LynDoor Industries™ is already on top of this with their wireless "White Lightning" grounding/bonding kits in various amp ranges.
12/03/2011 7:30 AM
some reason!
LifeCycle of Engineering
12/03/2011 6:21 PM
I know that guy.
12/03/2011 9:00 PM
I knew those Phd's weren't all they were cracked up to be!
12/05/2011 3:14 PM
The safety inspector has determined that the only thing wrong is that there is NOT a yellow safety cone on the bucket side of this contraption.
I nominate this photo for "Caption This"
12/06/2011 6:56 AM
Pretty funny...Rube-Goldberg Ground. Actually, if the rod leaned against (touched) that metal railing or used a metal bucket, it might lower the resistance to an acceptable level, at least for an "equipment-ground". If that generator has a neutral and if that neutral isn't switched by a transfer switch, the neutral-ground is "preserved" bt a solid connection all the way back to the existing servvice neutral-ground. Under this condition, the pictured ground isn't even required, and would be used only as an "equipment-or safety" ground.
I like one where a buried car was used as a ground.
Yep-stuck in the middle with you.
Register to Reply 18 comments
34point5 (1); Anonymous Poster (1); engineertony (1); khairul.asra (1); North of 60 (1); PWSlack (1); Randall (1); redfred (2); SITMWY2 (1); SolarEagle (2); StandardsGuy (1); szwasta (1); TonyS (1); Tornado (2); uweka (1)
