Previous in Forum: Problem with Polar Mohr 72   Next in Forum: Circuit Breaker Open/Close Time
What is the Difference Between ( KWHM & KVARHM )
01/24/2012 6:26 AM
1- What is the difference in internal structure and the theory of work between the watt-hour meter and VAR-hour one.
2- is there a single phase var meter ????
Thanks to all
sokrer
Re: What is the difference between ( KWHM & KVARHM )
01/24/2012 6:35 AM
A1: the cosine of the phase angle between voltage and current.
A2: yes.
01/24/2012 1:58 PM
Hi PWSlack
i know the angle must be ( -90 ) between A & V
I notice that the internal instruction is the same for the tow meters
but i want the work theory for each of them 3 ph & 1 ph.
And ask if the var meter must be always delta internal conn. and watt meter star conn.
Thanks
sokrer
Good Answers: 61
Re: What is the Difference Between ( KWHM & KVARHM )
01/25/2012 4:23 PM
For older electro-mechanical (disc-type) meters, there is no internal difference. An external phase shifting transformer is used to offset the voltage inputs by 90º. Digital meters sample voltage, current and phase angle simultaneously. Once you've got those numbers it's just math in the processor to determine which output to display, and most digital meters can display either parameter with the press of a button.
02/15/2012 5:08 AM
thank you
verry much
sokrer
Register to Reply 4 comments
pwr2thepeople (1); PWSlack (1); sokrer (2)
