Previous in Forum: lcd pixel   Next in Forum: 3D Glasses
Microwave Generator
02/05/2012 10:08 AM
which microwave generator is used in microwave repeaters in telecommunications?
Good Answers: 1693
Re: microwave generator
02/05/2012 10:17 AM
Your question makes no sense.
It is impossible to answer.
02/05/2012 11:53 AM
Good Answers: 116
Re: Microwave Generator
02/06/2012 1:38 PM
You ask a very broad question, the following defines "microwaves" as below 1 metre to 1mm wavelength, or 300 MHz to 300 GHz ....
http://en.wikipedia.org/wiki/Microwave
Also, the word "telecommunications" is very broad, since it means "communication at a distance".
Telecommunications used to mean telephone communications (audio speech channels of 300 - 3400 Hz) - and microwave was many speech channels. Approximately, a 600 speech channel analog system could carry one analog PAL/NTSC television channel.
Nowadays, most communication is digital.
However, any high capacity system has problems of frequency stability, linearity or timing error which make direct use of a microwave oscillator, even at 300 MHz, a problem. Usually, the master oscillator is a quartz crystal-transistor unit which is fed through frequency doubler/tripler/amplifier chains to get the final frequency.
Frequency modulation [or FSK - frequency shift keying (digital stepping between 2 frequencies] is common, because the considerable erratic amplitude fading possible due to rain etc on direct radio paths has little effect.
Since frequency modulation of a stable oscillator is limited, it was usual to phase modulate the amplified oscillator signal, then limit the amplitude of that to a constant value - leaving only frequency modulation. This frequency modulated signal was then amplified before feeding into doublers/tripler chains to get the final frequency.
The "travelling wave tube" has seen much use since it can give very wide band linear amplification [say 2:1 bandwidth] and can give very high powers at microwaves. Useful for satellite repeaters, where each communication path must use a different frequency.
Microwave repeater use for "fixed line" telephone connection began to decline in the 1980s with the advent of optical fibre systems. However, modern mobile-phone systems use microwaves, 2 GHz, 3 GHz etc, both to connect base-station to phone and to interconnect stations. So the base stations could be considered "repeaters".
Various types of transistor are used in these systems for microwave amplification etc.
02/08/2012 9:31 AM
thanks...
Good Answers: 119
02/09/2012 5:39 PM
67model (1); lyn (1); mjb1962853 (1); shyam arshid (1); SolarEagle (1)
